Question about Plumbing
My kitchen installer installed Franke USA model DFD901KIT in my new kitchen but water won't come out the faucet. It there something that needs to be removed that we don't know about? He said there were no instructions.
  • 2712 Answers
SOURCE: kitchen faucet Installation
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Posted on Aug 27, 2008
arealplumber
  • 33 Answers
SOURCE: DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
Posted on Dec 05, 2008
  • 3600 Answers
SOURCE: I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Posted on Aug 30, 2009
smokenic
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
  • 244 Answers
SOURCE: why would the side sprayer on my moen kitchen
Call Moen. Bad spray head or diverter.
Posted on Dec 18, 2009
Franke faucet FFPS200 has extremely low water pressure over the last few days. Same thing happened to exact same faucet in second home. How to repair?
You can check out the installation manual here that has a parts breakdown: https://s1.img-b.com/build.com/mediabase/specifications/franke/512399/ffps200_installsheet.pdf
Be sure to shut off the water below the sink prior to doing any disassembly.
Best of luck
Feb 24, 2017 | Franke Plumbing
I need a Franke faucet model # FF 822
I would try E-bay. Might also look for a rebuild kit. A last resort: Take it apart clean all the parts and then reassemble. Good luck.
Apr 01, 2014 | Franke Plumbing
LOW WATER PRESURE FROM A FRANKE KITCHEN FAUCET
There probably is sediment where the water is coming at the valve. Remove the head of the faucet and clean it . This normally is the problem.
Dec 24, 2012 | Franke FF-303 Kitchen Faucet with...
Hello i have a franke kitchen faucet #fff303 and the spray head is not working is there a replacment head you can send me?
There are websites that give instructions for disassembling the Franke faucets. Also, some have a valve cartridge ($20-50) that can be replaced (you take the handle off, the catridge is inside)/
Jun 15, 2011 | Franke FF-303 Kitchen Faucet with...
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Apr 23, 2011 | American Standard 4271S 'The Standard...
It sprays fine but off the spray thair is no presuser . we replaced the water lines in the house we have good preasure though out our home jest not at the kitchen sink
One of the greatest things about Franke Faucets is that they have a lifetime guarantee. If you recently changed the waterlines in the home then more than likely when the water was turned back on or lines pressurized the settlement in the water main (Outside of your home) was activated and clogged the aerator. Most aerators simply turn counter clockwise (With the water off) after remooving the aerator simply clean and dislodge any particles in another sink. As for the pull out, some models have an inline screen located between the hose and the faucet handle. Simpy remove the handheld faucet (With the water off) and clean the screen.
Feb 02, 2011 | Franke FF-303 Kitchen Faucet with...
Trouble with a Franke kitchen faucet - the spout has a retractable internal hose for spraying down the sink - it is not retracting as it should
Look at the clutter under the sink. Is the hose tangled or caught on something? There should be a weight clamped to the hose to make it fall back into place. This weight minght have slid down the hose.
Jul 17, 2010 | Franke FF-303 Kitchen Faucet with...
I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Mar 08, 2010 | Plumbing
''poor pressure hot water only on new 531 series''
If you remove the supply line from the faucet and open the valve into a bucket, do you have adequate pressure? If you do, you will need to remove the hot water stem to see if something washed up into the faucet when you first turned the water on.
Apr 10, 2009 | Price Pfister Savannah Two-Handle Kitchen...
Plumbing Logo
132 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
