Question about Hampton Bay 73554 Antigua Ceiling Fan
Cover does not attach to the universal bracket I purchased
I moved recently and lost the mounting bracket for my Hampton Bay (I believe Huntington) ceiling fan. I purchased a universal replacement bracket and home depot. The fan mounted fine, but the cover would not attach. The Hampton Bay bracket must have holes in the side for the cover to attach to...but the universal one does not.
Are all Hampton Bay mounting brackets the same? Which one do I need and where can I get it? Home Depot does not carry this.
Thank you,
Jonathan Bernis
  • Anonymous Mar 13, 2014
    The remote does not push all the way thru the bracket so that the so that mounting bracket can be secured to ceiling
  • 25 Answers
Buy a drill and drill bit and make a hole in the bracket where needed. To make installation easier, use a larger that needed drill bit and add washer to screw, won't look as professional but you are not a professional anyway. Who goes around looking at ceiling fan mounts anyway???
Posted on Jan 15, 2009
Hampton bay support ef20036
Can you send a pic of bracket & cover? This is a store brand for Home Depot!
Aug 21, 2013 | Dryers
Looking for an owners manual for a Hampton Bay Huntington III ceiling fan
Contact "King of Fans" (kingoffans.com) in Ft. Lauderdale at 800-330-3267. They made or make Hampton Bay fans. I just ordered an arm for mine. Have your UPC number handy.
Feb 16, 2011 | Hampton Bay 24750 Huntington III Ceiling...
Lost remote
Well you can purchase a universal remote in place of your lost remote. You need to connect the universal remote to your fan, universal remotes have a code search button or sequence. Turn on your fan, activate code search, & press the power button until the appliance turns off, then press the set button. or use the manual book provided by the universal remote manufacturer.
Good Luck!!
Thanks for using FixYa!!
Jul 06, 2010 | Hampton Bay 24750 Huntington III Ceiling...
How to install universal remote in a 52 " hampton bay ceiling fan ,model # 24754
Universal remotes have a code search button or sequence. Turn on your appliance, activate code search, & press the power button until the appliance turns off, then press the set button.
Jun 19, 2010 | Hampton Bay 24750 Huntington III Ceiling...
I have recently moved into a flat with a flush light in the bathroom. The bulb just blew but I can't figure out how to change it?
there should be a screw in the side, when you find it, unscrew it and the cover should come off and you can change the bulb.
Nov 19, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Removing a fan...
on that base if you push it up aganst the ceiling and turn it clock wise then the base cover shoud release and slide down the rod
Aug 25, 2009 | Hampton Bay 52 In. Polished Brass...
Hampton bay portland 2 ceiling fan
not sure of your exact model...but I have installed many hampton bay fan... so far they have all worked for ceiling hugging mode.. keep reading your instructions
Mar 15, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Can a remote control be installed on the Huntington III?
Yes you can operate them with two styles of remotes: either the remote wall switch, or a hand held remote. Both require the receiver to be mounted above the top of the fan in the base it is wired to. The receiver has wires on both sides; the one side wires directly to the house wires, and the other goes to the fan and light. They are both sold at Home Depot and Lowes. The ones at Home Depot also include the set made by the fan manufacturer.
Feb 01, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
Mar 10, 2008 | Hampton Bay AC414-LRU 52'' Kemper...
Hampton Bay 73554 Antigua Ceiling Fan Logo
250 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
