Question about Fisher and Paykel Dishwashers
Fisherpakel, DD602. How do I replace the seal oround the top. It has a cut in it.
  • BillONeill Jan 27, 2013
    Explanation and videos were very helpful.
  • Fisher and P... Master
  • 3,247 Answers
The lid seal in DD602 works like a balloon. If the seal is cut then the air escapes and will cause the lid not to seal leading to leakage and flood switch trip which shuts dishwasher down.
See the following video.
You can buy the seal from this site but use the correct product code of your dishwasher to make sure you get the right part. The product code is engraved on the label located on the front under the top drawer.
Posted on Jan 27, 2013
How do I change the oil seals on my husqvarana lt 140
Back wheel seals? Your going to remove tranaxle. And then ,take top of the tranaxle to replace seals.
Mar 15, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Fisherpaykel Dishwasher, DD602 need air pump
If the seal is cut then I do not see any reason to believe the pump is also faulty. You can test if the pump is working or not buy listening to the sound when you start the dishwasher. The air pump runs for a few minutes at the start of the cycle. You can try and find pump for DD601 which might also work. Unsually the pump and the release valve should be replaced together for better operation.
Dec 11, 2012 | Fisher and Paykel Dishwashers
My 1994 ford van is cutting out oround 35 to 45 miles an hourand and is idleling a little rough
If it always starts back, it may be your MAP sensor. If so, it will cut off going 10 miles and sometimes 40 miles before it does.
Mar 06, 2011 | 1994 Ford Econoline
DD602 model. while running upper washer appears that the seal/gasket around the whole upper is not working as water makes it out of basin and on to the middle shelf, then drips on floor. is there a way to...
I had a air leak so that it would fail to keep a seal.
To find out what was going in a made up a hose, which I could put in line and fitted in a pressure gauge.  It showed that the pump was pumping, but the exhaust valve had a small leak.
Also, the pumps loose effciency as the butterflay valves wear.
Kit PH2 PN528148 Pump/Exhaust valve fixes this.
I reckon that this is the biggest weakness in FP dishwashers.
It would help kit of parts to repair solenoid & pump were available.
The coils just do not go faulty, so why replace them.
Jun 28, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Top Drawer light is out-display eratic powers on and off at will.
Below is the service manual link and a web site that I found. refer to the lower section where a person writes in that the fixed the flooding with a hairdryer. I hope this helps, they seem like fantastic dishwashers.
http://www.scribd.com/doc/6462163/DD601V2-Manual
http://fixitnow.com/wp/2004/10/25/appliance-repair-revelation-fisher-paykel-dd602-dishdrawer-f1-code/
Mat
Please rate me
Nov 30, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel dd602 dishwasher manual
i have a dd602 codeind u 3 i need sevice manual
Nov 30, 2008 | Dishwashers
How to reset my fisher and paykel dishwasher
you have to remove the bottom drawer and remove the water from the base.theres two push in tabs on the bottom sides dd603 or if its a dd602/601 theres plugs that pull out remove them and the front panel the drawer will lift out far enough to get access.but you may find its leaking.hope this helps.
Mar 20, 2008 | Dishwashers
Dishwashers Logo
50 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
