Question about Simplicity Pioneer II SA200 Mechanical Sewing Machine
What size needle do I purchase for my simplicity Pioneer ll sewing machine
  • Simplicity Master
  • 7,365 Answers
Contact one of these sites and ask them, I checked on the internet
and couldn't find anything about the machines needles, if it was me, I would try schmetz universal needles,that what I use in all my sewing machines, for cotton or flannel, but if I sew like stretch I would use
ball point, it depends on what fabric is being sewed what needles you
use,, but call or email these sites and ask them what they suggest
sewvacdoctor.com
a1sewingmachines.com
Posted on Dec 12, 2012
lorizubie
SOURCE: A MANUEL FOR A SIMPLICITY SEWING MACHINE MODEL 237
Here is the direct link:
http://www.simplicityhomecare.com/manuals/
Posted on Jul 05, 2008
talk2ginny
  • 34 Answers
SOURCE: thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Posted on Jan 31, 2009
jimboz4
  • 305 Answers
SOURCE: Simplicity Fashion Plus breaking needles
needle guide may be slightly out of line, or bent, also chech base plate, maybe slack
Posted on Jul 22, 2009
  • 76 Answers
SOURCE: threading instruction for model #1220 simplicity
http://www.sewingstyle.com/Simplicity-Sewing-Manuals.htmlnot
not sure if you have the manual, try this site for a manual,
Posted on Sep 03, 2009
  • 4 Answers
SOURCE: need an operating manual for Simplicity, Model SW210
Sorry Angela, been looking for a manual for my Simplicity too but can't locate one either. If we don't contact manufacture for one, we may not get one. Unless someone out there has one to scan and share? Come on folks, help out!
Posted on Nov 19, 2011
I have a easy lock serger Model SL4300 and I need to know the needle size and what brand should I get, lost my manuel
Manual:
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl4300.aspx
Free Manual For Simplicity Easylock Serger Model Sl4300
Parts:
http://www.sewingpartsonline.com/simplicity-sl4300-serger-machine-parts.aspx
This site shows Organ and Schmetz needles but most quality needle brands would be suitable for your machine. A standard 130/705H needle will work. Just be careful as I believe my machine recommends no needles larger than a size 90.
SL4300 Overlock Serger
Jul 12, 2017 | Sewing Machines
Machine skips stitches on bulky items
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Aug 19, 2013 | Simplicity Quilter's Classic SW240...
Needles break
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Apr 27, 2013 | Simplicity SE3 Computerized Sewing Machine
What size needle to I purchase
check with
sewvacdoctor.com
Dec 11, 2012 | Simplicity Pioneer II SA200 Mechanical...
What type and size of needle does this machine use?
I recommend that you use only the type an size needle specified by the manufacturer. If I had a model number I can help find one for you.
Zashiban
Jun 23, 2010 | Simplicity Serge Pro SW432 Mechanical...
What is the needle system for Simplicity 804D serger?
For the both you listed (brother 925d and simplicity 804d) it is a "15x1" which is a standard home needle. Same size the fits almost all home sewing machines. Make sure to put the flat side of the needle to the back.
Let me know if you have any more questions,
Chris
Jun 09, 2010 | Brother 925D Serger
Thread breaking on Simplicity Denim Star
Dec 16, 2008 | Simplicity American Denim SA1100...
Simplicity Pioneer II SA200 Mechanical Sewing Machine Logo
26 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Greg Cann
Greg Cann
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
