White dots that move with screen when you touch tv
    New Friend:
  • 92 Answers
Manufacturer that they allow so many pixels to go bad in certain areas after some use
try if you can claim warranty
Posted on Dec 12, 2012
4 Suggested Answers
  • 1779 Answers
SOURCE: white dots on sumsung plasma tv
This is a problem is usually on your Y sustain board. There are two adjustments for this in which an Oscilloscope is nessesary for the alignment. However, there are two other things that can cause this also. This is beyond your abilities if your not a tech. Sorry for the news, It's not a major repair but should be done by a qualified tech.
Posted on Mar 17, 2008
roety
  • 585 Answers
SOURCE: White dots in plasma tv
The only thing you can try is to adjust the tiny control on the Y board, if you want to try do this. Open the set , set it up so you can watch it with the back off. now looking at the back on the left side you will see a circuit board larger connected to a smalled one or two that go to the screen edge . on the larger board look for a few small controls, mark their positions with a dark sharpy then turn each a little while looking at the dots to see if one makes them better or worse. If one control effects the dots try to center it for the least amount of dots, if no effect is observed when a control is turned return it the original position that you mark before starting. if the dots do not clear either the Y board is bad or the whole scfreen is defective.
gd lk
Eric
Posted on Aug 15, 2009
SOURCE: white dots on tv screen-HL=55686W
you should replace your old DMD, if i was right, it is 1910-6103W, but this model is very shortage, and expensive.
in the market, i only found some used one was sold, hardly get brand new.
Posted on Mar 26, 2012
My nevi 2595 shows only touch dot and will not do anything else. If you touch it the dot moves to another area on the screen
It looks like you are in the calibration mode ... just touch every dot and after a few times it will go back to the menu ... as usual.
Dec 24, 2014 | Garmin nuvi 2595LMT 5" GPS w/Lifetime Maps...
Cracked screen & white dots appearing since the crack appeared
I have a Mitsubishi TV and had the same problem. There is a mirror that moves to control each pixel. When some of them fail to move you get the white dots. Google your problem and a company will come up(sorry forgot the name).,you can buy the new part from them and they have exact utube videos to help you do the repair. Took me about an hour. Part was around $150. Very rewarding feeling when you turn the tv back on with no white dots.Still dot free after two years
Mar 16, 2014 | Mitsubishi MBS73A Base for WD73C9 WD73837...
My mitsubishi 65in tv has a lot of small white dots on the screen what causes this?
projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
Mar 07, 2013 | Televison & Video
Touch screen not responsive after speaker replacement It worked before speaker replacement.
To calibrate the touchscreen on a nuvi 300 or 600 series:
1. Power the unit On.
2. From the Where to? / View map screen, touch Settings (wrench icon).
3. Touch Display.
4. Touch Recalibrate.
5. A new screen will display that says Press Dot.
6. Touch the center of the dot.
7. Keep touching the center of the dot as it moves around the screen.
8. When Calibration Complete appears on the screen, please touch OK.
The touch-screen will now be recalibrated.
Nov 04, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
White dots all over the screen
White dots are due to bad DMD chip and qualified tv tech can replace required DMD chip in this tv to fix the picture issue.
Please contact nearest Samsung service center or local tv repair shop for repair estimate.
Thanks.
May 16, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
White dots and black on my screen
Are these dots moving with image or stationary under a moving image. This is a key identifier
Jun 23, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
White dots on screen
your dmd chip is defect this a good job you must tack emgine apart calculate atleast 200 dollars
Dec 06, 2008 | Samsung DLP HL-P5663W 56" TV
White dots on samsung S4266w
we have the same problem and now we're not sure what the heck to do. our tv is about 20 months old. i can't believe we have to get it repaired when we never touch it. EVER. now these dots are covering the screen, making it impossible to enjoy watching it. *annoyed*
laurie eller
Oct 22, 2008 | Televison & Video
Garmin c330
Try to calibrate the touch screen. Push and hold the power button on until you see a white dot on the screen. This is the calibration mode. Touch the dot and another dot will apppear, now touch this dot again, keep doing this until the unit reboot.
If you touch the 1st dot and nothing happens then the digitizer on the LCD is dead. If the unit is still under warranty, get a RMA and return it to Garmin.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
