Question about Frigidaire FGHC2342LF 23 Cu. Ft. Counter Depth Refrigerator - Gallery Stainless Series
Frigidaire FGHC2342LF has frost
There is frost building up on the inside of freezer on the middle racks
    New Friend:
    Problem Solver:
  • 5 Answers
Watch to make sure items put into the freezer are not wet or the cool button is set to low.
Posted on Nov 09, 2014
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
  • 40 Answers
SOURCE: Frigidaire #FRS26ZSH : Fresh food not even cool.
that is a defrost problem need tech to one of a few possible problems you can defrost unit completely for 2 days and it will work great for a week or so
Posted on Feb 23, 2009
  • 3 Answers
SOURCE: Frigidaire FRS26ZSGRefrigerator is no longer
Your auto defrost is not working. remove the rear assembly inside the freezer and melt any builtup ice with a hair dryer. Then check the defrost heater and the defrost thermostat. If OK then check the defrost timer located either in the fridge compartment behind the temp control or under fridge in frount behind grill. A continuity test is good for timer contacts. Heater is typ. 30 - 40 ohms. Thermostat will read short short below 35 degrees and open above 45 degrees. Timer motor winding has a series capacitor and must be tested as such. Watch out for stalled or slow running motors that look OK. PS. : QUICK TEST - The timer can be turned with a screw driver through a service access hole. With the back - of - freezer plate off turn timer till it clicks and you hear compressor turn off, this is the defrost cycle (7-10min). Use it to see if the heater is getting hot.
Posted on Mar 12, 2009
  • 82 Answers
SOURCE: Frost build up, Frigidaire FRT18K63CW top
The heater can be replaced $30-$40 appliance parts store. Make sure that's the part you need most places won't return electrical parts. Could be a defrost terminator also.
Posted on Jun 29, 2009
  • 25 Answers
SOURCE: Frigidaire plht189sska top freezer fridge problem.
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Posted on Sep 15, 2009
Testimonial: "Thanks for your help. Just looking for direction and trying to troubleshoot ...very frustrating. Thanks again Em"
Frigidaire side by side refrigerator/freezer has h1 flashing on refrig. side
H1 is temperature detected as too warm. Is compressor running? Are evaporator and condenser fans running? Is there frost build up on inside back wall of freezer?
Sep 13, 2017 | Frigidaire Refrigerators
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Sep 30, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How can I stop condesation building up on back wall of freezer side ? Water is running onto floor and pooling up.
Good Morning Friend,
I understand you have condensation building up on the back wall of the freezer side of your Frigidaire refrigerator, model# FGHC2342LF. I also see that this is a new refrigerator for you, and the water is pooling on the floor. It would take 24 hours for your refrigerator to stabilize at the set temperatures. First, I suggest giving it this timeframe. Secondly, if it is hot and humid, this is normal and can occur. Lastly, check with your installer to make sure that your refrigerator was installed correctly. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire FGHC2342LF Side By Side...
I have a frigidaire FGHC2342LF and the refrigerator is not cooling
Good Afternoon Rick,
I see that you are having trouble with your Frigidaire refrigerator, model# FGHC2342LF, not cooling in the refrigerator portion.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your refrigerator, give it an hour to 2 hours to see if the temperature restores to the suggested temperature of 37 degrees for the refrigerator and 0 degrees for the freezer. If the temperatures do not go down, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire Refrigerators
Freezer too cold
Is this a model=>FGHC2342LF Sounds like the freezer=> 240597203 Thermistor may be defective??There should be one in the freezer that regulates the temp and this one may be causing the compressor to run continious and you may not be getting the correct reading from freezer. Have you seen this?
Sea Breeze
Jan 06, 2014 | Frigidaire FGHC2342LF Gallery Series...
Frost build up Frigidaire FFHS2611LSO
Frost build up usually indicates an air leak - check your door seals and any part of the door for gaps. Also make sure the unit does not need to perform a defrost cycle.
Aug 19, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My freezer works fine but the refrigerator part won't cool. What can I do?
The leading cause of the refrig.not working while the freezer does is because the freezer is not automatically defrosting as its supposed to,do you see frost build up on the back wall inside the freezer?? if yes their is frost build up in=side of the freezer its not defrosting.
This tip i wrote covers what to check to see why its not defrosting.
http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Sep 26, 2011 | Frigidaire Refrigerators
Ice build-up on the inside top of of freezer door
This is a problem that the factory has released a bulletin on.They have released new hinges, and insulation for inside the door. So far I've only seen the bulletin for Kenmore upright freezers made by Frigidaire. Since it is a Kenmore the bulletin is a Sears Service Flash but the units are identical. For sears its SF46-517. They may extend the service to Frigidaire units but you'll have to contact Frigidaire about that.
Nov 04, 2008 | Zanussi Z57 / 3 Bottom Freezer...
Freezer not cooling
remove back panel inside freezer and see if pipework is frozen up and also check fan is working. if pipework frozen up, indicates a fault with the defrost system
Sep 14, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Frigidaire FGHC2342LF 23 Cu. Ft. Counter Depth Refrigerator - Gallery Stainless Series Logo
457 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
