Question about Microsoft Xbox 360 Console
No power My power cord box has a red light on, so my xbox will not turn on
    Sergeant:
    Champion:
  • 378 Answers
Try unplugging the cord from the wall and wait a minute before you plug it back in. If it still wont work you will need to replace the power cord.
Posted on Jan 13, 2009
When i turn on my xbox i'm getting 3 flashing red lights what does this mean
it means your xbox is overheating, you can send it back as they extended the warranty on it for this common fault unless you have modified it, in which case look up ring of death on youtube.
Jun 13, 2011 | Microsoft Xbox 360 Elite Console - Black
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
The power pack box to the system shows a red light...cant get the system turned on.
If it's showing a red light, it may no longer be good. You can buy an XBOX 360 power supply & cord at the following website:
http://store.richspsxparts.com/ustexb360pos.html
Aug 03, 2010 | Microsoft Xbox 360 Console
Three red lights flashing
Three red lights flashing means that there is a hardware fault.
Check your power supply light 1. Turn on your Xbox 360 console. 2. Take a look at the light on the power supply.
The power supply light is located on the end of the rectangular box in the middle of your power cord. If your power supply light is green
Solution 1: Check your power supply cables
Unplug and reconnect your power supply. Here’s how:
Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and from the power supply unit
Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
Make sure that all three power supply connections are firmly secured.
Turn on your console.
Before you perform solution 2, I would suggest you to go through following links.
http://support.xbox.com/support/en/us/nxe/kb.aspx?ID=907534&lcid=1033&category=hardware
and
Following link is an interactive troubleshooting link.
http://support.xbox.com/support/en/us/xbox360/hardware/console/troubleshootingconsoleproblems/flashinglights.aspx
Solution 2: Submit a console repair request
Your console needs to be repaired. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: I am a U.S. customerI am a customer outside the U.S.
This solution is absolutely FREE, so please rate and give positive feedback.
Thank :)
May 09, 2010 | Microsoft Xbox 360 Console
Xbox won't power up, orange light is on the power brick
Are you using a plug and play kit? if so disconnect it, mine does that sometimes, if thats not the case comment me,I would write them all down but I am getting a bit fed up with writing lots of solutions to problems and getting no response from the person I give the time to help.
Feb 13, 2010 | Microsoft Xbox 360 Console
Power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Apr 10, 2009 | Microsoft Xbox 360 Console
Red Light on Plug in connecter thing
Sounds like there is something wrong with the Xbox 360 power supply, try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord. Give it a minute then reconnect it all back, also try it on another wall outlet without any extension cord at all.
If it's still red that suggests fault with your Xbox 360 power supply so will need to contact Xbox 360 customer support if its under warranty they should be able to sort it out for you. If out of warranty it might cost you for a new power supply!
Dec 13, 2008 | Microsoft Xbox 360 Console
My xbox 360 power cord box messed up....
check your Audio/Video cable connection, sometimes those lights means that the plug isn't in the xbox/tv all the way
Jan 06, 2008 | Microsoft Xbox 360 Console
XBox 360 power problem
The power brick has most likely died.
Dec 14, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
47 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
