Question about Polycom Soundstation 2 Full Duplex Conference Phone - 2200-16650-00
Polycom soundstation 2 does not have a dial tone
When we dial the numbers they do not ring, nor does the phone have a dial tone. What can we do to fix this?
    Scholar:
  • 277 Answers
That Polycom runs off of Analog dial tone.
Either a dedicated line or in most cases from an ATA off the phone system.
You should be calling your vendor/tech in that handles the phone system to check programming, cabel, jack and the Polycom itself too.
Posted on Dec 13, 2012
5 Suggested Answers
  • 146 Answers
SOURCE: We moved our Polycom Soundstation
sounds like the 'brick' went bad
this is the power supply try replacing it
also and possibly more important did you reprogram phone and phone number when you moved it??
make sure you reset all settings and start new
Posted on Mar 21, 2011
SOURCE: polycom soundstation Ex - no dial tone
Someone in our office recently damaged the RJ-45 cable for our Polycom Soundstation. Because the jack was damaged I could not determine the order of the cables. After a call to polycom, we found the pinout information we needed - so I thought I would share, in case anyone else finds themselves in a similar situation:
With the RJ-45 prong pointing down the wires, from left to right are:
  • Black
  • Brown
  • Red
  • Orange
  • Yellow
  • Green
  • Blue
  • White
Then Crimp and test. I got this information directly from Polycom for use with the Polycom Soundstation. This information was not easy to get. They originally told me they could not provide the information and I would have to buy a power adapter. This is not true, just trim the cable and follow the above instructions.
Posted on Dec 03, 2008
JackHeath
  • 1049 Answers
SOURCE: Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
Posted on Oct 01, 2009
intower18
  • 957 Answers
SOURCE: Polycom soundstation 2 not showing
The link below may help you on resolving the issue. This is a PDF file for user guide:
http://www.orficn.net/Verizon%20Website/Phone %20Manuals/audio_conferencing_polycom_soundstation2_user_manual.pdf
Just click it. Please let me know if this help you or not so that I will proceed to the other solution.
Posted on Jul 23, 2011
We moved our Polycom Soundstation 2 from one office to another. It was disassembled and reassembled by who knows who. It is using an analog port from an NEC DSX 80. It recognizes an incoming call, but,...
Mar 17, 2011 | Polycom SoundStation
I can not get a dial tone on our new soundstation 2W I have unhooked one of our phone lines in our office so the line is good but does not work on the soundstation but works on our phone. When you try...
You need to update the software on the device. I called their support line and the tech explained everything. This has been a common problem with this conference phone.
Feb 07, 2011 | Polycom SoundStation 2W (2200-07800-001)...
How do I connect 3 phone calls on a Polycom Soundstation 2. There doesnt seem to be a hold button
It depends on what system it is installed on.
NUT, generally, with the first caller on, press flash you will get intercom tone again, dial 9 and connect to the next party. Once connected, press flash again and you should be connected to the original party.
Oct 23, 2009 | Polycom SoundStation2 Audio Conference
May 20, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Comcast Cable Modem with Polycom Soundstation Premier
Try adjusting the ringer volume, dial tone volume, and speaker volume. Make sure that the ringer type selection is not set to off. Also make sure that you are not bridging your call.
You can also use the Upgrade feature built into the phone to look for updates which may resolve your issue.
If this has only started happening recently, Restore the default settings and see if it resolves your issue.
Mar 20, 2008 | Polycom SoundStation
Polycom 2201-03309-001
The older Polycom SoundStations have power supplies that allow either anaog or digital signals. The phones themselves will work on either.
If your office phone systems are different, or if the extension it was originally plugged into was configured for analog and you are now plugging into digital would explain the problem.
Paul
Edge Telecom
paul@edgetele.com
Feb 20, 2008 | Polycom SoundStation
Conference call with a Polycom SoundStation EX
The conferencing capability to bridge 2 (or more) external stations comes from the telephone equipment/service that you have purchased. Either you are behind a PABX or Electronic KSU, which provides multiple phone service to your office, or you purchase conferencing capability from your local telephone provider (Verizon, AT&T, etc). In either case, the way to initiate a conference call would be the same as when you would have a desktop/office phone and establish a conference/bridged call to external parties. Usually this occurs by having one party on the line, flashing the disconnect button momentarily, getting a new dial tone, dialing and connecting to a second party, then flashing the disconnect button again, which signals the equipment to bridge those two calls to your station.  On the SoundStation EX there is a Flash button that provides that capability of momentarily flashing the disconnect button.  Try and see if that works. If not, then you will need to make arrangements to purchase the external equipment or service from your provider.  If you have the PABX or electronic KSU, it may also be a configuration option that you will need to have your support person for your telephone system, activate for that station connected to the SoundStation EX. Hope that helps.
Oct 22, 2007 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Polycom Sound Station
SoundStation: Changing dialing from Tone to Pulse
http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10966&sliceId=SAL_PUBLIC_1_2&dialogID=979138&stateId=0%200%20977279
Description
sp.gif sp.gif There are three ways that a SoundStation can be changed from tone to pulse, which depends on when the unit was manufactured.
1. Pressing the Keys 3&Vol + simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
2. Pressing the Keys *&MUTE simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
3. Operation done by DIP switches. Dipswitch Configuration On the bottom of the SoundStation, in the lower left hand corner of the large sticker may be a small silver sticker. Underneath that sticker are 4 DIP Switches. Switch number 4 is for tone and pulse,ON being tone, and OFF being pulse. Do not change the other three swithces as this could render the phone inoperable.
Sep 19, 2007 | NorStar Polycom Soundstation ( Phone...
Polycom soundstation Ex - no dial tone
  • Black
  • Brown
  • Red
  • Orange
  • Yellow
  • Green
  • Blue
  • White
Sep 14, 2007 | Polycom PCY220016000001 SoundStation2...
Polycom Soundstation 2 Full Duplex Conference Phone - 2200-16650-00 Logo
1,005 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
Sandeep Kamat
Sandeep Kamat
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
