Question about Kenmore 54501 Dehumidifier
Dehumidifier Kenmore 580.54501
Where can I buy a drain hose connector? Can't find on sera parts list. Thanks! Paul
Hose connector is Sears part # 5214A20027A
dehumidifer is Model # 58054501300 or 58054501400
use these numbers on searspartsdirect.com
Posted on Jul 29, 2008
Go to a Sears Authorized store and you can buy one there.
Posted on Jun 16, 2007
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
Drain hose connector
Check with a local Sears store. They specialise in Kenmore appliances and can maybe order one for you.
Sep 29, 2013 | Kenmore 54501 Dehumidifier
Kenmore 407 50 pint dehumidifier won't drain through hose
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Oct 13, 2012 | Kenmore 90701 70 Pint Dehumidifier With...
Kenmore Dehumidifier Model 580.54501800 is collecting water in machine when drain hose is attached
Aug 15, 2012 | Kenmore Dehumidifiers
The water fills the bucket and bypasses the hose I have attached wich should just empty the water into a drain.
Paul, there is a clog either in the hose or in the connecter tubing you have the hose connected to. Use an 18" long plastic Zip Tie (or something similar. NO wire cost hangers, though) that will fit into the hole at the hose connection. Carefully insert it into the hole and work in until you reach the bend of the tubing. Here's the tricky part, as you have to work it past this bend. Once you do and the Zip Tie bottoms out or you run out of Zip tie, slowly pull it back out, while rotating it. This will loosen any clogs, so be prepared for water to follow.
Also. keep in mind that the hose should be no longer than 5'. As the dehumidifier relies on gravity to drain the water through the hose.
Hope this helped you to solve the problem. Please let me know. Thanks.
May 23, 2011 | GE Ader50ln Dehumidifier
My dehumidifier runs over or leaks is there a way to plug into a hose to see if that takes care of the problem
If you purchased the dehumidifier new, it would have come with a part called a connector drain hose. This part is a long plastic tube with threads on one end to accept a hose. The part simply slides into the rear of the machine (with the threads of the part facing the rear). If you dont have the connector drain hose, it's part number is 5214A20027B and you can easily order it online for less than $10.
Jan 18, 2010 | Kenmore 54351 Dehumidifier
Do I need an attachment to connect hose to my new dehumidifier?
it should be generic. you just need a part with the same thread pattern. you could fix that a lot of different ways. as long as it screws in your ok. make sure you put some teflon tape on it to prevent it from dripping
Oct 06, 2009 | Kenmore 54501 Dehumidifier
Goldstar dehumidifier
The hose connector does not drain the bucket, it drains the condensate before it enters the bucket. Tube passes through back of dehumidifier by the cord wrap area. (you may have to remove a small cover)
Aug 25, 2008 | Goldstar DH504EL Dehumidifier
Clean the hose (it's full of black gunk)
Jun 30, 2008 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier Logo
1,222 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Marvin
Marvin
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
