Question about Canon EOS 550D Rebel T2i Digital Camera
T2i pictures not coming good.
I have taken pictures last 3 years on this camera. While taking pictures on different mode,suddenly the pictures are totally out of focus. Even on Auto mode does same. Then I change to manual mode, and first couple of them comes good then it is either too dark or too bright. No idea what went wrong. If I switched to Auto, the sometimes couple of shots come good then the pictures are terrible again.
    Champion:
  • 254 Answers
Load up the ATG Canon EOS Utility on your camera & check by shooting tethered. Then view it on a big screen,
Posted on Dec 13, 2012
Santy
  • 14 Answers
SOURCE: Pictures are too bright when shooting outdoors in sunlight
Have you tried changing your settings manually to outdoor? Or adjusted the aperture? You can usually find the aperture settings under the menu button. If not, try adjusting to outdoor conditions and disabling flash. And also, lower your white balance a good bit.
Posted on May 01, 2007
markevans
  • 148 Answers
SOURCE: CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Posted on Dec 24, 2007
arnomonfort
  • 115 Answers
SOURCE: Canon 1000D wont let me shoot
It can be the cold or wet. try to keep it in dry place and change the battery.
Posted on Feb 04, 2009
t00nz
  • 4738 Answers
SOURCE: LCD screen and pictures go completly white
The camera is defective. But as you've only had the camera three months it still is under warranty. Canon is usually very responsive to these type of problems and will bend over backwards to make things right (probably the most responsive of the camera companies).
Call 1-800-OK-CANON to resolve this issue.
Posted on May 25, 2009
welcomejee
  • 10594 Answers
SOURCE: lcd screen flickers in photo mode
If your Canon A85 shows distorted image in live view (camera mode) then its known problem of ccd imager chip failure. Check below image.
canon offers free of cost ccd imager chip replacement in A85 model.
Please confirm if its canon A85 camera or any other model to provide you more info.
Posted on Dec 23, 2009
Tip
How to take best pictures.
1. The best pictures can be taken with a tripod and using self timer or the remote control of the camera.
2. Some people think that the best picture can be taken with suddenly pressing the shutter. In reality it is not true. So the best pictures can only be taken with two steps. First, pressing half way and without not shaking the camera continuing on pressing the shutter. At last the camera takes picture. But a good photographer does not know the moment of taking the picture. He/She only knows and concentrates on not shaking the camera.
3. Best pictures can only be taken with an artistic point of view. Best photographers place the subjects to the most estetic point and the best estetic position.
4. Best pictures can only be taken without using the flash.
5. Best pictures can only be taken at the Golden Hour time. Golden Hour is the time period, starting with the Sun rise and ends after an hour. Second Golden Hour starts before an hour of Sun Set and ends with the Sun Set.
6. Best pictures can only be taken by a best photographer so you can never see a best photographer's portrait as a best picture.
7. Best pictures can not be taken with a most expensive camera but can be taken by a best working amateur photographer.
8. Best pictures can not be taken by professionals but can be taken by the professional amateurs.
9. Best pictures can only be taken with the camera which has a greater sensor size.
10. Best pictures can only be taken with a natural view of the objects.
on Apr 21, 2010 | Cameras
T2i SD card say it's full but the card is empty
Try formatting the SD card from the camera. You can find this option in the menu.
Dec 19, 2012 | Canon EOS 550D Rebel T2i Digital Camera
I am not able to see what i am taking a picture of on my canon eos t2i....how can i fix this so i can see what i am taking a picture of?
You changed the setting. So 1st press the little botton with a camara icon at the rgith side of the viewer. 2. Try menu - live view shoot - enable. 3 read the manual because you are not going to use some really nice camera features wih the view finder active.
Apr 28, 2012 | Canon EOS 550D Rebel T2i Digital Camera
I'm trying to upload the pictures on my Canon EOS Rebel T2i and the red light is blinking with nothing coming up on my computer... please help!
red blinking is memory card activity so should wait. try putting the camera into playback mode when connecting to a computer and computer should come up with a range of options. if all things fail go get yourself a memory card reader and take the card out of the camera and transfer your photos that way. its better on your cameras battery life and its quicker
Feb 15, 2011 | Canon EOS 550D Rebel T2i Digital Camera
This is to inform that I am having Casio Digital Camera Exilim EX-Z500 for last few years. The same was giving very good pictures, but last week, it suddenly started malfunctioning. Whenever, we took...
Some things to try: 1. Go into the menu and find "reset" to return to factory default settings. 2. Check the ISO setting....you may have it set too high for outdoor pictures. 3. Check the "exposure compensation"...it should be at "0".
Oct 12, 2010 | Casio Exilim EX-S500 Digital Camera
My digital rebel is suddenly taking black/blank images
Take the lens off, set the camera to manual and put in 'Bulb' mode. Check to see if the mirror flips out the way and the shutter blind opens to reveal the digital sensor. If either of those two are not working they will result in no data recorded, hence the blank picture.
Take it to a service agent to fix it if this is the case.
Sep 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
My camera takes picture but there all black? The
Last year my Canon PSA60 got the black screen in shooting mode. Menu display was normal and so the picture review mode.
Canon service center replaced the image sensor for free. When it happened again, I asked the service center for unit exchange (trade-in/upgrade program). Now I have my PowerShot S5IS. Good bye PSA60.
Canon has issued this in their notice page: http://support-asia.canon-asia.com/index.jsp?fuseaction=support&prod_type=notices-digitalcameras-lcd
Regards,
Herry Chris
Aug 11, 2009 | Canon PowerShot A60 Digital Camera
S5000 - camera does not display images in 'review' mode - still stays in photo shoot mode
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager( they are still doing it). check it out.
Dec 24, 2006 | Fuji FinePix S5000 Digital Camera
Canon EOS 550D Rebel T2i Digital Camera Logo
90 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
