Question about Brother Sewing Machines
My machine breaks the thraed alot.i have don its service last year .
Its been 3 years i have this machine but i did not used it regular just 4 house use only.it breaks the thread alot aspecialy when i fold the mitirial even if its thin 1.
  • Brother Master
  • 1,564 Answers
Sounds like too much tension, a bad needle, or bad needle plate.
Posted on Dec 12, 2012
SOURCE: Designer 1: upper thread shredding while embroidering
I too, have the same problem withmy Designer 1. I just bought ISACORD brand polyester embroidery thread to hopefully solve this problem, but I believe it must be a tension problem. I have a "date" with the repair lady on Friday (11/22/08) and if it gets repaired I will re-post what the problem was. Still love the machine WHEN IT SEWS!!
Posted on Nov 16, 2008
SOURCE: Elna Lock L2 I have overlocker rage..... been
Have you made sure the needle thread is the last to be threaded. If this thread is still under the loopers when you rethread, the threads will break .Sewit
Posted on Apr 25, 2009
SOURCE: On my overlocker, the bottom two threads keep breaking.
globe overlocker stitching reverse
Posted on Jun 18, 2009
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Posted on Sep 23, 2009
  • 92 Answers
SOURCE: The thread keeps breaking while free motion
Tough one! Did the machine ever work when it left the shop? if the shop said its working and its been in 4 times there could be a communication issue. I use schmetz brand quilting needles and have found some threaedds are so poor quality they cause this problem. Try a BEST quality thread, size 40 or 50....no bigger to start. Some folks buy big cones of thread and by the time they are used up the thread is brittle and weak. Work slowly...set the speed controller on the front of the machine at 1/2 to 2/3 speed and hold the pedal down to get a even speed. Dont move the fabric to fast, a slow smooth movement is whats needed. Practice on the same fabric and backing as you are trying to sew on. Bring it back to the dealer and ask them to try it. then you will have a better idea of whats what.
Derek
Posted on Jan 18, 2011
Is the Singer 513 worth taking in to get cleaned or repaired?
always, you will notice that it has a metal body which means it will last and last the brothers plastic will just deteriorate over time. The plastic parts in the brother will crap out. Th singer will still work in 20 years the brother will last 4-5 years if you are careful
Oct 29, 2014 | Sewing Machines
Need repairman for Elna Lotus TSP
Leaving a machine for that long unused causes this issue. The oil becomes dried out and gums up the mechanisms. The motor sounds off mostly because the grease is dry too.
It doesn't need to be an Elna mechanic... it just needs to be a GOOD sewing machine mechanic.
Mar 20, 2013 | Sewing Machines
Bernina 1130 backstitch is not working
then you need to call the shop that serviced the machine & tell them
about the problem that the machine won't backstitch & see what they
say
Apr 29, 2012 | Bernina Sewing Machines
Is it worth to repair a Singer Stylist model 478? Missing foot part and cords.
yes,,there good machines,,several of my relatives have one,,,I get a lot of them to service
try sewingpartsonline.com for the foot & cords
also clean under the needle plate where the feed dogs are for lint
& clean bobbin area for lint & loose threads
have it serviced once a year if you don't use it alot,,twice a year if you do use it alot
Nov 27, 2010 | Singer Sewing Machines
I bought an empisal overlocker and sewing machine more than two years ago at Game Centution. I used the sewing machine a few times. I tried to use the overlocker but without success and just put it away...
Hi Bonita
Can you use the sewing machine? Does it work? I am also thinking of buying one but not sure if I should. They're on sale now at Makro for R899 =- what did you pay for yours?
Aug 17, 2010 | Sewing Machines
My reverse stitch doesn't work?
There is a rocker inside the machine the rocks back and forth with the operation of the reverse button. It will stick if it is not serviced regularly. If you have the machine serviced every 2 to 3 years, by someone who knows the machine, everything should work fine for many years to come. Not servicing a sewing machine is something like not servicing an automobile. It will run fine well beyond the recommended service time but when it stops, you will need to spend a lot more money than what you would for a standard oil change.
Feb 13, 2010 | Husqvarna Sewing Machines
Bobbin/thread tangles
All sewing machines will require maintenance. The difference being that some machines (most made these days) require servicing from a technician. The older machines have the instructions and the owner is able to do the oiling/cleaning themselves. If you don't mind paying for the service then how often depends on use. If you use your machine regularly, say at least once or twice a month, then you will find you would need service about once yearly. If you never use your machine, say once or twice a year, you may find it needs servicing every time you try to use it.
If you wish to purchase a new machine, what machine depends on your amount of usage, types of sewing and such. There are a lot of good easy to use machines on the market, my suggestion is to stay away from the Discount house machines. These may look ok, but they are much cheaper parts inside. My suggestion is to go to a local sewing shop and sit down and sew on the machines. When I sold them I always told people to bring in a sample of the type of sewing they do. If the salesperson won't let you sew on it, don't buy from them. If you want to email me with the types of sewing you do and such, I'll see if I can help you find one. csews@email.com
Mar 01, 2009 | Singer Sewing Machines
Viking is skipping some stitches when it is on zigzag
These are great machines but after 25 years there are probably a lot of problems that need to be fixed. It could be as easy as buffing or replacing your needle plate. If you take it in for service (and can actually find someone who is good with this machine) you will probably pay $200 to $400 to get it back to 'factory' state.
Jan 29, 2009 | Husqvarna Viking 1
Breaking needles
It depends on how thick and strong your needle is- try getting a stronger or thicker needle and see if it works. Or it could just be the machine, something might be broken inside
Jan 17, 2009 | Bernina Bernette Deco 600
Sewing Machines Logo
20 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
