I had the same issue twice (2 diffrent devices) on LG Blue-ray HX-906 - stuck on "please wait" after switching it on. It turned out to be defective mainboard - main BGA chip (the one with black radiator) has some problem with connection to mainboard. Here is how to repair it:
- dismount the mainboard
- take off the radiator from the main chip
- put alluminium foil around the chip to avoid unnecessary heating up of other parts of PCB
- heat up the chip using air hotgun to about 200 celsius for about 5 minutes.
This is likely to be an electrical fault. I would suggest contacting LG to see what can be done - if you have had the item for less than a year, they should replace/repair the phone for free.
Do you mean the network unlock?You can get the unique unlock code for your LG 3D Stereoscopic Phone(LG Optimus 3D P920) from Simpleunlocking.com and remove the network lock easily by following the free unlock instructions from Mobileunlockguide.com and remove the network lock very easily.
you need to be connected to a 3d source when you try and switch and it must be playing 3d media before the projector would even try and im sure you know you need to be connected via hdmi for this to work, so grab a 3d dvd player and a 3d capable hdmi cable and a 3d dvd and then try it--Good Luck.
Hi visit Mobileunlocksolutions.com to unlock your LG Optimus P920 3D mobile from network lock .Here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
