Question about Miele 24 in. G692SC Plus SS Free-standing Dishwasher
Dishwasher will not work
Did start and then the red light keeps flashing , rinse, salt , drain .
I had the same problem. on the same machine. when this light flashes it means that it cant easily intake or drain the water. just clear the filter located down the tube and clean all of its parts and the valve wich is down from a metal stipe next to the filter. after this press continiously the start button. this should do it!!!!
Posted on Mar 26, 2013
  • 210 Answers
SOURCE: MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Posted on Jun 01, 2008
SOURCE: MY MIELE G856 SC DISHWASHER
press the start/stop and hold for 6 seconds that should clear it.
Posted on Jul 23, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
  • 122 Answers
SOURCE: salt light is on, no manual. What do I do?
Remove the bottom basket from inside the dishwasher - you will see a twist cap on the bottom of the pan - unscrew and add your salt there - it takes about a box to fill. Reinstall cap, and the salt light will extinguish.
Posted on Jan 05, 2009
SOURCE: miele dishwasher red inlet light flashes
This is most probably a software glitch. I had the same issue a week ago and my dishwasher is only about 2 yrs old and only gets used on average once a fortnight.
At first I did everything as the manual shows in the troubleshooting section. The whole process takes only about 5 to 15 minutes depending on how good of a handyman you are.
When I cleaned all the parts involved (all pretty clean to start with anyway) and connect them all back, sadly the red light wouldn't go.
It looked like I was stuck with the most hated option I had left: call the dreaded technician and be prepared to depart with some hard-earned cash.
Before doing that and out of desperation, I decided to surf the net for clues, blogs, forums, etc... and on one of them I found my answer.
One blogger suggested that "if anything else fails, try the 'reset' step" which means pressing at the same time the On/Off button and the Start/Stop button. That operation put a big smile on my face (and my wife's face too) as the red light magically disappeared.
My suggestion is "first try the reset trick and if that fails try and clean the parts as the manual shows". It'll save you headaches because the reset would do the trick in 90% of cases.
I work in IT and I can understand the fact that a software malfunction would trigger the red light and not reset it.
Good luck.
Posted on Aug 14, 2009
My miele g680 dishwasher did have a flashing intake/drain I cleaned it seemed to be working fine, then everytime I try to start it the softener light comes on with no further washing activity.
that is just an indicator that your salt is low. it will stay on until you refill the water softener with softener salt. it will not affect the dishwasher to run it without the salt. the water for your final rinse will not be softened.
Apr 06, 2012 | Miele Dishwashers
Dishwasher - not washing
did you check the fuse
Jun 05, 2008 | Dishwashers
Inlet/drain, salt and rinse aid light flashing also water left in base of machine after it stops
Hi
Thanks for using FixYa. The first thing that should be checked is if its draining properly as it could be that the drain hose is clogged and needs to be cleaned. The drain pump also should not be clogged. Also the stopcock should be opened fully and the water inlet valve should be checked for any clogs. Also the metal filter, impeller cover and the air gap unit should be checked. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 06, 2010 | Miele 24 in. Novotronic G641 Plus Built-In...
Cda cw494 dishwasher it runs for about 20 mins
is the light indicator flashing because you need to add salt or rinse aid.i have a bosch and my lights only flash to give me information on addig salt and,or rinse aid. so i can stop this by setting my dishwasher to take all in one detergent ,then the lights will not flash.
Nov 10, 2009 | Dishwashers
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
L63 Salt light is flashing
goes for short time and 2 ljghts flash the red salt light wont go on
May 16, 2008 | Ariston Technologies L63 Free-Standing...
HELP WITH NON FUNCTIONING DISHWASHER
similar problems here, repair man says its fine but the salt light was on so i added salt and works ok now. Some dishwashers don't function properly without the salt and rinse aid, even though you're pills may have then included, you still have to add them seperately, dumb but necessary at times.
Feb 27, 2008 | Dishwashers
Miele 24 in. G692SC Plus SS Free-standing Dishwasher Logo
181 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
