Question about Xerox Phaser 8400 Laser Printer
Phaser 8400/8500/8560 maintenance kit
While Xerox offers two separate maintenance kit part numbers for the Phaser 8400 and 8500 printers, they look identical. Can I use a 108R00675 maintenance kit (part for 8500 series) in the Phaser 8400? Has anyone else tried this?
  • Anonymous Mar 27, 2014
    It says "maintenance kit missing", even though the maintenance kit is inserted correctly.
  • 4 Answers
No, it will not work because the chip (CRUM) is not compatable.
Posted on Jan 13, 2009
ERROR CODE PHASER 8560 07,010.43:69551 Replaced Maintance kit
. they replace a certain number of pages printed by the manufacturer data
maintenance kits are easily user installable and come with a fuser assembly, transfer roller, and pickup, or feed/separation rollers.
Apr 11, 2011 | Xerox Phaser 8560DN Laser Printer
Shadow Printing on a xerox Phaser 8560. Have changed the Maint Roller and done the various cleaning cycles
The printer requires a maintenance kit. (95% chance anyways)
I would suggenst the extended life maintenance kit (10,000 page lifespan) part number 108R00676 to correct this issue.
You can usually get these where you get your solid ink cartridges.
Feb 25, 2011 | Xerox Phaser 8560DN Laser Printer
Xerox 8560 displays replace incorrect maintenance kit
Was this a new maintenance kit? If it was new, try putting the old one back in, if it reports the same message, the pivot plate will more than likely need replacing. If it displays the original message i.e, replace maintenance kit, then the fault is with the new maintenance kit. Do check you have been sent the correct maintenance kit for your machine, part number should be 108R00675 for standard and 108R00676 for the extended Phaser 8560 printer and Phaser 8560MFP kit.
If it is the original maintenance kit and the error just appeared, as I am assuming you will have already tried re-seating it, the problem is likely to be the pivot plate again.
Hope this helps.
Jan 22, 2011 | Xerox WorkCentre C2424DN All-In-One Laser...
What maintenance kits can I use in my Xerox Phaser 8560DN
Standard-Capacity Maintenance Kit - 108R00675 - 10,000 pages#
Extended-Capacity Maintenance Kit - 108R00676 - 30,000 pages#
Oct 06, 2010 | Xerox Phaser 8560DN Laser Printer
Phaser 8560 warns to replace the maintenance kit
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
Sep 26, 2009 | Xerox Phaser 8560MFP Laser Printer
XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Apr 07, 2009 | Xerox Phaser 8560MFP Laser Printer
Reset counter on Xerox Phaser 8200
I think the maintanance kit runs out based on time and usage, which ever comes first, roll back your printers clock a few months or more and see if that fix's the problem.
Oct 05, 2008 | Xerox Phaser 8200DP Thermal Printer
Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Jan 15, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8400 Laser Printer Logo
687 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
