Question about Samsung Convoy Cell Phone
I have a samsung convoy flip-phone and the right side of the flip is loose due to someone stepping on it. The phone, screens, etc work just fine. How can I get the right side of the hinge back in pl
Obviously the ribbon cable is intact. How can I get it taken apart so I can get the right side of the hinge back in place?
SOURCE: samsung sgh-d807
I just finished disassembly and it wasn't that bad. Take off all four screws around the battery, then carefully but forcefully take the plastic casing off. Then, take the 2 screws on the main circuit board. That will reveal one connection for the ribbon cable, take that off. Under that is the backplate sliding mechanism of the phone. There will be 6 screws on this assembly, one of them under cable the connects to the keyboarb (bottom right). You will have to take off a green tape and also a gold padding to get to this final screw. After that is off, you will see the other half of the ribbon. Take that one off also, just yank it off. Install the new ribbon tape, make sure you don't rip it, and you're set. good luck. EE
Posted on Aug 11, 2007
  • 3 Answers
Remove battery cover and battery. There are four small screws visible on the rear cover, remove those. Wiggle and distort the back cover a little at the bottom of the phone until it pull partly free from the phone, slide a guitar pick or small flat blade screwdriver between the phone and the rear cover, at the side of the phone, pry this cover off until it snaps free. You will see the main board now. Remove the two screws holding this board on, carefully fold it back towards the battery area. The main ribbon cable is visible now. Remove a green tape on the socket where the ribbon cable joins the board. pull the ribbon away from the board gently and use a screwdriver or something else to cut the adhesive between the board and the cable. The socket has a hinged brown piece closest to where the cable comes in, that flips up to release the cable. The small cable coming from the number pad is removed by gently prying up the rectangular connector from the board. Now with the board free you can remove six screws from the plastic backing plate, and remove that plate from the slider assembly (one of the screws is hidden by a piece of green tape). On the front half of the phone there are six small screws on the rear side (the camera side). Four are visible, two are hidden behind rubber plugs at the top of the phone. Separate the chrome trim from the backing plate by starting at the bottom of the phone, by the key pad, and it may be stuck from a little day-to-day dirt but separate it there, then swing the bottom end out and release the front cover from the two clips that hold the top end together. You now can separate the ribbon cable from the screen assembly in a similar way as you did with the other end of the cable. Reassembly is the reverse of disassembly. Be sure to replace the pieces of tape, and the wire mesh shield attached to them, they serve to prevent radio frequency interference between parts of this device, and between this device and others.
Good luck, and happy dreams.
Posted on Dec 06, 2007
  • 3 Answers
SOURCE: frozen upstage phone by samsung
Try turning the phone off then wait a few minutes and turn it back on. If that dosen't work then you may need to reset the phone. Take out the sd phone and use an earing or something to press the reset button. Hold in for about 10 seconds. Hope it works!
Posted on Aug 14, 2008
Bajanguru
  • 7752 Answers
SOURCE: Samsung SGH-Z510 - problem
The phone need to be service professionally so take the phone to a mobile store and have that done.
ASFEI - try a hard reset *2767*3855#
Posted on Oct 05, 2008
  • 7 Answers
SOURCE: Samsung Convoy cell phone will
try the volume button on the side. the red bell means u have it on mute. otherwise find the profiles settings im using a rugby and they are in settings, profiles and adjust your ring volume in there
Posted on Jan 17, 2011
How do i get my phone to send pic messages it just says invalid destination address every time i try to send a pic message?
This is from the following link: http://www.verizonwireless.com/support/knowledge-base-83298/To
Take and Send a Picture via Messaging.
  1. From the main screen, navigate: MENU > Media Center > Picture & Video.
    Utilize the 5-way navigation pad to highlight and the center button to select.
  2. Select My Pictures.
  3. Select a picture then press the right Soft key to choose Options.
  4. Select Send.
  5. Select Picture Message.
  6. Enter the 10-digit mobile phone number or email address then select OK.
  7. Select SEND.
To send an existing picture this is from the following link:
Send an Existing Picture via Messaging Samsung Convoy Convoy 2
Send an Existing Picture via Messaging - Samsung Convoy™/ Convoy™ 2
  3. Select the picture then press the right Soft key to select Options.
  4. Select Send.
  7. Select SEND.
Mar 03, 2016 | Samsung Convoy Cell Phone
How do i get my bluetooth to work?
Turning Bluetooth On or Off
1. From the Home screen,
press MENU>Settings&Tools>Bluetooth Menu
2. Press the Left Soft Key (Turn On) or (Turn Off).
- or -
press the Directional Key RIGHT, highlight Bluetooth On/Off,
then press OK
from page 101 of your Phone's manual:
Samsung Convoy 3 (Verizon)
http://www.fgcu.edu/Telecommunications/Folders/samsung-convoy-3.pdf
>> If this was helpful in any way, please let me know so that I will continue helping others, by Clicking on the Helpful button below. Thank you :)
Dec 05, 2015 | Samsung Cell Phones
What is car icon on Samsung flip phone
Hi, Have you tried selecting the icon? Usually this will solve the problem. If you do not have a manual for this phone you can download one at the following site.
http://www.phonearena.com/phones/Samsung-Convoy_id3783/manual
Mar 03, 2015 | Samsung Convoy U640 for Verizon Wireless,...
Samsung convoy
If the phone got wet and the screen went out. That means there's water damage and the phone is fried.
Keep phones AWAY from water at all times. Water resistant or not.
Jan 10, 2012 | Samsung Convoy Cell Phone
I bought a Samsung Convoy. Trying to put new numbers in phone but will not let me change between house & cell symbol.
What do you mean? On my Convoy, I have the up and down arrows to add more contact numbers and when I display them in my directory, the right and left arrows to step between the numbers.
Carl
Jun 28, 2011 | Lands Phones
My Samsung Convoy does not have any sound in the earpiece, but in Speakerphone mode it works fine.
I HAD THE SAME PROBLEM & I'M SO HAPPY I FIXED IT !!! IF YOU HAVE TO HAVE A LITTLE COMMON SENSE AND HAVE A LITTLE KNOW HOW OF DISASEMBLEING & REASSEMBELING !!! REMOVE BATTERY AND 4 SMALL SCREWS ; TOP 2 ARE UNDER RUBBER PROTECTION PLUGS BY FLIP OF THE PHONE. NOT EASY TO GET OUT BUT I USED A MICRO (TINY SCREWDRIVER) THE WHOLE POINT IS ONCE DISASSEMBELED THERE IS A SMALL CONNECTION FROM THE HEAD PIECE TO THE BASE OF THE PHONE (VERY LOOSE ) AND A BLACK ADHESIVE PADDING THAT WAS MENT TO KEEP THOSE CONNECTIONS INTACT. GIVE IT MORE PADDING TO MAKE A CLEAN TIGHTER FITTING CONNECTION WHEN U REASSEMBLE YOUR PHONE !! THATS ALL IT IS ; IS A LOOSE CONECTION!!!! GOOD LUCK!!!!!!!!!!!!!!
Apr 26, 2011 | Samsung Convoy Cell Phone
Samsung Convoy cell phone will not ring in. screen shows bell with a red hash through it.
Jan 17, 2011 | Samsung Convoy Cell Phone
U900 samsung mobile phone main screen does not display everytime
The flex of your phone is getting weak or maybe it has loosed contact from the phone board.
The flex connects the screen and the phone board together.
It usually gets worn out the more you open and close the slide of the phone. This fault you are experiencing is usually common with Slide and flip phones.
The solution now is to loose the phone and check the flex if it is well fixed or is faulty.
If the flex is not well fixed, then should fix it but if faulty, you need to replace it.
If you cannot loose the phone yourself, give it to someone who can.
Best wishes.
Jan 02, 2010 | Samsung U900 Soul Cellular Phone
Samsung Convoy Cell Phone Logo
563 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
