Trying to activate Dell P793 moniter using pc
  • 5,660 Answers
If the monitor shows Power Saver Mode, or Sleep Mode, or No Signal; it is because it is Not receiving a Video Signal from the computer.
The monitor cable is bad, or the computer is not working.
http://support.dell.com/support/edocs/monitors/p793/En/specs.htm
http://support.dell.com/support/edocs/monitors/p793/En/index.htm
http://support.dell.com/support/edocs/monitors/p793/En/trouble.htm
The main problems with desktop computer failure is;
1) Computer is dirty inside
2) Power Supply failure
3) Ram Memory module/s ('Stick') are loose. Power unplugged from computer; FOLLOW Anti-Static Precautions; the Ram Memory module/s are removed, THEN reinstalled. Visual inspection WILL NOT DO.
(Also the gold plated contact pins should be cleaned with a pencil eraser. BOTH sides, ALL contact pins. Use air to remove eraser dust)
Just because you may see LED lights light, and Fans spin; means NOTHING.
Does NOT indicate the Power Supply is good.
A) If ALL of the LED's, (Light Emitting Diodes), were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use from 51 to 125 Watts of power. Just depends on what Processor it is. (Older Intel Pentium III's, and AMD Athlon's use less than 51 Watts of power)
This is why a Power Supply with a weak voltage power rail, can light LED's, and spin fans; but NOT have enough power to turn the Processor on.
[There are 3 main voltage power rails.
The Switched-Mode Power Supply (SMPS) in your computer is a Converter.
Converts high AC voltage, (100 to 240V AC) to 3 main low DC voltages;
3.3 Volts, 5 Volts, and 12 Volts. (DC)
In comparison two D cell flashlight batteries produce 3 Volts DC,
http://en.wikipedia.org/wiki/Computer_power_supply#Wiring_diagrams
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Suggestion is to test the 3 main voltages coming out of the Power Supply, with a multimeter set to DC Voltage.
You can buy an inexpensive multimeter that is plenty good enough for this job; for around $5 to $12.
OR;
Borrow a KNOWN to be good, Compatible power supply from a working computer; and use it temporarily for a test unit ]
If you are getting a video signal, and it is scrambled/distorted, post back in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Dec 12, 2012
2 Suggested Answers
SOURCE: Moniter stays in powersaving mode 75% of time.
Ther shud be a STANDBY / POWER button on your keyboard..Press it, then your monitor will be back to normal..
ask for any further assistance...
Posted on Jun 11, 2009
When i boot up my Dell Latitude D420 laptop it just doesnt show anything, not the log on window or anything
No display could be the ram needs to be reseated.
They use shared memory and if the memory cards get knocked loose=No video.
Aug 25, 2011 | Dell Latitude D420 Notebook
I have dell p793..i need to know what`s year it be manfactured?
Made around 2001, look at the tag in the back, there should be manufacturing date.
Jan 08, 2010 | Dell P793 17" CRT Monitor
Jun 11, 2009 | Dell Dimension 3100 PC Desktop
Picture is too big on computer moniter
try to change the Display settings with a higher resolution, example 1024 x 768. It's under control panel - Display and Settings Tab.
Apr 01, 2009 | Dell 2350-DHB7R21 PC Desktop
Required cct dgm moniter p793
green back ground screen no showshave to natural color
Feb 24, 2009 | Dell P793 17" CRT Monitor
My monitor will not turn on
disconnect the monitor cable from your computer tower
if you get a 4 colored box which says power on self test. it means its not the monitor then you have to get the video card or the systemboard.
Jun 09, 2008 | Dell P793 17" CRT Monitor
Two horizontal lines
Please verify the same monitor with other computer, Else try changing the display card if you have a CRT monitor. If you have lcd try to workit on other PC, If you get the same result from other computer ; you need to change LCD of your monitor.
Mar 05, 2008 | Dell P793 17" CRT Monitor
Dell P793
Check condesators that connect to G2, normally they are two 1nF 2kV. Replace them and will work
Apr 10, 2007 | Dell P793 17" CRT Monitor
Open Questions:
Computers & Internet Logo
David Payne
David Payne
