Question about Datamax E-Class E-4203 Label Printer
Barcode scanner won't read printed labels
Just recently, the labels printed by my datamax e-class 4203 label printer will not be scanned by my barcode scanner. old labels from the same printer are scanned just fine, but new ones, even copies of old labels, are not registered by the scanner. i successfully scanned an old barcode, then printed off copies of that same one, and only one of 5 copies worked. The assumption is that the printer is not printing the barcode with the same quality, but I can't figure out how to fix it.
    Scholar:
    New Friend:
  • 52 Answers
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Posted on Feb 18, 2013
2 Suggested Answers
Nic61
  • 1073 Answers
SOURCE: s there any free software for running Datamax E 4203 Printer? it is meant for printing library barcode labels.
http://www.datamaxcorp.com/software/e-class/
There u go!
Manuals, drivers, firmware and utility for the E-class,E-4303,E-4204 and E4304
Good luck
Nic
Posted on Apr 24, 2009
What is the backing?
The Backing is the see through paper on which the labels are stuck to. It can have a light yellow or white color. While the printer prints, the labels move through the label sensor, usually green in color. The gaps between the labels triggers the sensor to indicate where the printer should start to print.
Hope this Helps. (",)
Aug 05, 2014 | Datamax DMX-M-4206 Thermal Barcode Label...
DATAMAX E-4203 ONLY PRINTING HALF OF THE BARCODE
I doubt the sensors would have anything to do with only printing half a label. I'm not familiar with the E-class series of printers, but the common causes of that problem that I've seen before with the larger M & I class printers can be:
1) A piece of label or ribbon is stuck on the printhead.
2) The printhead is not seating properly on one side, causing the printhead to be too far away from the label & platen roller to apply enough pressure in order to print.
3) A printhead cable is not seated fully somewhere and not supplying the signals properly to that half.
4) The main logic board is bad.
5) The printhead is bad.
6) There is a software problem or label configuration setting that needs to be corrected that controls the print width.
Feb 26, 2014 | Datamax DMX E4203 Printer
Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
Datamax printer prints every other label
Hi
Label length or pitch (label plus gap) is incorrectly set, either in your software and /or driver.
Barcode Labelling Solutions
Apr 25, 2012 | Datamax W-Class Printer
Got to work this morning and the thermal printer had continuously printed the previous days manifest until it had run out of labels. I inserted new labels and it started to print the manifest again. I...
Uninstall the printer and restart the computer once installed reinstall the printer from the CD that came with the printer or get the latest software / pilots from the printer's web page
Jul 21, 2011 | Datamax E-CLASS DMX-E-4203 Label Printer
Hi! I have a problem with my office Datamax E class printer. When i change tickets in the printer it doesn't print them the right size - normally they are too short. Do you have any idea how to solve...
If you are changing length(feed length) you may have to recalibrate the printer . Also ensure that your print format is the correct length for the stock.
You can look at the setup of the printer using the datamax-oneil printer configutation program, or if it is using IP connection, you can go directly to the internal web page for set up. make the cal length 3 times the label length, or leave at the default value.
Dec 29, 2010 | Datamax E-Class E-4203 Thermal Label...
Only prints ''smeared labels'' with no text even remotely recogniza
You need to alighn your print heads and or buy new ones. Also, the paper must be the right specified paper or it will blotch or smear.
Feb 19, 2009 | Datamax E-Class E-4203 Thermal Label...
Regarding Datamax E-4203 - Won't print
Check to see that the label sensor is over the gap in the label. It is just under the head on the right hand side.
You might also have the unit configured incorectly. If you go to the Datamax site, you can download the printer config program, It is easier to use than trying to push the buttons in the correct order to configure the printer.
Also use at least a 6" long label, and print the config file to see if you are set correctly for gap mode if using die cut stock.
May 16, 2008 | Datamax DMX E4203 Printer
Datamax E-Class E-4203 Label Printer Logo
196 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
