Question about Kitchen Ranges
My pellet stove is makin a lot of ashes and the flame isnt working as fast as it should.what is the problem?
    Genius:
  • Kitchen Ranges Master
  • 1,669 Answers
Air, air, air! If the pellets don't get the forced air from the fan they burn slowly. Also if the air vent is blocked or partially blocked you will have the same symptoms!
Posted on Dec 26, 2012
2 Suggested Answers
SOURCE: St Croix pellet stove: pellets drop
http://www.jaygaulard.com/blog/2009/01/18/how-to-clean-out-a-st-croix-prescott-exl-pellet-stove/
Posted on Feb 24, 2009
No flame. The auger works fine and the pellets are feeding in. There is no fire to burn them.
Do you have a user's manual? Most pellet stoves need to be lit before starting the auger to sustain the fire.
Feb 10, 2017 | Cars & Trucks
What is causing the ready light to flash red twice when I try to light my pellet stove
[PDF]INSTALLATION AND OPERATION MANUAL - Wood Pellet...
woodpelletheat.com/WinslowManual.pdf
by P Stoves - ‎Related articles
Please read this entire manual before installation and use of this pellet fuel-burning room .... FLY ASH BUILD-UP: For all wood pellet fuel-burning heaters, the combustion ......Ready Light - lights up when stove is ready to operate. Igniting Light ..
Sep 27, 2015 | Pool & Spa
We have a heilsa pellet stove model#QCPS-28000 ,its dropping pellets to fast ,how do I adjust the feed.
  1. SET THE AIR INLET DAMPERS
It is not possible for the manufacture to factory set your stove to work properly without some adjustments. The dampers help control the amount of airflow supplied for combustion.
A damper PUSHED IN all the way, maximizes concentrated air flow to the burn pot. This will maintain a robust fire.
The Auger timing is designed to be run, in most conditions, with the dampers closed.
In some areas/conditions, it mybe necessary to adjust the damper open slighty in order to slow down the flame and allow the pellets to keep pace with the rate of burn. This should be monitored closely to ensure you have the propoer feed rate established. If dampers are opened too much, the rate of burn will be very slow and the pellets will build up.
This setting needs to be fine tuned to according to your location and elevation. It is recommended that you start with the dampers pushed in to start.
Feb 20, 2013 | Northern Tool and Equipment Pellet Stove -...
I purchases an elcipse pellet stove in 1990. It still works perfectly. I need to replace the insulation blocks for the side walls and also need a new ash pan. Do you know where i can purchase these items.
Elcipse was manufactured by Warnock Hersey, but was sold to St Croix. So, their parts may be interchangeable with your stove. Try Pellet Stove Parts.com and click on other brands for St Croix.
http://www.pelletstoveparts.com/mm5/merchant.mvc?
Feb 22, 2011 | Heating & Cooling
We have country flame pellet stove it will start then shuts off. We have had company here and they do nothing all we have had is PROBELMS with stove.
Yeah, I have a country flame stove and I have had loads of issues. Country Flame stoves are junk, I am working on a class action lawsuit with some other country flame owners as of 2.2.2011
want in?
Oct 04, 2010 | Napoleon Auburn Pellet Stove Heater
Ash build up in burn pot
You are burning wood pellets. When you burn wood you produce ash. Some of the ash is extremely hard and hard to remove. What I do is remove the burn pot, take it into my shop and with a screwdriver and hammer, LIGHTLY tap on the hardened ash until the pot is clean. Should only take a few minutes. At the same time you can clean the glass. Even though it may burn very clean, nothing burns wood fuel without by-products...Good luck...Lee
Jan 04, 2010 | Napoleon Auburn Pellet Stove Heater
I have a pellet stove and the glass soots up very fast is there a way to prevent the soot build-up
Most of the pellet stoves I have seen have a part that pushes air up in front of the glass. See if you have a part that you are not sure of where it goes. If you do, try it in a way to push air in front of glass. You may have to contact the company that produced it and get one from them. Another thought, there may be holes in the floor of the stove that have been plugged by ash or something. If there are, clean them out. Good luck...Lee
Nov 25, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
My Quadra fire 1000 Pellet stove is not igniting correctly, the fire box fills with lots of smoke, the when it finally does the flame is erratic, extremely high and is giving off alot of black, and does...
Hi lovinthepine:
1st. clean the unit, inside and out! Clean fire bowl/pot, it'll have small'ish holes for air and a larger one for the igniter. Clean out all holes in fire pot! Make sure fiberglass gasket material between firepot and firebox floor is in tacked and not leaking. make sure ash pan door is closed tight. Clean finned heat-ex's, this requires pulling out the two heat exchanger cover plates inside the firebox., next pull the right side panel and remove neg pressure blower & clean. These can get cloged up with ash and half burnt pellets. Tall flames & black smoke mean the unit is out of adjustment. Try closing up the pellet feed plate some, it's located in the pellet hopper area. Adjust opening smaller and wait 15 min, takes that long for change. If that doesn't get it, try opening the positive pressure blower's restrictor plate some. Remove left cover panel & find semi funneled blower cover plate, loosen screw and slide plate sideways +/- 0.25". If that doesn't do it, make sure all blowers are coming on, check for exhaust blockage in stove output/Flue sys. I hope that help ya, good luck!
C.B.
Oct 21, 2008 | Heating & Cooling
After installing the pellet stove,the stove seems to 'burn up" the pellets to fast not creating a "coal bed ',no real heat is going in the house.It is a breckwell big E mod. 55'000 btu...
Not sure what is happening but if the pellets are burning too fast that tells me you have to set the air flow while they are burning. Even a wood stove will burn to fast if there is too much air . There should be a setting for the air flow on all stoves and some times it should be almost closed. if it continues i would contact the stove seller and ask them.
Sep 04, 2017 | Heating & Cooling
Kitchen Ranges Logo
104 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
