Question about Acer Aspire All-in-One Desktop PC - Silver (AZ3100-U3072) (2771498)
How to install a new harddrive in an acer 23" all-in-one?
Just it hard to do and can you use recovery disks to reboot and restore theoperating sytem on the new harddrive
  • JerryWaters Dec 12, 2012
    on for the first time. It ask you to make recovery disks.
  • Acer Master
  • 7,627 Answers
If you replace the HDD you will have to do a reinstall of Windows or clone the drive. If you have the Factory Revovery DVD's then you can reinstall to Original Factory Condition. All you data will be lost. If you clone the drive, it will be as it was when you removed it. That said, is there a problem with the HDD? Why are you replacing It? The HDD hardware replace is the easy part.
Posted on Dec 12, 2012
  • max carson
    max carson Dec 13, 2012
    Make disk store for a emergency.
  • 233 Answers
SOURCE: Acer Desktop won't boot after recovery
Why not use your new hard drive as a storage disc. Reconnect your old hard drive as it was before. Hopefully it will boot the computer again. If it does, shut down the unit. On the primary bus, set your old HD as master & the new HD as slave with jumpers. Boot the unit & hopefully you will now have a "c"&"d" HD showing in My Computer. Remember that your are dealing with Windows & what should happen & what really happens can be two entirely different things.
Posted on Dec 15, 2008
sandrew
  • 2961 Answers
SOURCE: setting up a new hard disk and operating system on an Acer Power SC
There should be more than one disk, as the other will be drivers, all you need to do is press F2 or Del to get into your pc's bios settings and change the first boot device to your cd drive, insert your acer disc into the drive, then save the bios settings, restart the pc ,then, when prompted on screen to press enter to boot from cd; do so.
You should then follow instructions to set up windows on the 'C' drive as is default and it may need to reformat in NTFS.
Posted on Sep 08, 2008
bigbiggs
  • 326 Answers
SOURCE: SET UP COMPUTER
Check the bios and make sure the hd is there. There should be a program on the cd or recovery disk to fdisk the hd (partitioning). Look at the dir on the disk and see whats there.
Posted on Jun 09, 2008
  • 21 Answers
SOURCE: Replacement harddrive into acer pc
No matter what you do, you need to partiton and format the drive and install an OS, be it with the Acer recovery disks or with an original XP install disk. You will need to boot from your CD drive to install the OS, if your drive is not bootable you will need to boot from a floppy and load drivers for the CD drive. For information on how to get these boot floppies check out this Microsoft link:
http://support.microsoft.com/kb/310994
Posted on Apr 13, 2009
  • 442 Answers
SOURCE: I tried to restore my Acer T180 and installed my
Yes, when you use the actual discs that came with the computer you computer will be restored to normal. These Operating systems are called BIOS locked CDs, if they detect the right brand BIOS / motherboard they will install the OEM edition of the OS, hence you need not activate it or it will get activated properly.
Posted on Dec 22, 2010
Testimonial: "Thanks for the help. Quick and accurate info."
How to factory reset without recovery disk
When you need to recover part or all of the files on your Acer Veriton M460 desktop computer, Acer makes it easy to do by offering a built-in recovery program called eRecovery Management.
This option uses clean operating system files, usually stored on a separate partition of your hard drive, to correct errors or return the system to its original factory settings.
You can also use this program to write separate hard copies of the eRecovery program onto CDs or DVDs in case of hard drive failure.
Create Backup Disks
If your M460 did not come with separate recovery disks, and many machines don't in recent years, you can create your own through "Acer's eRecovery Management" program located under the "Start" menu.
Click on "Backup," select "Create Factory Default Disk" and follow the on-screen directions.
The program will inform you of the number of CDs or DVDs you need and help you through their creation.
Recovery with Disks
To use your created disks for recovery, place the first disk in the optical drive and reboot the system. As it boots, hold the "ALT" key and tap "F10" repeatedly until the computer boots and you see a screen titled "Starting Acer eRecovery."
You will see three options for recovery: to factory default, from user backup or from CD/DVD. Choose the option you desire and follow the on-screen directions to initiate the recovery sequence.
Recovery from the Hard Drive
Since Acer places the eRecovery Management program directly onto the computer, you can run the recovery option while in your desktop.
Open the "Acer eRecovery Management" program under the "Start" menu and click "Restore." You can choose to restore the computer to factory defaults and lose all the personal data stored on the hard drive or only restore the operating system and leave your data intact.
Select "Yes" on the confirmation screen and then "OK" to start the program.
Recovery Vs. Restore
When performing computer problem solving, the term "recovery" is often used interchangeably with the word "restore."
In some cases, "recovery" can mean to simply correct problems, such as replacing corrupted operating system files with good ones.
The term can also refer to "recovering" the system to its fresh-from-the-factory state, which is what "restore" means as well.
Restore Drivers or Applications
Acer's eRecovery Management program also offers the option to reinstall drivers or applications, which could become corrupted or damaged over time.
This option allows you to replace the current drivers for your Windows operating system with the ones originally installed on your system.
Under the "Restore" tab of the "Acer eRecovery Management" program, click "Reinstall Drivers or Applications" to see the content list and select the files you'd like to recover.
http://supportforacer.iyogi.com/veriton/factory-settings-6.html
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq40.shtml
http://support.acer.com/product/default.aspx?modelId=477
Aug 26, 2013 | Acer Veriton Z290G Desktop Computer
How to reboot my acer v3 series?
Reboot or Recover? If you have a Factory Recovery Partition, use this procedure, a Recovery will return your Laptop to the day it came out of the box, YOU WILL LOSE ALL YOUR DATA, and you must install ALL Windows, Acer updates and software you installed, a Restore will return to a date selected, if your Laptop has Restore enabled in software. Acer Restore/Recovery Procedure: http://panam.acer.com/acerpanam/desktop/0000/acer/aspiree360/aspiree360faq40.shtml
Apr 17, 2013 | Acer Computers & Internet
My acer eRecovery is missing
When a person buys a computer, and turns it on for the first time, you are repeatedly asked if you wish to make a Backup.
This is your Restoration (Recovery) disk
Did you make one?
No?
Then either contact Acer for the disk, or buy a fresh, new genuine copy of Windows, and install it.
When asked choose Repair. Non-Destructive Installation.
[Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer]
Or see if a nearby computer repair shop can repair the basic Windows files.
Regards,
joecoolvette
[NO, I do not agree that the Recovery files are on the harddrive, and not a separate disk.
The reason however, that this method was brought into play, was because of users.
1) Lost the recovery disk.
2) Afraid to use the recovery disk, so they just take it down to a computer shop anyway.
Hmmm, I'm a pre-built computer manufacturer......................
Say the disk costs around 50 cents USD.
If I take that times 100,000 computers, I save $50,000 dollars.
Users don't use them anyway, I can save $50,000 dollars.........hey, whats the problem?
I'll just put it on the harddrive, and tell them to make a Backup disk.
NOW people aren't even making a Backup disk! Sheesh!
Feb 09, 2013 | Acer Aspire Computers & Internet
To whom it may concern. im looking to reboot my acer 6935 but i dont know what way to do it, i dont have the recovery disc. could you please help. thanking you.. brian o' connell
This procedure will work usually unless there has been an alterations to the originally installed OS on the Acer. On recent Acer computers they have a hidden volume on the disk labeled PQService.
This volume is for restoring the computer to the factory settings in same condition as purchased new. It will erase everything currently on the main hard drive.
Step 1: Backup everything that is important to you, on a disk or separate hard drive.
This includes any documents, pictures and application installers.
Step 2: Reboot the system and press ALT-F10 during the POST to start the Acer eRecovery Management and reinstall the operating system.
Step 3: Select Restore system to factory default.
Step 4: The wizard will lead you through formatting the designated drive and installing the operating system from the computer hard drive to the designated drive.
Jul 20, 2011 | Acer Computers & Internet
I have an acer power fg and i just installed a power supply and a new harddrive now is giving me problems to format the harddrive it says to reboot or media doesnt let me install windows xp help
Well , Insert the windows disk , make sure the boot priority is set to CD/DVD ..boot the windows xp disk and format the hard drive using NTFS full format.
Please reply for any furthur issues
Nov 18, 2010 | Acer Power FG (APFGUP5161) PC Desktop
I have an acer aspire one D250 laptop and I tried to reboot and restore it. Now it lead me to a blank page that says B00TMGR is missing.press Ctrl alt del to restart. I tried to use ALT F10 and nothing...
*** Remove any external monitor as it will make entry into BIOS utility and recovery process difficult. ***
The following is from pages 29-30 of the 52-page D250 UserGuide.pdf located in folder C:\Book
I want to restore my computer to its original settings without recovery CDs.
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1. Check to see if Acer disk-to-disk recovery is enabled or not.
2. Make sure the D2D Recovery setting in Main is Enabled.
3. Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press during POST (Power On Self Test).
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press + at the same time to enter recovery process.
3. Refer to the onscreen instructions to perform system recovery.
Important! This feature occupies 6 GB in a hidden partition on your hard disk.
Sep 30, 2010 | Acer Aspire 3050-1733 Notebook
HOW CAN I RESTORE MY ACER TRAVELMATE 2200 without the original disk??????????????? NOW CAN U ANSWER THAT...ASAP
Hello !
Note: the recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook.
You can try ALT+F10 or CTRL+F10 during the initial boot cycle. This should prompt the laptop to access the recovery partition on the hard drive.
If it doesn't work :
Activate BIOS Setup Utility, press <F2> during POST.
Check the BIOS settings.
a Check to see if "Acer disc-to-disc" function is enabled or not.
b Make sure the [Acer D2D Recovery] setting in [Main] is
[Enabled].
c Exit the BIOS Setup Utility and save changes. The system will
reboot.
Hope this helps.
Sep 29, 2009 | Acer Travelmate 2200 Notebook
Dec 14, 2008 | Acer Aspire™ T180 PC Desktop
Help with my laptop
Do you have your Acer restore cd or your original Windows cd? Let me know and I will help you through this. Thanks.
Jeff
(DON'T RATE THIS 'TIL WERE DONE)
May 21, 2008 | Acer TravelMate 2480 Notebook
Acer 1690
They may be correct, although you can try pressing F8 on boot up and and enter safe mode. When in the menu choose 'Last Known Good configuration' and press enter, allow a reboot and hopefully you get into windows. It may also be the boot.ini which is damaged at tells the harddrive where windows is, but you will need your Windows disc to repair the system.
Apr 09, 2007 | Acer Notebook
Acer Aspire All-in-One Desktop PC - Silver (AZ3100-U3072) (2771498) Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
