Question about Dryers
Frigidaire dryer (model/serial FERB6600eso/al #XD61204062) spins, but doesn't heat and has noise.
The noise is due to a metal spring that moves when dryer spins. How much will cost to repair it?
  • 113 Answers
SOURCE: Frigidaire dryer model number LGQ1442ES0 won't stop spinnin
Ive seen this before. There was actually a coin that had fallen out of the drum and got stuck on one of the contacts, causing it too short. Open the dryer panel, unplug it first, and look for any signs of a coin or somthing shorting a circuit. Thats step one. Hope this helps. Dave www.washermd.com
Posted on Dec 17, 2008
WonderTech
  • 268 Answers
SOURCE: Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Posted on Aug 12, 2009
  • 1531 Answers
SOURCE: have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
Posted on Sep 17, 2009
  • 1738 Answers
SOURCE: frigidaire dryer no heat thermal fuse seems ok?
check your vent, make sure it is not plug with lent. If it is not then your heating elements.
Posted on Dec 06, 2009
Testimonial: "quick and great info"
  • 59 Answers
SOURCE: noise in dryer Frigidaire model fde336res1 when running
Could be the drum bearings are worn. These are what the dryer drum turns on and when they wear out the drum and frame rub together (metal to metal). Also could be the belt idler which keps the belt tight around the drum. In either case the dryer would have to be internally accessed to determine failure.
Posted on Feb 17, 2010
Testimonial: "thank you. I will call repair man."
Frigidare dryer aeq6000es2 doesn't spin, humming noise, burning smell
Hello tancrbtt - It sounds like your unit may have one or more problems. Either the belt slipped off the idle pulley and/or dryer belt and needs replacing, a faulty motor or a common failure between control and motor. Consult a professional to accurately diagnosis the dryer and to assist with the repairs.
Feb 12, 2013 | Frigidaire Electric Dryer
Dryer has power but doesn't spin or heat up
Check to see if the door switch "clicks" when you push and release it. If the switch is bad, the dryer won't run. Here is the part in case you need it.
Oct 30, 2012 | Frigidaire FGQ332ES Gas Dryer
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 23, 2012 | Frigidaire Dryers
When the dryer gets hot, the tumbler begins to make a continous squeaking noise as if there is metal to metal; not a grinding noise. If you allow it to cool down and restart, it doesn't start until it...
Well ya never mention in your question what brand you have but a GE or Hotpoint dryer has a small plastic insert that wears thin over time. It begins to do a squeak squeak squeak type of noise.And that noise is intermittent, on a Frigidaire model the noise would start out low and gradually get worse. The bearing sometimes gets so bad it gets chopped off and the tub falls into the heating element.
Jun 30, 2011 | Dryers
I have a Frigidaire dryer mod# ferb6600eso electric dryer. When it runs, it sounds like metal on metal. Is there felt around the front and back of the drum and could this be worn out?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 28, 2010 | Dryers
I have an frigidaire electric dryer model number FERB6600ESO will not get hot. What could be the problem?
First check to see that your getting 220 Volts to the dryer.
Then locate your heating coil on the back of the dryer under the metal plates.
You should see a fan/blower housing that goes to the inside of the dryer drum that is where you will locate the heating coil, also some times the thermostats/thermistors are located either inside or outside of the same fan/blower housing. Check them to make sure they are not faulty.
Good Luck
Please rate me
Thanks
Aug 12, 2010 | Dryers
Dryers Logo
Top Dryers Experts
