Question about RCA D61W20 61" Rear Projection Television
Can't turn on tv
When trying to turn on light will blink a couple times and every now and then will catch and turn on or will just not do anything,but if it turns on it turns off with no problem
  • RCA Master
  • 5,138 Answers
Check capacitors cp150 2200uf 16v and cp114,cp120 220uf 35v- If cp150 is puffed up on top replace all 3 capacitors.
Posted on Feb 10, 2009
I can press the power button on TV.the green light will come on briefly then go off the red light will blink a couple of times waits second and blink twice
HI,
By blinking led it shows which part of the tv is faulty. As You didn't mentioned anything about the brand and model number of the TV its not possible to give a accurate solution.
www.electro-medical.blogspot.com
Sep 18, 2015 | Televison & Video
Hi, I have a Sony KDL-46XBR9 LCD Digital Color TV. This morning my son was watching cartoons and it clicked itself off. It has sometimes done this in the past, so we did something else for a couple of...
This tv have a power supply board is the causes and the problems.Ur tv power supply board finally gave out and not supply the right voltages to the tv system anymore.That the board,where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Televison & Video
When trying to turn on my tv, the green light blinks a few times then the red light blinks a couple of times then automaticaly the tv shuts off. There is no picture at all. It makes a couple of sounds like...
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Jun 04, 2010 | Zenith E44W46LCD 44" Rear Projection...
Turns on for a couple seconds and immediately turns itself off.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Let me know what you find and I will tell you what I know.
SD TECH
May 10, 2010 | Mitsubishi WT-42313 42" Rear Projection...
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi ws-55515 light blinking
Sounds like the remote is not programed correctly or the input sources have been changed.
Call the cable company and complain that it worked before they came and shoud work afterwards.
Mar 24, 2008 | Mitsubishi WS-55515 55" Rear Projection...
No picture red light blinks 7 times
in this model is commom that the convergence ic.s go bad and stop the set from turn on check for a couple of fuses that are in convergence board if is blow replace convergence ic
Feb 01, 2008 | Sony KP-53HS10 TV
TV Problem
the red blinking light is a code that tells you what is wrong it will blink from 1 to 10 or just blinks all the time
Jan 03, 2008 | Sony KV-32S26 32" TV
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
RCA D61W20 61" Rear Projection Television Logo
115 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
