Question about Royal Satellite 40 Typewriter
We have a satellite 40 typewrtiter, some times after we use auto correct the ribbon gets hung up behind the key depression wheel. anyone else?
  • Royal Master
  • 3,594 Answers
Check For bent spokes on the print wheel, if that's OK try a fresh correction tape.
DickyO
Posted on Dec 12, 2012
How do i get my Brother A X 250 Eletric Type writer to type the correct letters ?
"If your unit is not printing properly:
1.Ensure the ribbon cartridge has not run out of ribbon. If your ribbon appears silver or gray, install a new cartridge.
2.Ensure the black lever in the center of the carriage is pressed to therear towards the paper. If not, press it to the rear to lock the Daisy Wheel into place.
3.Reset the unit by holding down the [CODE] Key and pressing the [SHIFT]Key and the [WORD OUT] Key.
4.Release all three keys.
5.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com
Feb 27, 2013 | Brother SX-4000 Typewriter
How to fix mobo steady hardisk led no post
Do you have one of the older ATA hard drives with the 40/80 pin ribbon cable? If so, be certain that you have the ribbon installed correctly at each end. Some ribbon cables are not keyed and if you get the red stripe at the wrong end, that it the symptom you will get.
Dec 26, 2011 | ASUS Computers & Internet
How do i reset the wheel on a smith corona sl460 electronic typewriter? the correction ribbon keeps coming out of place
The typewriter has a spring at one spool to keep the correction ribbon taut. If that spring is broken or out of place, the ribbon will always get in the way of the wheel.
If both ribbons are correctly set tight between the wheel and the paper, the typewriter will reset the wheel at power-on.
Some models reset the wheel every time you close the cover. You can see and hear it if it does.
Feb 16, 2010 | Smith Corona Office Equipment & Supplies
The wheel turns but it does not strike to make the type?
Remove the ribbon and turn the feed wheel to make sure the ribbon will feed by hand. Check that the ribbon is lifting each time you depress a key.You might also want to check that the platen (black roller) is seated down properly in it's latches.
Nov 11, 2009 | IBM Wheelwriter 30 Typewriter
I have an Royal-Adler Satellite 40 which is mistyping. We tried resetting the wheel, but that didn't work. Does anyone know the codes to "clear" codes that may have accidentally been entered into the...
Take the printwheel out and look for bent or broken spokes, check the P/W area for debris. be sure that you have a dry correction tape the tacky ones will gige you fits.
DickyO
Aug 04, 2009 | Royal Satellite 40 Typewriter
Wheel is not setting up to type correctly
The keeys were getting caught in the plastic guide. Tood guide off and now no more problem!! Thanks anyway!!
Jun 03, 2009 | Swintec Office Equipment & Supplies
Ignition cylinder won't turn
I had the same problem in a 94' trooper. Basically the Ignition lock cylinder is wore out and you need a new one. Mine wouldn't turn past lock and no matter what I tried it wouldn't turn. You can go on auto zone and find the part, mine was about 61 bucks, it comes with keys and the ignition cylinder. The deal is that to get your new ignition cylinder in you have to get your original turned to off or acc I can't remember. You'll see with your new ignition cylinder that when you turn the key there is a button that can be depressed but only when the key is turned past lock and it also won't depress in start. First, disconnect battery and wait like 30 minutes. So, what you do is take a screwdriver handle and place it up against key and take some pliers or something and beat on it a couple of times, this gets the key in deep enough to where you can eventually turn it. I swear it will eventually turn, once there, take off the top and bottom plastic covers off steering wheel/unscrew electrical wires on back of ignition cylider and other side and you know the button I referred to basically you have to depress that with key in acc or off and it will slide out. If your having trouble finding the button look at new ignition cylinder in comparison to old one and you can see where the depressed button is on side closest to you, you'll see a little hole up on the side of housing that you can depress.
Mar 01, 2009 | 2000 Isuzu Rodeo
Not typing correct letters
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
Mar 09, 2008 | Brother ML-100 Typewriter
Adler royal satellite 40 ribbon drive problem
Try holding the code key down and pressing the (.) period key. It is probably in the mullti strike ribbon mode.
Oct 18, 2007 | Royal Satellite 40 Typewriter
Replacing typewriter ribbon
Linda, Depending on what make and model you have it could be several things. The newer TW's use a print wheel which has to home itself each time the power is turned on. This tells the print motor how far to turn for the correct letter. Make sure there is no debris and everything is seated properly... platen, print wheel, etc. Once again, this depends a lot on what kind of TW you have. MM85
Sep 04, 2007 | Office Equipment & Supplies
Royal Satellite 40 Typewriter Logo
42 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
