Question about Vehicle Parts & Accessories
I installed an avital 4111 in a 2003 saturn l200. It worked fine when I returned the car to my customer. Now it's not working. It just ticks. Like I said, it worked fine and now it doesn't. She said if she pushes the button on the remote about every 15 times it will start. Any ideas?
  • 625 Answers
What bypass did you use?
Posted on Dec 16, 2012
RAIN3R
  • 5 Answers
SOURCE: changed batter remote start not working
Hello, What has happened is your remote has lost its programming.. Just like with most electronics, when something is reset or powered off, or even when the battery dies ....the programming software is lost. The remote has to be reprogramed either by a dealer (suggested) or by an aftermarket outsource..Hope this helps...This could help with almost all remotes.
Posted on Nov 22, 2008
  • 13 Answers
SOURCE: prestige aps-57 remote start...car won't start
Hello hope this can help you. First check the starter wire, it is tan/lt blue located at the ignition harness. usualy during installation of the remote start system this wire is cut leaving you with two ends. one wire is coming from the ignition switch the other is going to the starter. the brain of the alarm hooks into both of these wires. if the repair man cut the wires from the brain and spliced them together he has just put the system back to OEM status leaving the alarm no way to engage the starter. I believe that may be where the problem lies but if not then I would say check your immobilizer bypass module the repair man mave have diconected that.
Thank you,
Luis
Posted on Dec 04, 2008
blueextc3221
  • 15935 Answers
SOURCE: remote start doesn't always work
It is that way because you wouldnt want the car starting when you have it it in your pocket or purse.
Sounds like the keypad contacts may need cleaning, or have been bent/broken/etc.
Have you tried another (backup) keyfob?
Please do this and report back.
If you are having problems, the installer should troubleshoot for you for free.
Posted on Jan 14, 2009
ltfrc
  • 227 Answers
SOURCE: engine cranks will start fine with key remote will not start it
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
Posted on Jan 28, 2009
SOURCE: how do I reset or reprogram a CS34-II TX remote?
u dont know?
Posted on May 15, 2010
How to reset the security system on a 2002 Saturn l200
i know what issue is.. it happen to my car, i found a module that you can install yourself and it will bypass the security system.., check it out they have great customer service .. I bought it and my car runs great to this day. hope this helps
http://vatspasslockpasskeysecurityhelp.com/ Do It Yourself GM Security bypass
Jan 21, 2017 | 2002 Saturn L-Series
Replaced ignition control module on 2001 saturn l200 2.2 litre engine and now car won't start
may be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here: chinasinoy.com
Jan 28, 2013 | 1993 Saturn SW2
I can't find a rental place to rent Kent Moore
I'd be willing to bet that a standard ball joint remover/installer would work on this application. Looks like a big "c" clamp with adapters to fit into place. A large screw aids in the install.
Jul 28, 2011 | 2003 Saturn L-Series
My question is this I have a 2001 L200 series 4 door saden and I was worndering when my car goes tick tick tick is that the starter not working and if so how much would one run me or is it something else?...
If u here that noise double check the battery and connections at terminals. That clicking is the starter tryin to turn and more than likely is ok but a poor connection or a bad battery the starter cannot pull proper amperage to start the vehicle. If the basics check out u can condem the starter but on any vehicle an electrical system or any other system cannot be correctly diagnosed without a fully operating battery
Jul 16, 2011 | 2001 Saturn L-Series
What's the meaning of a symbol looking red with a car/wrench on the instrument panel of a 2003 saturn l200? horn don't sound,ac won't work,doors won't unlock after ignition is turned off.
A wrench symbol is the equivalent to a check engine light. Take your car into a mechanic and let them diagnose the error code the engine light is storing to help diagnose the problem.
May 20, 2011 | Saturn L-Series Cars & Trucks
My saturn won't go into park. All other gears work
some vehicles have a small slot next to the AT shifter on the floor. about the size of a car key to fit in. on my vehicle that is the release to let the shifter go into park. just find something long to stick in there like your spare key then try and return the shifter to P with the brake depressed. just push straight down, there is no turning motion to do this. this happened with my accord.
Feb 11, 2010 | 2002 Saturn Sl
I have a saturn 2002 l200. The right high beam isn't working
pull the bulb out and look for burnt spots on the connector. if it's burnt or corroded you can get a replacement at a good auto parts store
Nov 16, 2009 | 2002 Saturn L-Series
Saturn L200 2002 electrical and engine does not work
Tighten the battery connections with a wrench, not pliers!
Loose battery problems are a common problem with GM side mount terminals. They need to be very tight to work right.
Happened to me before too! No power, no lights, no radio, no crank.
Jan 02, 2009 | 2002 Saturn L-Series
Vehicle Parts & Accessories Logo
154 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
