Question about Kenmore Washing Machines
Manual for Kenmore He top loader 28002010
Need a manual
2 Suggested Answers
  • 1937 Answers
SOURCE: my top loader kenmore is noi spinning
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Four possibilities: (Ranging from easiest to messiest)
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the
washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section
on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf8525712
2007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using
an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the
washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?
newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor
coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6
inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to
put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they
don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you've tested the Lid Switch and the Motor Coupler is fine, and the clutch bands and springs are OK the problem could
well be the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for transmission operations on top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b
0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into
spin mode.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the
Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to
have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and
gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator
uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two
clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8
screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic
cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't
go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Jun 01, 2010
Kenmore washer mold smell issue
front loader of top loader? For front loaders you need to dry around the front gasket and leave the door open 24 hours after each wash.
Put a couple of towels in the machine and add a full box of Arm and Hammer Baking Soda and do a 90' boil wash. Clean towels and the smell gone.
Jul 17, 2016 | Kenmore Washing Machines
I need a washing machine manual for a Kenmore top loader, model number 22422100
Please check your model number. Kenmore washers have a 3 digit prefix followed by another 8 digits. If your full model number is 110.22422100, then Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/12008/KENMORE-Residential-Washers-L0407343?brand_name_search=110.22422100 . This is a generic manual for all Kenmore one-speed automatic washers. A copy of the descriptions of the washer settings is available here: http://www.managemylife.com/mmh/owner_manuals/15224/KENMORE-Residential-Washers-L0305156?brand_name_search=110.22422100 .
I hope this helps. If your washer has a different prefix, please add a comment with the prefix. I'll try to find manual for the correct model.
Jan 22, 2012 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
My washer (Kenmore eighty series top loader) stops when it spins
The service manual is located inside the shell of the machine wrapped in plastic.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
Getting inside
Open console, remove brass clips, tilt cabinet (top, sides and front) forward.
Apr 13, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
521 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
