Question about Kitchen Appliances - Others
How does the Fleetwood Meat slicer sharpener work
Someone took the sharpener apart to clean it and now we can/t get it back together and mount it so that it works properly. It is an EF12 slicer, Could I get a picture or a schematic of the unit and installation instructions.
SOURCE: Globe commercial Meat slicer
Hi, I have working on meat slicer my whole life and can help you.
What normally happens is this. The bearings in the knife hub (this is the unit that the knife attaches to and spins) is starting to fail.
The gear on the knife hub is made out of a fiberous material and the worm gear on the motor is made out of metal, so when the bearings start to fail and cause resitance in the hub, the metal motor gear starts to eat the fiber gear on the hub and eventually wears a big chuck out of it. Then the motor spins free and doesn't make contact with the hub gear.
How you can check if this is the problem is this. You need to keep the power switch on machine in the off position and turn the blade a 1/4 of a revolution. Then turn the machine on, what should happen is that the blade will spin some and stop again.
The proper fix for the machine would be to rebuilt the knife bearing unit and replace the hub gear, motor gear and hardware.
In regards to the Chefmate. This is a design flaw of Globe and I told them about this when the machine first came out! The know is on a steel shaft that goes thru the aluminum body. The steel shaft starts to corode and also rust, then it freeze in the frame. What has to be done is this. This assembly needs to taken about sanded, lubed and put back together. The best way to permently fix this is have a machine shop machine the frame out and install a Oilite Bushing, these are impregnated with oil and it will never lock up again.
Where are you located? Let me know if I can answer any other questions for you.
If you have any other questions, you can call me on my cell 201-274-6274 or e-mail me at njrealestate@earthlink.net. Thank you
Best regards,
Scott
Posted on Dec 27, 2008
  • 20 Answers
SOURCE: Berkel 827 sharpener not working properly
Your grinding stone stud is more than likely frozen try and lossen it up with a little penetrating oil take the sharpener off and work both stone back and forth untill they are both spinnig freely and remember do not apply either sharpening wheel on the knife for more than 5 seconds at a time you can burn the wheel and then it will never get sharp
Posted on Jun 13, 2009
protek480
  • 1714 Answers
SOURCE: how old do you have to be to clean a meat slicer
Old enough to know that you unplug it before you work on the blade!
Posted on Sep 26, 2009
  • 44 Answers
SOURCE: to sharpen the blade of my meat slicer
The stone that sharpens the back bevel is used for more time, but use grind for minimal amount of time, 30-40 seconds sounds extreme to me. The stone for the top surface of the blade is only pressed briefly to remove the slight burrs from sharpening on the back side of the blade.
Posted on May 22, 2010
SOURCE: Rival Meat Slicer Model 1037 Pin for blade
i too need a pin for this modle. has anyone solved this problem for that person?
Posted on Sep 15, 2010
The blade is wobbling on my Fleetwood meat slicer EF12 Slices look like waves.
check that the problem is not from the way the blade is mounted on the shaft
any thing between the blade and the backing hub of the shaft will make the blade wobble so check for burrs , bad fitting parts or the like at the blade center
new bearings , shaft and hub are new but is the hub on the shaft straight
Dec 17, 2015 | Home
Can't sharpen blade
1 of 2 problem exist, you need new stones, or the depth of your sharpener needs to be lowered to compensate for blade wear
Mar 27, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
We have a meat slicer with no manual and no brand name anywhere on it! The only information on it is a plate at the back that says "MATR 32, TYPE 220M" My husband can't figure out how to...
Hi if he has to remove it , never heard of someone removing a blade to clean it , he needs to use a inpact screw driver with a hamer, I see so many louse fingers not knowing what they are doing
Oct 02, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
To clean can I 1) hose it down with a dishwasher
This isn't recommended, meat tends to get in a lot of the nooks and crannies in a slicer machine. It's best to first unplug the machine, then take it a part in order to properly clean it. If your not sure how to take the machine apart, consult the user's manual for further understand how to do it. Once taken apart, some sort of stainless steal cleaner followed by a sanitizing soap should be used to clean it. Sanitizer is very important especially when dealing with meat products. Once a sanitizer is applied it is recommend that you let the slicer air dry for 4-6 hours before using it again to ensure the sanitizer has fully dissipated.
May 18, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
To sharpen the blade of my meat slicer
Oct 09, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
How old do you have to be to clean a meat slicer in the uk
Sep 19, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Looking for insstruction manual
e-mail onesharpstore@comcast.net give us the slicer model you want a parts manual for and we will see if we can help you
Mar 19, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Feb 03, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Kitchen Appliances - Others Logo
263 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
