Question about Microsoft Windows XP Home Edition English for PC
0x0000008E (0xC0000005,0x805D946E,0xF78032FC,0x00000000) Blue screen STOP 0x0000008E (0xC0000005,0x805D946E,0xF78032FC,0x00000000) Doing this daily when computer left unattended for a while. Seems to be fine while it's being used.
  • Microsoft Master
  • 2,878 Answers
Remove all USB attached devices like drives. You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode. To eliminate possible bad RAM. Unplug PC, open case, and remove all RAM. Test one DIMM at time, one slot at a time. Re-install Windows. Clean install works best, but all data will be lost. Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Posted on Dec 11, 2012
pcblogger
  • 44 Answers
SOURCE: stop error
Visit this post on microsoft to resolve your problem.Your RAM may be the cause of the error.
Posted on Aug 22, 2008
SOURCE: windows xp quit loading blue screen says
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windwos " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Posted on Jan 08, 2010
mirzausman
  • 129 Answers
SOURCE: Blue screen on boot up. ***stop: 0x00000024
It is because you have installed a wrong driver like sould/display and USB smart card most cases reported are when you install wrong com port driver.
Otherwise its a RAM problem. Please open your case and then clean the RAM. Remove any newly installed hardware and retry.
Posted on May 12, 2010
  • 107 Answers
SOURCE: stop: 0x00000024 (0x00190203, 0x82F95248,
Try a restore point.
If your problem persist check you RAM memory.
Thanks
Posted on May 27, 2010
  • 8 Answers
SOURCE: when I shut down windows xp it restarts I stopped
Click on my computer.
Right Click on the C: drive.
Choose Properties.
Tools tab.
Error checking: Check now.
Choose automaticly fix file system errors.
Start, Yes, OK, Reboot the PC.
On boot a blue screen will launch and run for 5 - 20 minutes.
It wll reboot into windows when completed.
Posted on Sep 27, 2010
Stop 0x0000008e (0xc0000005, 0x8054BAB4, 0xF43c3844, 0x00000000) beginning dump of physical memory physical memory dump complete
you need to reinstall your windows, because your computer problem is dumping disk that cause your windows corrupt
i hope this helpful
thank you for using fixya
Feb 11, 2011 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Pc blue screens with 0x0000008e (0xc0000005, 0x807019uf, 0xaa7ff48c, 0x00000000) after reboot goes into safe mode boot option. Selecting xp pc boots normally. repeated reboots pc works fine. But if left...
STOP 0x0000008E errors are usually caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Download and run from a floppy or CD MEMTEST86 at
http://www.memtest86.com/
Aug 05, 2010 | Evesham Evolution PC Desktop
System is wont boot
Getting 0x0000008e is surely a signal that your registry is corrupted. What you need to do is to fix 0x0000008e as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don’t fix 0x0000008e, this potential risk will bring you more troubles, Even system crash.
Cause of the problem would be.Mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause 0x0000008e.
Heres how to fix the issue
Download the software fix by clicking here.
Launch it after finishing the installation.
Click “Scan Now” button
Click “Repair Problems” button and fix 0x0000008e.
May 21, 2010 | HP Pavilion dv6000z Notebook
Can only start pc in safe mode keeps doing windows inconsistency check. Seems to be on loop. Blue screen shows Tech info stop 0X0000007F (0X0000000D, 0X00000000, 0X00000000, 0X0000000. Windows XP. Please...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 15, 2010 | Computers & Internet
My main computer has stopped working. it is displaying a fatal error blue screen with code numbers at the bottom these seems to be problems with the registary stop: 0x00000024 (0x00190203,0x807ae0b0,...
BSOD - blue screen of death....sorry mate but its seems that a fatal error on your operating system occured....most probably a sure way to fix this is to re-install windows, and lose everything on the hard drive...
Feb 15, 2010 | Computers & Internet
Windows xp home does not boot
Replace the HDD.
You don't want your precious data on that drive.
Nov 08, 2008 | Maxtor Hard Drive
Dell Dimension 4600 Blue Screen
Usually this blue screen appears due a hardware issue or drivers conflict.
1) Try to boot in safe mode (hit F8 after starting up) and select "Safe mode"
If you don't get access try doing this:
2) Run the OS CD and use the option Recover Console (R)
This will fix the problem.
3) If the problem continues, you will need to install the OS again.
Oct 07, 2008 | Computers & Internet
Installing windows xp
http://support.microsoft.com/kb/315335
go to tht link it states ur problem and a perfect solution
pls rate my answer if i helped at all
Sep 22, 2008 | Computers & Internet
Computer will not start
When Windows crashes with blue screen, it writes a system event 1001 or 1003 and a minidump to the folder \windows\minidump. Check system event 1001 and 1003 and it has the content of the blue screen
Event ID: 1001
Source: Save Dump
Description:
The computer has rebooted from a bugcheck.The bugcheck was : 0xc000000a (0xe1270188, 0x00000002, 0x00000000, 0x804032100).
Microsoft Windows..... A dump was saved in: .......
Event Source: System Error
Event Category: (102)
Event ID: 1003
Description:
Error code 1000007f, parameter1 0000000d, parameter2 00000000, parameter3 00000000, parameter4 00000000
Control Panel -> Adminstrative Tools -> Event Viewer -> System -> Event 1001/1003. Copy the content and paste it back here
Aug 17, 2008 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Microsoft Windows XP Home Edition English for PC Logo
83 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
