Question about Smith Corona Office Equipment & Supplies
My r key won't lift up, how do you fix that?
All of my writing keys lift up except for my r key, whats up with that?
    Champion:
  • 204 Answers
Usually the typebar link is off or broken. Lift the key up manualy and see if its attached. If it is broken only an expert can fix it. If it is off you may be able to reattach it if you are mechanically inclined.
Hope this helps
Posted on Jan 19, 2013
I had to reinstall xp home edition and the product key won't work help
Do you have the proper key ? it should be printed usually on a sticker somewhere on your computer
Make sure all keys are typed in correctly with the space between
IE: Q8VBM-34FWW-7DFFY- .... this is just an example
Hope this helps.
Dec 19, 2012 | Microsoft Windows Xp Home Edition Sp2...
Can't open hatch and my key won't unlock the doors. how do i open the tank?
Order a new keyfob from the dealer and have them program it to your car.
Jun 24, 2012 | 1999 Audi A4
I have a 1990 Arctic Cat Cheetah Touring and everything runs well except when you turn the key to start the motor, it won't start. Turn the key to run position and short out the two power terminal
Well, I can probably help you but you will need a Voltmeter and know how to use it. Shouldn't be too much of a diagnostic problem but the VM is first. Do you have one and know how to use it?
Aug 02, 2017 | Toys
My nordictrack is stuck on a program &wont let u do anything else..cant change the speed or incline &the fans wont turn on..its like the consol is frozen or stuck on a program..how can i reset it...
How to Troubleshoot a Nordic Track C2500 X15616db0-ef56-4f0a-afbd-b1ae3379f47f.small.jpg Jolie Johnson
Based in Austin, Texas, Jolie Johnson has been in the fitness industry for over 12 years and has been writing fitness-related articles since 2008 for various websites. She received her Bachelor of Arts in English and philosophy from the University of Illinois.
By Jolie Johnson, eHow Contributor
updated April 15, 2011
Related Searches:
The NordicTrack is a treadmill designed for in-home use. It offers a speed range of 0 to 10 mph and an incline range of 0 to 10 percent. It folds up vertically to save space when you aren't working out and can be rolled to a different room. The console has 16 preset workout programs and features iFit interactive technology. If you have problems with the console or walking belt, you can often fix them yourself with some basic troubleshooting steps
Instructions
  1. Power Turns Off When You're Using the Treadmill
    • 1 Check the reset switch on the bottom of the treadmill near the power cord. If it has tripped, the top of the switch will protrude. Wait 5 minutes then press the switch.
    • 2 Check that the power cord is plugged in completely. If it is plugged in, unplug it, wait 5 minutes then plug it back in.
    • 3 Remove the magnetic key from the console then reinsert it.
    The Console Won't Turn Off
    • 1 Insert the magnetic key into the console. Your C2500 is stuck in demo mode if the console won't turn off after you remove the magnetic key from the console.
    • 2 Hold the "Stop" button down for a few seconds.
    • 3 Press the "Speed" down (-) button. Remove the magnetic key.
    The Incline Does Not Change Correctly
    • 1 Press and hold the "Stop" and the "Speed" up (+) button. While holding the buttons, insert the key into the console, then release the buttons.
    • 2 Press either the "Incline" up or down arrow button. Wait while the incline raises and lowers. This recalibrates the incline system.
    • 3 Remove the key from the console.
    Walking Belt Slows
    • 1 Unplug your C2500 and remove the key from the console.
    • 2 Turn both rear adjustment bolts, located on the back of the walking deck, to the left, a 1/4 turn.
    • 3 Lift the edge of the walking belt in the middle of the deck. You should be able to lift it 2 to 3 inches off the walking platform. If the belt is still too tight, loosen the bolts another 1/4 turn each.
    • 4 Plug the treadmill in and reinsert the console key. Walk on the belt at a slow speed to see if it still slows. Repeat Step 2 if necessary.
Sep 27, 2011 | Nordic Track NordicTrack Treadmill, A2550
1995 geo tracker won't start. I've replaced everything except the ignition switch. It used to click when i turn the key, now it won't even click.
DISCONNECT YOUR BATTERY AND RECONNECT, THIS SHOULD RESET THE BRAIN.
ALSO...WHEN YOU TURN THE KEY, LISTEN TO HEAR IF YOU CAN HEAR THE FUEL PUMP COME ON...IF NOT, GUESS WHAT? HOPEFULLY NOT!... BUT,YOU MAY NEED TO REPLACE THE FUEL PUMP, IF YOU CAN'T HEAR IT WHEN YOU TURN THE KEY, AFTER YOU'VE RESET THE BATTERY!
HOPE THIS HELPS!
Aug 30, 2011 | Geo Tracker Cars & Trucks
My TI83 calculator hasn't been used in a few
Is it that your "Enter" key won't depress or it doesn't respond?
Aug 05, 2011 | Texas Instruments TI-83 Plus Calculator
Configure keyboard buttons
Status: No need for registry backup, the 1.1 version of the software allows you to delete all key modifications within it, in order to return your keyboard to normal.
I came across a nice utility for changing keyboard keys in Windows. It's called Sharpkeys. Basically, you open the program, select which keyboard key you want to change (such as Left Alt), and choose what key you want it to actually be (such as Left CTRL). Here's the website:
http://www.randyrants.com/sharpkeys/
On the 7405gx, it will do all of the keys except for the Function key and the special hotkeys that control volume, mail, etc. For example, I assigned the "'\" key to the left of the spacebar to be "Left Alt" and the left alt button to be "Left CTRL", because those keys are more natural for my fingers to press. Physically the keys look the same, but their functions are now different.
Once you've installed the program, open it and you will see a black screen with green text and some buttons. To add a new key assignment, do the following:
1. Click the "Add" button
2. To select which key will be changed, click on the "Type Key" button on the left under "Map this key (From key):" and click the "OK" button OR select the key from the list.
3. To change what character is actually typed when you press the key, do the same as #2 except choose the "Type Key" button the right under "To this key (To key):"
4. Click the "OK" button.
5. Click the "Write to registry" button.
6. Click the "Close" button.
7. Restart your computer or logout. When you load back up, the key changes will be in effect.
You can revert to the original state by clicking the "Delete all" button.
This is a neat program because you can change your laptop keyboard keys to do whatever you want. Please post any comments, questions, or suggestions and I will update this post as necessary.
Aug 03, 2011 | ASUS Computers & Internet
Electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
Jul 24, 2011 | 2008 Jeep Cherokee Grand
I can't see what my contact person write to me and when i ' am writting i can see what i write but when i make send i cant see it either>>plz i need help it's so important thank you
for windows xp,2000,NT; other OS this direction may vary
first click on start>Run>type "regedit"
find HKEY_CURRENT_USET>Software>Microsoft>Windows>CurrentVersion>
Internet Settings>Zones.
delete key or zone names as for example "?" or a square like you could see
but except keys 0,1,2,3 and for
NOTE: DON'T DELETE keys 0,1,2,3 and 4.
if it doesn't work jus simply restart your YM application
or maybe your PC.. and there you go..
If this doesn't work just send me mail lovemyguitar41@gmail.com
I'm glad to help... if its much helpful pls send me also a mail or just post it in my fb Account..
just follow the instruction...
if it is so helpful to you press thumbs up..
Jun 30, 2011 | Yahoo Messenger
69 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Ron Dufek
Ron Dufek
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
