I have nikai 32"lcd.not come power.but power board is ok.i have chack.but why not come led light read or green?
headstrong
  • 233 Answers
SOURCE: Dell W3201C: No picture, No sound
Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Posted on Dec 28, 2007
SOURCE: bush lcd tv
yellow screen
Posted on Apr 23, 2008
  • 98 Answers
SOURCE: Akai LCT3201AD 32 in. LCD
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Posted on Jun 09, 2008
  • 17 Answers
SOURCE: Power board for 32 in. Vizio
Yeah Shopjimmy has over 20,000 parts for vizio! I bet they would have a power supply for your tv. their website is www.shopjimmy.com
Posted on May 07, 2009
  • 1039 Answers
SOURCE: lg 32lcd tv's - does not power up - flashing green light
Replace any swolen capacitors on power board. If still not working replaced main board.
Posted on Aug 29, 2009
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Lcd tv has sound but no picture, checked the inverter board and light is coming on the screen but no image
1. Symptom: Powers up, relay clicks, LED turns green, backlight comes on but there's no display from any input, and no OSD.
Solution: On the T-Con board labeled 320WTC2LV3.7, stickered J01420PE7F0288, check/replace:
F1 = 2A, 35V SMD (measured 9 Megaohms in circuit) - OK!
Dec 27, 2013 | JVC LT-32E488 32 in. LCD Television
Sony lcd LED blinks Six Times
Problem is related with Back light error. Check 24V DC from power board to inverter board. if ok then Inverter board or LCD Panel needs to be replace.
Nov 21, 2013 | Sony V SERIES BRAVIA KLV32V300 32 in. LCD...
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
No picture no sound on a Vizio HDTV10A. The green light comes on then turns to amber after a couple of seconds
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Feb 01, 2013 | Vizio 32" l32 hdtv 10a high definition...
Bought in Dubai 3 years ago Pan.Viera LCD 32"\r\nStandby light flashing red/green. Have to switch on with on/off button after a few minutes switches off itself..........then back on itself
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
1 dg board, (stv 5v sense time out)
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Dec 04, 2007 | Dell W3201C 32 in. LCD Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
