I installed the converter box on channel 3 instead of channel 4
I already have my DirecTv on channel 3 and would like to install converter box on channel 4, can I delete the converter box from channel 3 ?
  • etdutton07 Jan 14, 2009
    Thanks for the help, it took only seconds to fix. I give you a 10 out of 10. Thanks again.
    Sergeant:
  • 227 Answers
No reason to delete converter box from channel 3. Most converter boxes have a selection switch on the back for channel 3 or channel 4. Slide switch to 4 and set tv to 4.
Posted on Jan 13, 2009
We have DirecTV and is is on channel 4. My
Use the tv remote to put the tv on ch 4. Use the direct tv then to select channel of the direct tv box. The box is broadcasting to the tv on ch 4. Also check that tv is on correct input . Again use the Panasonic remote to select correct input. If this does not work call direct tv for assistance.
Dec 03, 2009 | Panasonic TC-32LX60 32 in. LCD Television
I have an older Sanyo (approximately 8 years old) and my remote control is damaged (only the buttons/controls on the right side are working, volume turns up but not down, most of the left keys do nothing)....
If you are feeding the signal from your digital converter into the TV antenna input, I would input the converters signal to the TVs video input instead. I am assuming your converter has a video output signal and left & right audio so you will need cables for your audio also. If your converter has only rf output for the TV tuner input it is generally on either channel 3 or 4 and there may be a switch to set this. It is possible that when the TV scanned for channels the converter was off and it did not find a signal on 3 or 4. If you can get the TV to re-scan, be sure the converter is turned on and on an active channel. All your channel selection should be via the converter after that and the TV simply stays on 3 or 4. I would suggest looking in to getting the original remote. Try partstore.com and see if they have one for your model.
Nov 18, 2009 | Sanyo DS27930 27" TV
No welcome window, set up menu from Insignia converter box.
Make sure your TV is tuned to channel 3. If you don't see a picture from the converter box change the TV to channel 4 and check for the converter box output. If you continue to have a problem with the installation, the FCC has a hotline to help solve setup problems. They can even arrange for someone to come help with the setup at no charge to you. Call 1-888-CALL-FCC.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
Apr 09, 2009 | Quasar VHQ400 VHS VCR
How to hook my directv to digital input to lcd tv j32l637
I don't know what flat screen tv you have,but you must be aware of the coaxial input behind the TV.It could be analog input,digital input and OUTPUT!!
Anyway,if you connect your basic directv box to your digital input,it will not serve you any purpose to get HD channels and you don't have the HD directv box.The TV will not display digital channel for you because if you use coaxial input to TV,you should be under either channel 3 or 4 and be sure either channel had been saved under memory.In order to change channels,you will need to change it from your directv box.
JUST LIKE a VCR connect to TV.TV will be under channel 3 or 4,and you will change your channels from the VCR.Don't forget to scan all the channels from the VCR!
solutiondoct
Nov 11, 2008 | Televison & Video
Digital conversion tv no color
if it is connected with coax cable i would first try removing the cable and reinserting it, try putting the channel switch on 3 instead of 4, or 4 instead of 3, if this does not work try a different coaxial cable
Aug 06, 2008 | Televison & Video
Dvd player/recorder DRW 500 does not pick up channels after installing DTV converter box. it will record directly but can't be set for timed recording because it did not find channels
You want to set the recorder timer to record the out put channel of the converter box (either 3 or 4 ) then tune your converter box to the channel you want to record, and leave the converter box turned on until you are done with the timed recording.
Jun 30, 2008 | Televison & Video
Insigna ns-dxa1 converter
You might try useing a higher bandpass diplexer
Apr 24, 2008 | Audio Players & Recorders
Hi
Have questions about your upgrade? We've got the answers. What do I need to do to receive my upgrade? Nothing! Just make sure your DIRECTV HD DVR is continuously connected to your land-based phone line and you will receive the upgrade automatically. When will I receive my upgrade? The 6.3 software upgrade will roll out over a period of several weeks. Customers with more than one DIRECTV HD DVR may receive their upgrades at different times for each receiver. We appreciate your patience while we deliver these new and improved features to eligible DIRECTV HD DVR customers nationwide. Are all DIRECTV DVRs receiving this upgrade? No. DIRECTV DVR models SONY SAT-T60, PHILIPS DSR6000R and HUGHES GXCEBOT will not receive the 6.3 software upgrade. Other models received a similar upgrade, 6.2, in the past. I have a DIRECTV R10 DVR with 6.1 software. Will I receive this upgrade? No. The 6.1 software on the DIRECTV R10 DVR already includes the 6.2 features such as folders and faster menu scrolling. Will any of my DVR settings be changed as a result of the upgrade? Yes, some of your settings or preferences will be changed back to the factory default settings as a result of the upgrade. These include: "Favorite Channels," "Channels You Receive," "Spending Limits," "Clear Channel Banner Quickly" and "Dolby Digital" recording and output. To change Channel Banners, Channels You Receive and Favorite Channels preferences: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Channels" To change Spending Limits: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Parental Control" To change Dolby Digital Settings: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Audio" 4. Select "Dolby Digital" and "Digital Output" Will I be charged for this upgrade? No. We're upgrading your DIRECTV HD DVR as part of your normal DIRECTV® DVR with TiVo® service at no additional cost. What happens if I don't have my phone line plugged into my DIRECTV DVR? You will not be able to receive the upgrade if your DIRECTV DVR is not connected to your phone line. To install the upgrade, your receiver must successfully make a call to our servers. How will I know when I have received my upgrade? You'll receive an on-screen message the first time you visit DIRECTV Central after your upgrade is complete. It will also appear in your Messages section. You can also check your System Information screen to find out which software version you currently have. Will the download delete any of my currently saved programs? No. All of your saved programs will still be there for your enjoyment after the installation. Once your upgrade is complete... How do I activate the Grouping (folders) option? 1. Go to your Now Playing List. 2. Press Enter on your remote control. 3. Change groups to ON. SHORTCUT HINT: While viewing your Now Playing List, press number 2 on your remote control and your Now Playing List will change from the GROUPS view to show each individual recording. Press 2 again and it will switch back to the GROUPS option. How do I sort alphabetically instead of by date recorded? 1. Go to your Now Playing List. 2. Press Enter on your remote control. 3. Change sorting option to Alphabetical. SHORTCUT HINT: While viewing your Now Playing List, press number 1 on your remote control and your Now Playing List will change from alphabetical to date sort. Press 1 again and it will switch back to alphabetical sort. Some settings will restore to factory defaults when the new software is download
Aug 19, 2007 | RCA DRD485RG DirecTV DTV Receiver
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
