Question about RCA 46 46LA45RQ LCD TV
46LA45R RCA 46" TV does not power up following a power loss
Any time tv is unplugged, or black out. It must be unplugged for at least an hour before you can get the red indicator light on the front, or it can turn on.
    Top Expert:
  • RCA Master
  • 14,553 Answers
If a power loss someone needs to open set and see if when power came back it popped the line fuse, follow power cord inside to the fuse which it goes directly to.
Posted on Dec 12, 2012
  • 4 Answers
SOURCE: green to red blinking light when plug in rca lcd
It is the capacitors on the power supply...They blew on ours...took it in a they replaced 7 for less than 100.00. Common problem with this tv because it gets hot. Hope that helps.
Posted on Nov 25, 2009
  • 901 Answers
SOURCE: Tv will not turn on
There is a fault condition in the TV. Safety circuit shuts it down.
Check with the authorized service center.
Posted on Apr 16, 2010
  • 8457 Answers
SOURCE: RCA L37WD12 out of control
Ur Tuner board have problems,just not dead yet.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.The Tuner board main IC have intermitten short,that why take out A/C power input work for awhile,and than back to the same problems.
Posted on Apr 22, 2010
budmrtn
  • 11361 Answers
SOURCE: RCA L26WD12 26IN, LCD TV will not turn on, the red
It can be due to unstable DC power from the power supply due to bad caps, or bad main board (I had to replace my main board, and later on the inverter boards). You may want to think about putting money into this TV.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
http://s807.photobucket.com/albums/yy352/budm/RCA%20L26WD12/
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 12, 2010
SOURCE: 42in Lcd RCA tv will not power on, the indicator
Hi Ruth, Im having the exact same problem. Ive read online that it is a fuse or something, not sure, but its the weekend, and i have no tv. Tried calling RCA cant get anything out of them. If you find out what it is please let me know. I know how frustrating it is...
Posted on Sep 24, 2010
I have a Panasonic 46" flat screen plasma tv that will stay on for as long as you want, but when turned off, will not come back on for hours
If the set is a few years old you might want to look at the caps in the power supply--not unusual for them to be puffed up and hence cause issues like this.
May 26, 2012 | Panasonic TH-46PZ80B 46 in. Plasma TV
My 46" rca
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.3_24_2012_2_45_20_pm.jpg
Mar 24, 2012 | RCA 46 46LA45RQ LCD TV
No sound on my 1997 rca home theatre tv
have you checked in the menu to see that the speakers have not been switched off if you have a sattelite or cable box try unpluging the for 10 mins and plug them back to the ac and do a fresh restart many times that clears up loss of sound issues if not then you will most likely have to call a servicer in your area for further assisatnce
Jun 05, 2011 | RCA P46810LV 46" Rear Projection...
TURNS OFF ALL THE TIME
Hi
Thanks for using FixYa. You’ll need to reset the Projection TV and to reset it follow these steps:
  1. Turn off the television and wait for 5 minutes.
2. After 5 minutes unplug the television power cord from the electrical outlet.
3. Let the television remain without power for more then 1 minute.
4. Plug the power cord back into the electrical outlet. If the television is plugged into a power surge protector, remove it from there and plug it directly into the wall outlet. Turn on the television. If the issue is resolved, then the problem is with the power surge protector and not the television.
If the issue is not resolved then this might have happened due to over-voltage. Please check the power supply unit for swollen/bulged capacitors and burnt wires/components on the power supply board of your TV. You should try and turn off the TV for 8-10 hours to reset it. Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition. All this is only recommended if you have electrical expertise and know how to solder/re-solder components.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 26, 2010 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
Sharp 46 aquos model LC46E77UN tv turned off power button just flashes on and off tried unplugging and waited an hour and replugged same conclusion power light just flashes
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Oct 01, 2009 | Sharp Televison & Video
Needs to be cleaned
The back comes off the unit.  Lots of screws.  If you do this, DO NOT touch anything related to the tubes.  Power it off for several hours...unplugged...before touching it.
Nov 23, 2008 | RCA P46924 46" Rear Projection Television
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
RCA 46 46LA45RQ LCD TV Logo
184 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
