Question about Samsung Refrigerators
Samsung Refrigirator RS4525SH. Everything is working fine except my control panel. Replace my control panel today with no results. What could be broken? Thanks
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: refrigidare model # plhs267za
sounds like the air damper control for refrig is freezing in the open positon. not a really consumer freindly repair,(dropping side control panel checking damper door for ice build up, removing ice and applying a silicone lubricant(vasiline) to prevent further freezing of air damper motor. sounds easy enoug but that panel is real tricky to drop and mount back in.
Posted on Mar 04, 2008
pappapumpdaf
  • 635 Answers
SOURCE: My control panel on the freezer door stopped
Make sure the wires on the left top door hinge are still connected. They are usually under a plastic hinge cover.
Sometimes there are wires on the bottom left door hinge that get disconnected when you move the fridge as well.
Posted on Mar 11, 2010
TheMobilian
  • 8220 Answers
SOURCE: Refrigirator Temp controller button making noise-
Try raising the legs up on the front just a hair. This will shift the weight of the ice box to the rear and force the doors to close tighter. Then the beeping may go away.
Posted on Jan 03, 2011
No dash lights when headlights are turned on. Everything works fine on my vehicle EXCEPT today the panel lights don't work. Turn signals, hazard blinker, oil gauge, rpm gauge, speedometer, drive shift...
there is a regulator for the display brightness, you may have it turn'd down or it has stopped working;. it controls the brightness at which the dash lights are. usually has a speedo sign on it. goes up and down. it works with the main light and is conecter to them on the same lighting board if it has gone then a new light swtch control switch will be needed.
Oct 13, 2013 | 2001 Chrysler Town & Country
Samsung Refrigirator RS2545SH: Installing my ice maker when I heard several clicking sounds, I realize I forgot to unplug my refrigerator before installing my new ice maker. After plugging back my Ref I...
First lets check the wiring plug under the top left hinge cover to insure the connection is firm and then check connections at the motherboard. Let me know what happens, Thanks Sea Breeze
Samsung Refrigerator Familiarization
Dec 13, 2012 | Samsung Refrigerators
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Jul 24, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Condensor fan not running
put your hand on the body and feel if it hot if hot change fan if cool problem
Nov 01, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Samsung side by side refrigirator
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Aug 20, 2008 | LG LFX25960ST Stainless Steel French Door...
Refrigidare model # plhs267za
Mar 04, 2008 | Frigidaire PLHS267ZA Side by Side...
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
