Question about Hotpoint WMA48 Front Load Washer
Hotpoint Aquarius Extra WMA48
The machine leaks out of the powder drawer.I have put hot water down it in case it was undissolved powder.At first this course of action worked but now it has decided it will flood every time it is used.Also it does not seem to pump all the water out of the drum.Could it be the pump needs cleaning out ? Is there a solution that could be put in the machine to clean it out and dissolve any hairs/cotton and so on ? I am quite technical so given instructions would cleaning the pump out be something i would be able to do myself ? I should mention we have dogs and the wife washed one of the dog beds some time ago.The machine is about seven years old i think. Thanks
    Sergeant:
  • 236 Answers
Firstly you will need to take out the soap drawer and thoroughly clean it and the spray holes that are above the soap drawer. secondly i would reduce the cold water pressure to a fast trickle/jet that way it will not be spraying all over the place. the filter sounds as though it will need cleaning out. unplug machine, from the rear is a metal plate, remove it to gain access to the bottom hose-this incorperates the filter. undo secure jubilee clip and lower hose. remove debris and check the hose and pump for further obstructions. you should be ok after that. try to beat out the dog blankets outside b4 washing to remove as many hairs as poss. tone.
Posted on Jun 11, 2007
  • Suzanne Alford Dec 11, 2011
    Fabulous! I saw this reply from Tony and finally found this mysterious filter that's not mentioned in the Aquarius Extra WMA48 manual! My next door neighbour is now lying on my floor removing the gunk and some of thsoe colour absorbant tissues you put in to avoid colour runs which had somehow worked their way down between the rubber door seal and the drum! Thank you and fingers crossed that water stops coming out of the dispenser drawer pipe and flooding kitchen. Yet to do a cycle of wash but i'm hopeful now all is going to be fine! I'll let you know if anything else happens, if i go silent then all is fine and dandy!
Washing powder compartment fills up with water
It's probably just caked with powder or conditioner and needs cleaned. Your handbook gives instructions on how to remove the drawer. Alternatively the dispenser to drum inlet hose may be blocked and some hot water may clear that.
Jul 13, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Can this machine heat its own water? It has a hot and cold water intake. also mashing machine is not taking the powder from the powder drawer. Can you help?
Yes, this washer does have a heating element.
Make sure there is a good water pressure at the inlet valve/s,
or the powder will not dispense.
Make sure there is no blockage or obstruction in the drawer, \also make sure you have the powader in the correct compartment.
Hope this helps.
Dec 20, 2009 | Hotpoint Aquarius WD640 Front Load...
Water leaking from Door and Draw from Hotpoint Aquarius Extra
Had the same problem. I unplugged the machine from the mains. pulled it out from the unit and removed the lid. checked the black rubber hose which leads from the drawer to the drum. it was full of water. i carefully squeezed the pipe and tried to clean it out with warm water to see if it was clogged. still leaking. i then Removed the green paddle on the inside and turned the drum to line up with the black rubber hose that leads from the drawer. I very carefully used a wire coat hanger to put through the gap in the drum left by the paddle. Moved left and right, oh look.... A sock! I manipulated it out of the gap, checked the hose. Water had gone. Put everything back together. No leak. All done in under an hour :-)
Mar 02, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Powder drawer wont open
Grasp the drawer firmly, and pull out until it reaches its stop, then press the plastic lever down in the middle of the drawer at the rear, and pull the drawer out.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Hotpoint Aquarius WD640 Front Load...
Manual WMA48
To get the information you require you need to type in your browser bar the following. hotpoint user manuals
In the list on the left click on manuals-user guides-handbooks-hotpoint service
Then in the search box type in your model number of washer, and download instructions, as req'd.
PleaseThankyou. rate my solution to your query.
Jan 27, 2009 | Hotpoint WMA48 Front Load Washer
WD 63
Remove dispenser drawer from m/c, and thoroughly clean it and all accessories.Clean all residual build up of undesolved powder and conditioner in drawer compartment..
If it still leaks, then remove top cover, locate large black hose at bottom of dispenser, and give it a good squeeze to clear any possible blockage in the hose itself..
If still no better, could be due to exceptionally high water preesure forcing the water out of the drawer.
Turn cold water valve down a little to reduce pressure.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Water leaking (Aquarius 1200)
don't think using quick wash should make a difference as water intake is the same take drawer out and wash thoroughly especially the rinse compartment. if gunged up the water overflows the compartment and leaks down the front. otherwise, you may have a blockage in the hose from the drawer to the tub. take top off, remove this hose and clean disconnect from mains when you do this
Apr 01, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA48 Front Load Washer Logo
601 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
