Question about Insignia Digital-to-Analog Converter for Analog TVs
NO SIGNAL on Magnavox TB100MW9 converter
I just hooked up my Magnavox converter for DTV and I get a sign NO SIGNAL. Do I have to wait for Feb 17 to get the signal? I hooked it up to an indoor antenna (rabbit ears) as specified..
  • jerrymoorehe Jan 13, 2009
    Thanks for your help! I wonder why they don't tell you this up front?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 62 Answers
Rabbit ears are not strong enough to pik up the digital signal. You need to buy a DIGITAL antenna. You can pick a powered one up at Wal-Mart, or any retailer for around 20 bucks. Once you have the proper type of antenna, go through the setup sequence again and then you will be in the "digital age". You will wonder why they didn't do this sooner!
Posted on Jan 13, 2009
Tip
Magnavox TB100MW9 DTV Converter repair
After a close-by lightning strike, my Magnavox TB100MW9
Digital TV Converter box stopped working. I took it apart and found a
shorted diode (the fat one on the power side of the board)
marked with the number SB340. From the NTE cross-reference
web site, I found a replacement diode, NTE586 (Si, Fast
Switching, Schottky Barrier Diode) that cost me $2.40 at
a local electronic parts store. I replaced the diode and
it works fine!
on Apr 27, 2015 | Magnavox TB100MW9
Dtv converter box digital analog signal
If you do not have a control number for the box as listed by the Remote Manufacturer; then you may try contacting RCA directly.
Dec 12, 2013 | Magnavox TB100MW9
It is likely the converter will have to be replaced
Jun 18, 2013 | Televison & Video
Tb100mw9 dtv converter I cannot access setup wizard.
Unplug,replug the converter box back like about an hour later.The box will resetting itself back to the factory setting,should able to bring up setup wizard than.
Jun 06, 2011 | Magnavox TB100MW9
Magnavox 20MF500T/17 will not interact w/NHENS DTV Converter box
The tv just needs to be set to channel 3 or 4 to pick the signal up from the converter box.
Jan 10, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox DTV converter shows no signal
do you have your converter box hooked up to an antenea? If so, if you move the antenea, then you may have to reprogram the channels through the converter box. This happened to us. So, we played around with the antenea until we found the most channels came through and marked the area around the antenea (you can use tape, or if you do not care a permanet marker like us. Note our antenea sits on top of our tv.) We have not had any trouble since. We marked the place for the antenea, in case someone moves it or so we can try to get more channels when the final switch happens. We gain a lot of stations, but lost only one.
Hope this helps,
The Gordons :)
Jan 06, 2009 | Insignia Digital-to-Analog Converter for...
I just bought a MAGNAVOX DTV TB100MW9. Before hook-up,we fot channels 4,6,10,20. After hook-up, all I am getting is 4 PBS channels. Why i have a dtv converter box the set up menu does not come up to...
connect the cable box to your tv using the audio/video cables
yellow -red-white
to the same colors on the rear of the tv.
switch the the input to audio/video 1 2 or 3
which ever one works.
Thanks guy9
Jun 17, 2008 | Televison & Video
Insignia Digital-to-Analog Converter for Analog TVs Logo
419 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
