Question about HP Pavilion a1514n (EX269AAR) PC Desktop
Pc turns on but there is no sound
When i connect my speaker there is no sound and the volume is full.
  • HP Master
  • 2,878 Answers
Check with headphones to make sure you even have sound.
Right click My Computer > Manage. Select Device Manager Do you have any Unknown Devices with warnings! Installing or upgrading the drivers might resolve.
Posted on Dec 11, 2012
My levono C460 system sound is off so no sound what can i do?
Hi
3 possible solutions:-
• Adjust the Windows volume control - select the speaker icon from the Settings Charm or click the arrow on taskbar to show the hidden icons in Windows desktop mode, then click the speaker icon. Ensure that the volume is turned up and the sound is not muted. Adjust the volume, bass, or treble controls to eliminate distortion.
• Reinstall the audio driver.
• Disconnect any headphones from the headphone connector - sound from the speakers is automatically disabled when headphones are connected to the computer's side-panel headphone connector.
I also give a link below to a page from which you can download the full manual for future reference.
Desktops and all in ones Lenovo Series all in ones Lenovo C460 All in One...
Cheers
Oct 26, 2014 | Computers & Internet
Why am i not getting any sound out of my lap top computer?
Try to connect an audio system or headsets from the audio/headset input. If there has sound coming out?. The speaker of your PC was damaged. If did'nt hear any sound? Update the sound driver.
Aug 26, 2014 | IBM ThinkPad Computers & Internet
Cable for phillips subwofer computer system not working. Is there a replacement i can buy
switch on the speaker system remove the jack connected to your pc.give full volume / off volume,
just touch the jack pin from your finger.check the sound is coming.
if sounds well your speaker is ok.problem with pc.
if not in woffer ic has to be replaced.
Nov 07, 2013 | Philips MMS171 Computer Speakers
There is no sound in my pc
Some possiblities are:
* The sound is muted or turned down to zero. (This can often be controlled from the keyboard; for Windows 7, try the control panel > sound > adjust system volume).
* Speakers aren't connected, are turned off or are set to zero volume.
* Speakers are broken (least likely).
May 09, 2012 | Dell Latitude D610 Notebook
Speakers are hooked up but no sound
maybe they have the volume muted. Check to make sure the volume is not muted and that the speakers are plugged into the light green port in the back of the computer.
Make sure the volume on the physical speakers are turned on and turned up. And make sure the volume in the Audio Sound Properties it turned up and not muted.
If you see the speaker megaphone at the bottom right near the time click on it to adjust the properties.
You can click Start/Control Panel and look for Sound or Audio properties
May 02, 2012 | ASUS Essentio Desktop with Intel Pentium...
Low sound output from speaker
Hi tabrezansari,
I have an aspire acer 4741 series laptop. I always turn my sound volume to the max (Fn key's + arrow UP).
But if you encounter too low sound, you double click on the speaker icon in the lower right hand, it should bring up the mixer volume menu. Make sure none of the 'mute' buttons are selected. Also check the sliders to full volume or whatever is confortable for you.
Hope it helps.
Thank You for using Fixya.
Sep 06, 2011 | Acer Aspire One PC Notebook
The sound in the left speaker goes on and off on rough road. turn the volume up to max it works. Turn down 2-3 and no sound
IS A LOOSE WIRE CONNECTION TO THIS SPEAKER ---- WHEN ON FULL VOLUME THE HIGHER CURRENT COMING TO THE SPEAKER KEEPS IT PLAYING .......
CHECK THE CONNECTION ON THE BACK OF THE SPEAKER ---- MAYBE UNHOOK AND RECONNECT AGAIN ......... IF NOTHING CHECK THIS SPEAKER CONNECTION AT THE
STEREO REAR .............. YOU WILL FIX THIS
Jun 29, 2011 | Car Audio & Video
I can use headset but my pc has no external sound
TRY CONNECT THAT SPEAKER TO OTHER COMPUTER FIRST. THEN ALSO CHECK-UP POWER ON LED , VOLUME CONTROL AND AC PLUG.
May 27, 2011 | Audio Players & Recorders
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
HP Pavilion a1514n (EX269AAR) PC Desktop Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
