Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
I put a gallon of diesel in a 1987 sportster. Permanent damage?
I drained the tank and put in fresh gas.
  • 91 Answers
Dont worry to much it wont hurt it anything, you said you drained the tank now you need to drain the float bowl and it will run agin
Posted on Jan 15, 2009
3:1 gas/ diesel in 2011 kia what can I do to remove it?
This site may have all your answers:
http://www.autobytel.com/car-ownership/maintenance-repair/accidentally-putting-diesel-in-a-gas-car-104029/
Basically do NOT drive the car and have the gas tank drained or talk to a mechanic.
Accidentally putting diesel in a gas car If you know that you have accidentally put the wrong fuel in the car, then don't compound the mistake by driving the vehicle while trying to think about what to do. Instead, call your mechanic immediately. At this point, the damage isn't permanent. If you drive and continue to drive, at one point the vehicle will stop and you will still have to have it towed.
There are two things you can do to try to fix the damage:
1. Try to clean up the damage yourself - have the vehicle towed home if it's not there already, and get as much of the diesel fuel out. How? By siphon if you can or any other method that you have available. Once you have as much of the diesel out as you can, fill the tank with the correct unleaded fuel that you normally use. Try to start the vehicle. It could take several attempts but it will start and it will smoke - a lot. It will continue to smoke until the last dregs of the diesel make its way through the system. It might run a little rough until everything is cleaned out. How it runs will depend on the proportion of diesel fuel relative to gas left in the tank.
2. Alternatively, have your vehicle towed to where your mechanic is and have the fuel tank drained of all the diesel fuel by a profession. They are also likely to flush out the whole fuel system. If the diesel stays in there for too long (and who knows how long is too long for your particular vehicle), it could ruin the fuel pump, lines and injectors. It is also possible that the diesel could have gummed up the spark plugs and filters. If this is the case, they will probably need to be replaced. Getting a professional to do the job will cost you anywhere from $100 to $500 and possibly a little higher depending on the extent of the damage.
Dec 29, 2015 | 2011 Kia Sportage
Run out of gas and put some watery gas in the tank, it cut off 3mins later
Just plain silly. Remove gas tank, drain and dry. Replace fuel filter. Fill gas tank with 5 gallons of fresh gas. Add a bottle of water remover to tank then start and drive. Good luck.
Aug 21, 2013 | Toyota Cars & Trucks
Had some gas in a can, so i poured maybe a gallon of it in my tank to make it to station. then found out it was diesel fuel. i only drove it a block and noticed it tryin 2 boggle out on me so i parked it....
Diesel should not hurt your car as long as you did not put to much in your tank. I would recommend that you buy a good bottle of octane booster dump it in your tank then fill it up with a high octane full like 91 octane. That should make up for the difference. Your car may smoke a little bit until all of the diesel is out of your system but it should be fine after that. I hope this helps and if you have any other questions please feel free to ask.
Sep 19, 2011 | 2002 Dodge Intrepid
I accidentaly put diesel fuel into my 2000 Acura 3.5 RL, the tank is 18 gallons, it was at about 2 gallons when I filled the tank with 4 gallons of diesel, I got the car towed back to my house, what steps,...
Very easy! Get a siphon and get all of the fuel out through the fill hole. Then put 5-10 gallons of good fuel with a can of Seafoam this will help to dilute any remaining diesel that is left. Start and let idle for at least 10 minutes. It may run rough for a little bit but will clear up and you will be ok! Good Luck!
May 11, 2011 | 2000 Acura 3.5RL
Filled tank accidently with diesel
No problem!!! Just syphon the tank and refill with gas. try to get as much diesel out as possible, obviously, but a quart or two mixed with the gas won't hurt, as a matter of fact it will act like a fuel system cleaner and lubricator. Beyond two quarts to 16 gallon tank and some egr system damage could occur.
Apr 03, 2011 | Nissan Pathfinder Cars & Trucks
I accidently poured 5 gallon of road desiel in my 06 hybrid. how do i get the diesel out?
Well, the good news is that filling a gasoline engine with diesel is not as bad as using gasoline in a diesel engine. There is likely no permanent damage.The bad news is that you're probably looking at several hundred dollars (perhaaps up to $500) to drain the fuel tank and engine and
flush the fuel lines. If the diesel gummed up the spark plugs and filters, they'd probably need to be replaced, but those are minor costs.
First, you won't be able to easily drain the fuel tank. I don't think
they put drain plugs on the tank as most imports do. The best way to
get the fuel out would be to remove the fuel line, extend it with a
rubber hose or something, and run power to the fuel pump. The best
place to do this would probably be at the fuel filter. The electric
fuel pump will pump enough fuel out of the tank to allow the engine to
start. It would be a good idea to run the tank dry, fill it with
another gallon of gas or so, then use the pump to remove that
gas/diesel mix also. Fill up with gas and you'll be fine.
As to replacing parts, or aving parts destroyed by the diesel, I don't
think that will happen. You might wanrt to change the fuel filter,
but even that wouldn't be mandatory.
Since your car is fuel injected and the fuel runs in a "loop" (the
injectors get fuel pessure from the in tank fuel pump, and the excess
pressure is fed back to the tank) any residual diesel will be flushed
out of the lines almost immediately. Just run the fuel pump with a
bypass without starting the engine, just like you did to drain the
fuel. As it runs it will circulate fuel through the loop and clear
out any diesel in the fuel loop. The engine should then start up
immediately.
One downside you MIGHT experience: the "honeycomb" catalytic
converters used by Jeep and many others are quite sensitive to
clogginbg with carbon, oil deposits, etc. Although in all probability
you haven't done any damage to the cat. conv. this is a good reason to
get as much diesel out as possible before attempting to start it.
If you take it to a shop and they want to drop the tank, etc. I'd
suggest to them using the pump to drain the tank. Like I say, I've
used this method many times with great success. You should be able to
find someone to do this for $100 or so. (Maybe less).
Feb 21, 2011 | 2006 Honda Civic Hybrid
Unleaded gas in a diesel fuel tank
do not worry about draining it, pour about 6 to 8 ounces of engine oil in it, and top it up with fresh fuel, it will be fine. The only way to drain the tank is to remove it and turn it over.
Apr 26, 2010 | 2006 Dodge Ram 2500
I but 3gals of gas in my 2008 ford 350 diesel is this going to hurt it, if so how can i fix it , maybe add something to it, i dont hgave alot of money!
Hi:
This sort of falls into the "it depends" answer, but how much diesel was in the tank at the time? The best answer is if you don't have alot of fuel in the tank, then try to siphon all of it out, and then fill the tank up with fresh fuel Even if you have to buy 4 plastic gas cans and a siphon hose, you could **** out 24 gallons of the mixed fuel, and put fresh back in
Regular gas will make a diesel run hot and ping.
Option B is to top off the tank with Diesel and hope for the best....
Nov 18, 2009 | 2008 Ford F-350
Accidently put gas in 1987 300d turbo diesel. what do i do?
You have to drain you fuel tank completely, and refill with diesel only.
Hopefully it didn't already cause too much damage to the glow plugs and engine in general.
May 12, 2009 | 1987 Mercedes-Benz 300-Class
Daughter put "diesel Fuel" into 2003 ford taurus. What's the best way to drain fuel tank?
the easiest way is to lift the car and unhook the fuel filter and cycle the fuel pump to push it out of the tank. you may have to cycle the key quite a few times to get it out but is easier than dropping the tank to empty it. if you crank the starter for a second the pump will run longer each cycle should get a couple gallons per cycle from the fuel line.
May 05, 2009 | 2003 Ford Taurus
Lands Phones Logo
76 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
