Question about Coleman Led Rechargeable Spotlight Flash Spot Light 120v & 12v Charger Included
I need a replacement led globe for my coleman 12v 4351-700
Looking for 12v cigarette lighter charger for colman fridge Regards Chummy 0824478245
try searching for the following in ebay
Campingaz Replacement Power Lead 12v - For 12v Coolers
comes up with a number that state they are for coleman fridges
Mar 17, 2017 | Cars & Trucks
I changed both the low beam headlights, I wore glove so I wouldn't touch them with my bare hand, but they wont turn on. the high beams work so do all the other ones. Anyone ever have this problem?
Check for voltage on headlight plug with a car voltage probe or a globe with a wire soldered on one side for the probe wire and another wire soldered to globes other terminal to Earth - terminal or car body . when 12V switched globe lights up .
Then you can test low beam relay is getting voltage from headlight switch. You can check fuse is supplying 12v to low beam.
You can check relay is switching 12V to low beam headlight .
Mar 22, 2016 | Hyundai 2012 Sonata SE
Coleman 530 Lumens Spotlight needs a need battery FIFUTEC FP 1228, 12V 2.8Ah. Where can I find the right size?
Hi Mary, go to batteryspec.com. In the search box put in TR2.6-12 even though it's 2.6, it equates to 2.8 for our spotlights. The battery is around $20 with a 1 year warranty, and has the same specs (dimensions, terminal position) as ours.
Mar 05, 2014 | Coleman LED Rechargeable Spotlight
I have a very old SL Waber PowerHouse 250 that I brought out of storage. I bought an after-market battery. After plugging it all back together, and plugging it in, I find that the LED does not light. No...
Sounds more like a problem in the UPS than the battery. If you don't have a voltmeter or a friend who has one (should read 12 volts), try connecting the battery to a 12v car light globe (brake or turn indicator globe). The globe should glow brightly and get warm. If so, the battery is fine.
Jun 05, 2011 | Computers & Internet
Reverse lights only work sometimes on isuzu wizzard
Manual gearbox: check on right hand side of gearbox. There's an electrical switch(looks like large nut nut) with 2 wires coming out of it These wires have connectors toward the top of the gearbox, diconnect them.
The wires that this switch was connected to, conect them to each other. ie the reverse light switch has been bypassed. Put the vehicle in reverse. Turn on the ignition. DO NOT START. Check the reverse lights. If on the switch is faulty and needs to be replaced. If not measure the voltage across each of the wires and a good earth point. (Gearbox casing will do fine. ) One of the wires should read < 12V.
If 12V then
  • Globes are faulty(Replace)
  • wiring to the globes are faulty - unlikely -(This can be repaired by simply running a new wire to the globes)
If no 12V then the wiring to the fusebox is faulty. A quick fix is to run a new wire from the fusebox to the switch(Connect to fuse C-3, indicated as "turn, back")
May 31, 2010 | 1998 Isuzu Trooper
How to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Mar 16, 2009 | Coleman Camping, Backpacking & Hiking
Light Globes
You have 12 volt globes that are 50 watts power. Check out a home improvement store/lighting store for a replacement.
Sep 11, 2008 | Camping, Backpacking & Hiking
Rechargeable Camping Lantern
you need to coldsolder the pc board.
Apr 09, 2008 | Dryers
Coleman Led Rechargeable Spotlight Flash Spot Light 120v & 12v Charger Included Logo
96 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
weirdtop
oldhess
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
