Question about Microsoft Windows Vista Ultimate Edition
Vista screensaver slow to respond to movement of mouse
When the screensaver has been on and I want to use my computer I move the mouse and the screensaver takes time to close. Most computers you move the mouse and the screensaver is gone.
  • katsu54 Jan 14, 2009
    I am running Viata and my computer has 3 gig of Ram. The computer is new, just got it in Nov. nothing else is running when the screensaver is on,
  • 71 Answers
Changing to a less active screen saver
Posted on Jan 13, 2009
    Problem Solver:
  • 6 Answers
This only happens when optimum amount of RAM is not available on your computer.
Since you have not disclosed the config of your computer, I would recommend you to increase the RAM on your computer.
Thank You.
Please rate my solution.
Posted on Jan 14, 2009
  • rishabhj Jan 15, 2009
    Then there is a problem with your windows installation.
    This usually happens when the windows system files are corrupt or there is a problem with DirectX files....plz check up with your GPU one also.
My cordless mouse is very slow
When you say 'very slow', I'm assuming it is slow to respond to movement. Does the mouse pointer behave this way if you use a wired mouse? If so, your problem is something in your operating system. If not, you may need to move the transceiver closer to where you use your mouse, or perhaps put it in a line-of-sight with the mouse.
Jun 11, 2013 | Computers & Internet
New cordless mouse slow to respond to "click": cannot control or direct movement: jerky, sporadic. Is this because I do not use a mouse pad?
mouse pad would help but you may have a virus so go to windows help and support and download the windows defender and run it, there have been a lot of bugs affecting mice lately however do try to use something that has a surface on it that would make the mouse work better if it does work better then buy a mouse pad next if it's still slow you can go to control panel and sped up the mouse and also into tools Internet connections and change the mouse properties there.
Feb 05, 2010 | Logitech Cordless Mouse
Mouse continually skips around. I changed batteries, reset it and everything. What's wrong?
You have the tracking speed set too high.Go to 'start'-'control panel'-'printers and other hardware'-'mouse'.After opening mouse you'll see "pointer options",click and you'll see "pointer speed".Move the speed down from fast to slow until you can see it easily.The other thing is if you don't have enough RAM memory it won't be able to keep up with simple hand movements.Click "start'-right click"computer"left click"properties"and up will come what you have for a computer will be displayed.Near the bottom of the page will be RAM,to it's left is how much you have.XP you need at least 512MB(1GB is better-up to 3GB best)Vista 1GB minimum,up to 6GB with Vista x64.Adding Ram is the easiest way to speed up a sluggish machine.Please re post if you'd like to get into changing setting for best performance.
Dec 30, 2009 | Dynex Wireless Optical Laptop Mouse...
Mouse suddenly not moving very well, and takes a long time or extra clicks to respond
There are several things that this could be. First, let's suspect the mouse itself. Make sure it has fresh batteries. If it's rechargeable, make sure it's charged. Be aware that rechargeable batteries WILL stop working at the end of their life. Another easy fix to clean the movement detection mechanism. If it's a ball mouse, take out the ball and clean the rollers. The dust will probably be wound so tight around them you'll think it's a rubber washer or something, but you can pick it off with a little trouble. If it's an optical mouse, clean the lens with a dry cotton swab. If this doesn't fix the problem, try plugging the mouse receiver into a different port on the computer. Check your computer for viruses, spyware, anything that might be slowing it down. Check to make sure you have the latest drivers installed if necessary.
Nov 25, 2009 | Logitech Cordless EX 100 Mouse
Cursor and keyboard movment responds very slowly
Does the slow movement of cursor and keyboard seen only on excel? Given that your excel is not corrupted, it just could be the file size of the worksheet you are working is too big. But if the slowness is present even on small excel file, you may consider re-installing your excel.
But if the slowness is present even on other application, then the problem could be on your pc itself.
Oct 26, 2009 | Microsoft Excel for PC
Monitor picture turns on its side when it goes to screensaver
Sounds like your screensaver is using a picture of your desktop in it's code intentionally.
Right click on a blank area of your desktop --> select properties
--> click screensaver --> change it to "none" or another screensaver
Jan 17, 2009 | CTX S762A 17" LCD Monitor
Mouse Sensitivity Issue
If your laptop is Vista, this page should have a download for a Vista touchpad driver:
http://consumersupport.lenovo.com/lenovo/drivers/2412/50.html
If it's an XP laptop, try this link:
http://consumersupport.lenovo.com/lenovo/drivers/2412/313.html
If one of them works, let me know which one and rate appropriately. If neither of them do, we'll try something else.
Thanks.
Aug 25, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Wireless mouse
sometimes wireless mouse is a bit slow in responding.
use a mouse pad sometimes it helps.
Mar 26, 2008 | Logitech Cordless Mouse
Microsoft 3000 wireless mouse problem
Normal 0 If you are using Vista Operating System this is a common problem.
!. Go to MY COMPUTER and RIGHT CLICK on it.
2. Then CLICK on PROPERTIES.
3. Next CLICK on DEVICE MANAGER. 4.Next CLICK on CONTINUE..
5. CLICK on the HID HUMAN INTERFACE DEVICE +.
6.Right CLICK on the HID NON-USER INPUT DATA FILTER.
7. Click on UPDATE DRIVER SOFTWARE. 8. When the screen comes up CLICK on SEARCH AUTOMATICALLY for UPDATED DRIVER SOFTWARE.
When finished the screen saver should work properly. Bud
Feb 21, 2008 | Microsoft Wireless IntelliMouse Explorer
Microsoft Windows Vista Ultimate Edition Logo
100 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
