Question about Cisco 7912G IP Phone
My Phone is on Busy Mode
I am using a Cisco Phone 7912 Series and my main problem is the busy mode since last week. This is what happened: I placed a call then, I got to have an incoming call. What I did was to end the first call anf pick-up the second one. After I finished talking to the second caller, I put down the phone and after that it started to be on the busy mode. I already rebooted the phone and re-configured the CCME but still, it doesn't work. What will I do? I hope you could help me on this. Your help is highly appreciated. Thank you very much. Best regards, Angeli san Juan
  • Angeli San Juan Jul 08, 2007
    Hi Pastorm,
    Yup, I am in a Call Manager. Up to now, it is still on a busy mode. I can use it for out going calls only but it doesn't work once the call/s is being transfered to me.
    How am I hoing to fix this?
    Thanks a lot for dropping by.
    -Angeli-
  • 98 Answers
Are you in a Call Manager envirnoment ?
Posted on Jul 06, 2007
  • Marcelo Pastorino
    Marcelo Pastorino Jul 17, 2007
    Have you tried reseting and restarting the device from the Call Manager Admin page ? It should be the first thing to try.
Problem with cisco sg500
I'm not familiar with the device, but it might be something in the configuration. It could be DHCP, it could be something deeper.
I suggest contact Cisco support directly, they have support forums too.
Dec 11, 2013 | Cisco Small Business 500 Series Stackable...
Cisco ip phone 7912 is not working. when conecting in LAN then it will not boot, while another same series ip phone on that LAn port works perfectly. Only red and green LED blink continue in...
If it is getting an IP address, goto that IP address and there you will be able to see some console messages. See if alternate TFTP is set and is going to a different CM server. If so change it to the ip of your CM.
Aug 17, 2017 | Cisco 7912G IP Phone
ONE OF OUR PHONES IS ALWAYS BUSY. YOU CANT CALL THE EXTENSION OR FORWARD VOICEMAIL BECAUSE ITS ALWAYS BUSY. HOW CAN I TURN THIS OFF??
You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Jan 18, 2011 | NEC Dterm DTP 16D-1 Corded Phone
Want to migrate fom sccp to sip protocol for cisco IP Phone 7912
Here's a great little document from Cisco directly, called "Converting a Cisco 7940/7960 CallManager Phone to a SIP Phone and the Reverse Process"
Easy to do, just follow the step-by-step directions.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
Jan 21, 2010 | Cisco 7912G IP Phone
Doesn't answer calls or answers with speaker only
This is happening because your "Self-Cleaning" hookswitch is going bad. Since it's a carbon contact design, this will happen more and more frequently. I recommend sending your Cisco IP phones to IdacomUSA for repair and refurbishment. If you are the DIY type of person, we are also selling the pad and assembly for the Cisco hookswitch at $15 each (w/minimum order)
Jun 04, 2009 | Cisco 7940 IP Phone
Phone line gets busy tone while recieving fax in DRPD mode
As I understand it, this is as it should be. You have two different numbers sharing the same physical line and only one can be active at any one time, so if you are using the phone and someone tries to fax, the fax line will be engaged and similarly, if you are sending a fax and someone tries to ring on your phone line, it will be engaged.
Nov 07, 2008 | Samsung SCX 4521F All-In-One Laser Printer
CISCO 7912 Ip Phone,Red lights are continuously on.
Well, in most Cisco VoIP phones those lights are used to tell you if you have a voicemail. Have you checked your vm and cleared any new ones? This might be your issue ;)
Oct 14, 2008 | Cisco 7912G IP Phone
Network busy
This happened to me once before and I found I had the phone on flight mode instead of normal. Switch it off and on again and see if that works, if not there is more to it. I'm no expert with technical things but worth a try.
Jul 07, 2007 | Sony Ericsson K800i Cellular Phone
"busy" Error
check your firmware version and update if necessary. Usually you get the "busy" message when your camera is writing to the card and it's possible the card isn't quite right - a format should fix it. Alternatately you might try a different CF card to see if the problem goes away. Good luck!
Sep 14, 2005 | Canon EOS-20D Digital Camera
Cisco 7912G IP Phone Logo
346 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
