Question about Bose Wave Radio
120v Bose Wave Radio/CD player plugged into 240V outlet
My wife plugged her 120V Bose Wave Radio/CD directly into a 240V outlet in Ireland instead of into the step down transformer. Is there an inline fuse to protect the transformer inside the Bose? If not, any idea of the likely extent of the damage?
  • gatlinj00 Feb 03, 2009
    I have the same problem, but in China. If it is a fuse, is there a manual or other documentation that I can access in order to determine how and with what to replace it? Thanks.
  • 22 Answers
There is a fuse you can check. Also a rectifier bridge, a 3 terminal regulator IC (18V in, and 10V out) as well as a small transistor Q1 which often shorts. Easy and cheap fixes, or I would offer to buy your non-working model Bose if you decide to sell it.
Posted on Jun 30, 2009
    Problem Solver:
  • 16 Answers
There is a fuse inside but after changing the fuse if it still dont work the rectifier could be bad.
Posted on Feb 02, 2009
There seem to be no power. Nothing is on. I change the 9 Volt battery and still nothing is on. No radio, No clock. For a Bose clock radio. David Fong
Sorry for the late answer to your solution. There was some problem with my account in fixya.
I was not able to post any solution from yesterday as the new site is in development stage as told by the customer care of fixya.
I seen your question. You have to check the power cord of your bose wave radio first. Is there is any loose contact at its socket at the both ends. If its seems ok, Then you have to check the inline fuse inside the wave radio. For that you have to open the wave radio. I am giving you this solution assuming that you are aware of reparing electronic items. If you have some knowledge on fixing electronic items then you can fix it yourself.
Before removing the wave radio remove the power cord from the sockets. There will be 6 screws at the bottom of your wave radio in some models its 8 numbers. After removing the screws turn the radio and pull out the top cover. You can see the inline fuse near the AC input socket where you connect the power cord. Using a multimeter test the contnuity of the fuse. it should show zero ohms. if no, then the fuse is faulty remove the fuse and replace with a new one and power up the radio and check
If there is no other fault the wave radio will work ok. If the fuse blows again then the transformer of your wave radio is faulty. The primary winding of the transformer have some short inside. As it is a custom design the C core transformers are only available through bose service centers. If they are willing to supply the transformers to customers then buy it from them and replace yourself. If not, then you have to give the radio to them to be repeired. If you need any more assistance feel free to conatct me through fixya.The fuse will look like one in the picture.
Dec 05, 2011 | Audio Players & Recorders
Is it possible to buy a 220-240V transformer for a Wave awrcc1 to swap out the 110V one?
The simplest thing here is to buy a plug adaptor. Sold at many electronic stores.
Radio shack, The source, ....
Nov 24, 2011 | Bose Wave Radio
Bose radio will not turn on. I have a Bose Wave radio, model AWR1-1W, D.O.M. 980305, that will not turn on. I've verified that there is power to the radio (checked outlet plug of cord). I've looked...
I have the same issue with the same model. I found an open primary winding in the large transformer inside the unit. Now the problem is finding somewhere to buy the transformer...
Sep 19, 2010 | Bose Wave Radio
Following a direct lightning strike to our pole transformer, transformer blown ,, replaced ,, several electronics not working including our Bose Wave Radio (no CD) ... Where can we find repair and how much...
Bose does not release their schematic diagrams or parts lists, so factory maintenance is about the only way to go. You can start the process by visiting www.Bose.com, but be ready for some sticker shock. Before you do anything though, every Bose has a line fuse inside the case. The location varies by model and date of manufacture, but if you open the case it will be simple to locate. Check it, and replace it if necessary. The fuse is there to safeguard electronics against power surges, so it is your likely culprit.
Bill B
Aug 01, 2010 | Bose Wave Radio
Can my bose wave music system 240v work in canada 110v
No, you need a step up transformer, (110V input 240V output)
Jul 24, 2010 | Bose Wave Radio
Cdj 200s bought from america not working. they have american plugs on at 120v. i have tried an america to uk travel plug and 240v to 120v stepdown transformer but this has not resolved issue....... would...
Yes, fuse may be blown, first check out the fuse of CDJ,
if it does not work. Install a physical 120v American transformer
also change the switch of 240v to 120v from back of CDJ
thx,
djajay
Feb 07, 2010 | Pioneer CDJ-200 CD Player
WAVE radio transformer bad ???
If you can check ohms,you can also read volts. Open the radio again and look for DC volts on the rectifiers capacitors.They look like :cans", normally the color is blue. Check for positive dc v. against chassis ground. If no + tension,your rectifier or your secondary are open.
Aug 24, 2009 | Bose Wave Radio
Transformer secondary out ???
please my name is dele i have this BOSE radio/cd system model number is AWRC2G which transformer burnt out rightly, that the input is 240volts which output is the problem and in nigria. please i just want to know the output on each coloured wire of the secondary that has 8 wires output from the secondary (2 purple - brn = volt, 2 blue = volts, and 2 black - gray = volts. so that similar that i can use to work it.
thank you
I gave the Bose Wave Radio and 3-cd player to a friend for
Unplug and plug back in. It should go through a automatic process, ejecting any discs that are inside. If all you hear is a mechanical noise, try this again only with the disc trays facing the ceiling.
Dec 29, 2008 | Bose Wave Radio
AWR1-1W
It will Blow up :D Short out the transformer with some nice smoke out the back, its a very expensive machine and i wouldnt advise that.
Dec 02, 2007 | Bose Wave Radio
Bose Wave Radio Logo
1,006 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
