Question about Whirlpool GS6NBEXRL Side by Side Refrigerator
Water is leaking under Whirlpool refrigerator
  • 198 Answers
SOURCE: Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Posted on Jan 05, 2009
  • 531 Answers
SOURCE: My whirlpool refrigerator W-21 model #
clogged drain
Posted on Apr 01, 2009
SOURCE: Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
Posted on May 13, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
toolkits
  • 1099 Answers
SOURCE: My Whirlpool refrigerator is leaking and water is
On a top-freezer when the drain stops up water will back up turning to ice and eventually filling the air ducks with ice blocking airflow to the fresh food section causing it not to cool. You will also see a water leak inside the fresh food section. To fix this, remove the evaporator cover, (back or bottom of freezer) and then remove all the ice. Once all the ice is removed, you need to unclog the drain. I do this by forcing hot water down the drain with a turkey baser but you can use any squirt bottle, I have even used the water hose. Once the drain is clear, mix water and baking soda and pour it down the drain to prevent this from happening again anytime soon.
Hope this helpout,
Posted on Jul 28, 2010
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Auto defrost works fine except for water accumlating in the bottom of unit under the bottom trays instead of in the water tray by the compressor. graywolf7499@yahoo.com
There is a leak or damage of the pipe leading from the evaporator downwards.The defrosted water is leaking out of the tubing to the bottom,replace this tubing or check the leak on the collecting tray under the evaporator.
Sep 30, 2010 | Whirlpool Refrigerators
I have a whirlpool imperial refrigerator; freezer on top; with icemaker....water is leaking from the freezer section down onto top shelf in refrigerator, near back, any help??
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. This is all you need to do....
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 10, 2010 | Whirlpool Refrigerators
My refrigerator leaking water its filling up the water
the water pan is a catch for the defroster.When the defrost timer cycles it heats an element in the freezer that thaws ice bulid up and a drain hose deposits the water in the pan.
Dec 23, 2009 | Whirlpool Refrigerators
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking into the drain pan
if the pan on the compressor on plug unit get a rag and sock up the water i beleave you doors staying open to long
Mar 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water filter leak Whirlpool ed25rfxfw01
I have an undersink filter from Whirlpool that is leaking also. I had an older one that also leaked and I replaced it. Worked fine for about six months then water all over under the sink. I believe it is leaking from the O-ring which seals the body and the cap. I think they have a lousy design and will look for another filter.
Dec 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leak water on floor once a month
This likely a defrost cycle issue. Your drain tube is likely clogged. Get under there and clean it, clean your condenser while you're at it. Cut down door openings, open liquid in the fridge.
Jan 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6NBEXRL Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
