Dear:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
SOURCE: my HTC inspire 4G won't turn on or charge. the
Was going through this article. It might help:
http://community.htc.com/na/htc-forums/android/f/113/p/9281/40043.aspx
SOURCE: Slide the phone open and
A white screen, especially on slider phones, is usually caused by a loose connection between the video output cable and the phone's motherboard. Unfortunately, opening the phone to access the cable voids the warranty, and is a delicate operation which risks damaging the phone.
Your best solution is to the contact your service provider. Most phones come with a 90 day - 1 year warranty on a service plan.
SOURCE: I have Nokia E55. Three
Another one with the same problem as me :-( !
Have you tried with a new battery? Or is it simply dead?
SOURCE: Hi, I am having trouble
Touch screen problem
If your touch screen is not working, there are just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
Please note that all data will be deleted from the HTC Inspire 4G as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
If that doesn't work, or if your phone is frozen:
All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
