Question about AMD M863G (M863G15CV22ARV000) Motherboard
My dvd drive cant read cd?
I have a LG DVD write.it can able to read DVD but it doesn't read any CD.and also it is not booting even windows.i checked in my system events and it shows that one of the boot files failed to load. all these things happened when burning a CD was interrupted. what can i do...?
U must clean your DVD.
Posted on Jan 14, 2009
Laptop is not detecting the CDs or DVDs
check your CD/DVD driver is properly installed. you can check it by going in control panel, Clean your CD/DVD drive by any Cd/DVD cleaner.
Jul 06, 2011 | Compaq Computers & Internet
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
I had this problem for about 5 months my lg dvd rom dint read dvds . i installed ffirmware and tried to update it but there was erreor and now dvd drive doesnt even work. no green blinking light. when i...
This is the inherent risk in updating firmware to optical drives.
Buy a new drive, power down the PC, install it and reboot the PC. If it is and IDE drive, or a SATA for that matter, before you buy a new drive make sure to disconnect and reconnect both ends of the cable prior to replacing it, just to be sure it wasn't an accidentally dislodged cable causing the problem.
Dec 28, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Samsung DVD Rom Drive does not read disks
Usually when you buy a DVD ROM drive it comes with software. However, I bought a LG one and it didn't come with any software. All I can tell you is to update the system BIOS and the firmware that came with the drive. Look on the top part of the drive when you take it out of the system.
Go to the manufacturer's website and download updated firmware for the unit.
Aug 04, 2009 | Samsung (SH-S162L/BEBN) DVD RW Burner
I am not able to install it.The windows is recognising the LG player.
Hey,
Cd and dvd drives are installed automatically on windows when they are connected properly. if your drive is not installing then your computers windows has problems, I would insist that you use recovery cd's to restore the computer to original state or use the windows installation cd to install windows to the computer again.
Note that the cd / dvd drive may work outside of windows, so you may be able to install windows with the drive even though it doesn't work in windows. check bios if the drive is detected there or not.
heres some info on the bios, how to get there and how to use it.
http://www.youtube.com/watch?v=Tc1t3c5Yke8
you may need to change the boot order so that the cd starts before the hard drive.
May 05, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
OK I MEANT THE MACHINE IS NOT BOOTING BUT INSTEAD ITS SHOWING AN ACTIVE HYPHEN ON THE SCREEN. IT CANT EVEN BOOT OR READ OS FROM A CD.
Go into your bios settings and apply "Bios defaults",
Be sure the boot order is set to
1. CD/DVD
2. Hard Disk Drive
then save and reboot.
If the system boot, scan your drive with a good anti-virus.
If not, insert your Windows installation disk and reboot, press space if prompt to do so to boot on the CD. Reinstall Windows.
If it does not work, boot with a dos diskette, with fdisk.exe, delete all your partitions. Reinstall Windows.
Mar 27, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
LG CD/DVD combo does not recognize virgin DVD´s
DVD combo do not burn DVD's they can only read DVD read CD and burn CD to burn on a dvd you need a dvd writer. A DVD combo is a combination of just a DVD ROM and a CD-RW.
with some models (even of LG) you only get one drive DVD/CD-RW but in dome version it shows as two different drives DVD and CD-RW. consider this as partioning of a drive if its to be analogued to HDD (though its not partioning its just diffrent PROMS)
Hope you understand that there is nothing wrong with your combo its just that you are expecting it to be a DVD-RAM which it is not.
Mar 25, 2008 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
AMD M863G (M863G15CV22ARV000) Motherboard Logo
73 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
