Question about Vehicle Parts & Accessories
Need help disconnecting alarm on truck can't afford to take to shop can you help me out there
  • 625 Answers
Let's start with the year, make and model of the vehicle.
Posted on Dec 16, 2012
I have two issues: 1. AIRBAG alarm is on. I see
You can try stop leak, but there is a HUGE chance it won't work. Your best bet is to get a repair manual and learn how to replace the seals. As for as the airbag goes, do you know why the light is on? Why are you trying to disconnect the wire?
Aug 24, 2013 | 2005 Audi A6
I have a mitsubishi 3000gt and my alternator fuse keeps blowing. i think it might have to do with my aftermarket alarm and automatic start, but i had just gotten a new battery, alternator, and egnition...
If they go out, you need to go back to that shop and have them repair it correctly. Apparently they had someone work on it that didn\'t know jack about installations. I imagine they didn\'t install a relay and hooked it up to the alternator directly and somehow grounded the alternator with something in the car. If your blowing alternator fuses, that is serious in most cases since the alternator puts out heavy amps. Be sure your using the proper amperage fuse for the installation as well. Try returning to shop that installed the stuff and don\'t let them get away with keeping your car that long. That is ridiculous and if your not happy with their attitudes, report them to the BBB.
Aug 08, 2013 | 1995 Mitsubishi 3000GT
Our 2000 Mustang continually needs to be battery jumped. Took to shop, they said not battery or starter. They said it's Ford car alarm that is draining battery. Now what?? How do I disconnect
If the shop could find the problem, why
can they not resolve it ?
Need a different shop, if there is such
a place these days, that can actually
fix something
Apr 03, 2013 | 2000 Ford Mustang
My alternater and battery test good on my 01 kia spectra.But, After putting the fully charged battery in my car, it slowlky died in on ly a few blocks drive?
Connect an ammeter in series with the battery positive terminal and battery positive lead. With ALL systems off, including alarm, door lights etc and with doors closed you should have a reading of only 0.03 amps.I'm guessing that yours is higher as it sounds like you have a parasitic voltage drain.If indeed it is higher, then disconnect any alarm system first and check your amps again. Every time you disconnect something, go back and check your amps.Once you get your amp drain back to normal, then you have managed to disconnect the system responsible for the high current drain.
The most likely candidates are always the alarm system, then stereo, then GPS tracker. After that you will have to start pulling more fuses, one by one and letting the vehicle rest for a few minutes after each thing is disconnected before taking a reading.
BTW, if it is the alarm which is drawing a high amp drain, then it is more often than not the alarm siren back up battery which has failed.
Good luck.
Nov 14, 2012 | 2001 Kia Spectra
I bought a new battery and still wont start
Have you had the alternator checked? may not be charging the battery.
Oct 30, 2012 | 2004 Mercury Mountaineer
I can't turn off the security alarm on my 1998 nissan pathfinder
I couldn't turn off the security alarm on my 1999 Pathfinder as I replaced the battery,
Solution: I read the solution here to disconnect the positive cable, open the driver's door, insert the key, then reconnected the positive cable, while honking, I turn the key to the left, to the right and to the left again while the door is still open. The honking stopped. Then I started the truck without a problem. Thank you for the hint.
Jun 12, 2012 | 1998 Nissan Pathfinder
2006 jetta alarm randomly arms
its the battery in the alarm it has an alarm backup battery built in to the alarm when it fails it sets off the alarm, its in the siren part unit. its not usually replaceable but you can break it open and replace the battery or disconnect the unit, but the alarm will not go off, and it does not have a back up alarm horn.
Aug 13, 2017 | 2006 Volkswagen Jetta
Temporarily disengage alarm on 2000 honda accord ?
Under the dash on driver side the alarm box is usually placed there. You should be able to unplug it from power there.
Dec 24, 2011 | 2000 Honda Accord
2001 mits montero ltd, rechrgd battery & reconnect-alarm goes off
by a cheap amp meter from your local electrical shop should not cost any more than $20, disconnect negative terminal from battery and put the amp meter in between the negative post and the disconnected terminal you will find that there is a number apering on the amp meter eg. 2 amps start pulling fuses one at a time and see if the nomber drops ( always refit the fuse after you pull each one our you may have problems later working out what fuse gos were) when the nomeber dose drop you have found the circut that is at ault and you can make the choise of operating without this cercut or fixing it
good luck
Nov 29, 2008 | 2001 Mitsubishi Montero
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
