Question about Compaq Presario Notebook
No boot of laptop
I press the power button of my laptop but it doesn't boot
  • Peter Conway May 11, 2010
    What make and model?
    Which Windows ?
    Is there an error message?
    Please post these details and I can help
    thanks
    Problem Solver:
  • 82 Answers
Dnot press gently try a little harder if still problem persist contact ur nearest service station.........................Sameerayan
Posted on Jan 14, 2009
How can I tell if a power surge hit my laptop and ruined it? I can't even get it to boot up
It could either be that the motherboard is fried or the Hard drive has just gotten slightly corrupted. If you have the Windows install disk that came with it you could boot that up and then go into repair mode (press R) and then run "chkdsk /r" this would fix a hard drive issue. However if your laptop will not turn on at all when you press the power button then it is likely dead.
Nov 07, 2012 | Computers & Internet
Acer 5742g Beep at boot up
I have a problem that looks like this one.
At boot up, after the POST, each time the HDD led blinks, the laptop produces a loud "beep", and refuses to boot, as if this phenomenon prevented the HDD to be read.
If I press the power button, it stops beeping. When I release it, it starts beeping again.
If I press F8 at the beginning and then ask for a normal boot, It boots normally. Anyway, in windows, I have some strange activity, like I would continually pressing Alt+Tab. If I press Esc, it stops immediately and then all seems to work fine.
Any clue?
Jul 26, 2012 | Acer Aspire 5742G
Toshiba satellite C655 laptop has black screen with blinking cursor. It did complete some Windows updates. I was on the Internet then my laptop just shut down and it in this black screen with blinking...
Turn the computer off all of the way by holding in the power button until it shuts off.
Turn it back on and immediately start tapping the F8 key. It should bring you to a menu that has an option for going to "Last Known Good Configuration". Choose that option and see if it boots up.
If pressing F8 doesn't bring you to the menu - you may need to run diagnostics on the computer. To get to the diagnostics, attempt to boot to the Boot Menu by pressing F11 or F12 at the boot screen and see if it gives you the option to run diagnostics.
Nov 15, 2011 | Toshiba Computers & Internet
Acer zg5 will not boot
First remove the battery, make sure it is unplug, and press and hold the power button for 30secs. Than put the batty back in and see if it helps. If this doesn't, try removing the hard drive and memory and see if it turns on. If not than the motherboard is dead.
Also, when you say doesn't boot. Does it turn on?
Jul 03, 2011 | Computers & Internet
Toshiba Satellite laptop will not boot. Shows power from outlet and battery but no indicator light is present for the last two in the five light sequence.
Its an old trick that got my Dell laptop working
Unplug the laptop remove the battery press the power button,...nothing will happen, wait a few seconds put battery back in laptop plug it in hold upside down press power button until it boots
If that doesn't work it could be a bad/loose/dead bios battery What is the model of the laptop?
May 11, 2011 | Toshiba Computers & Internet
Dell inspiron m5030 wont boot up, ac adapter has green light then once it is pluged in light goes out.
Try a hard reset. Sometimes it works and is always the first step to take.
Remove the battery and the ac adapter plug from the laptop.
Press and hold the power button for forty seconds.
Install the battery and ac adapter .Now press the power button to attempt a boot into the OS.
If that doesn't work then remove the hard disk to see if it gets past the splash screen and the BIOS whines that it can't find a boo-table OS. That would indicate a hard disk failure.
Also try to remove the memory module(s) from the DIMM slots and then reinstalling them. That reset the modules and cleans some oxidation off the module pins (if there is any)
Hope this helps.
Let me know if you need more information
Thanks
Apr 26, 2011 | Dell Inspiron M5030 Laptop
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
I have hp6735s dark screen problem even with external monitor
Try removing the battery and see if it starts. If the battery is dead, the laptop will be unresponsive as you described. If this doesn' work, then switch out the power adaptor. You can find these on eBay for less than twenty dollars. Your laptop is not getting adequate power to boot up.
Oct 15, 2009 | HP Computers & Internet
Compaq Presario Notebook Logo
75 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
