The climate control panel in my 2000 Buick regal LS doesn't light up. It works but it will not display anything. I tried changing the fuses and it didn't help. How can I fix this?
    Sergeant:
  • 462 Answers
Check your manual if nothing there im afraid a dealer may have to check it
Posted on Dec 12, 2012
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: aircondition will not work sometimes
Is there any error code?
Posted on Jan 12, 2011
97 Buick Regal climate control
Hi Levi, Im AL the owner of Big As Auto Repair.
Levi, If you have the same climate control, then below is a link to a repair video for your climate control. Sorry, this is the part 3 video, look a the side to find the part 2 video and watch it first.
1997 03 Buick Regal climate control display repair part 3
Jan 09, 2015 | 1997 Buick Regal
I have a 2003 regal LS w/auto light control. When headlights come on I have no rear parking lights and no dash lights and the radio and transmission indicator don't dim. Same result if you turn th
Since these lights will work auto or manual is there a relay that might be bad. You mean these light's won't work auto or manual ????
Did you check the TAIL LAMP LIC LAMP fuse 15 amp . ?
Located in the right I/P fuse panel open passenger door plastic panel end of the I/P pull ,fuse box behind . This fuse takes care of the thing's your having problems with
Aug 18, 2017 | 2003 Buick Regal
I have 2000 regal and the lowbeam headlights do not come on anymore and when i try my highbeam ,i have to hold the lever back for them to stay on
Have you figued out the problem? I have exactly the same problem with my 2000 buick regal LS
Now the headlights are working at all - all the fuses tested fine - high beams lights do turn on when I pull the switch
Jul 07, 2011 | 2000 Buick Regal
I have a 2000 buick regal none of my dashbord lights work and the lights for the radio and heat,fuses are all good
The first thing you want to check is the panel light dimmer control on the headlight switch. Make sure it isn't turned way down.
Apr 10, 2011 | 2000 Buick Regal
My automatic climate control system reads in Celsius and I want to switch it to Farenheit. 2003 Regal LS How please?
is it a canadian car?...I have a canadian regal..if i unplug the instrument cluster, guess what..my climate control changes from Celcius to Farenheight. When i plug it back in...it goes back to canadian eh..so.im thinking you need a US instrument cluster (ie..miles not kilometers).to make the climate control stay in farenheight....awaiting your feedback
Dec 19, 2010 | 2003 Buick Regal
2000 buick regal L.S. electrical problems.
check body control module fuse . check head light relay and the drl lights relay.
Apr 25, 2009 | Buick Regal Cars & Trucks
NO LED Read out for Dual Automatic Comfortemp Climate Control
This is a chronic problem on the LCD display for Buick Century/Regal cars with the climate control HVAC system. The problem is most often some of the resistors on the PCB will get a "cold solder" joint and need to be fixed by remelting the solder and adding a bit more fresh solder. Remove the unit from your dash and inspect all the solder joints. Chances are you'll see one of them that is "loose."
Mar 23, 2009 | 1999 Buick Regal
AC quit working.
Please ensure the system does not have a leak or that the compressor clutch circuit have failed. These two areas are less costly to diagnose then the climate control module you are to replace.
The front facia panels are secured with clips and some screws careful removal will safe the clips for reuse. Good luck!
Jul 08, 2008 | 2000 Buick Regal
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
