Question about Home Security
House alarm entry chime
How do I turn on the slomins security system entry chime?
2 Suggested Answers
  • 17 Answers
SOURCE: my DSC security system is reading
First of all go to your security box.Now you will have to find where all the sensors conect to the panell.These area's on the board are called zones such as zone 1 zone 2 and so forth.Chech and make sure no wires have came loose from the screw termanils also make sure their is no corrision (good contacts are key).If this doesent work you will need a magnet find out which zone you are having trouble with such as front door back door window ect.Now their are two different sensers one is a flush mounted senser this will look like a little box on the frame of what ever it is securing.The other one will be a inset one this will be harder to find.It will be inside the frame of what ever it is securing.In any case you wil need to run the magnet over this device and see if the panel will reset.If this hapens then you know that their is something wrong with the orig. magnet.(When you shut the door or window the orig. magnet will align with the senser).Some times the distance between the senser and the magnet will effect the senser.If the senser is a flush mounted senser then their will be some wires you can acess to see if they are making contact.
((((( I DO NOT RECOMENT THIS ONE. IF YOU TRY THIS ONE YOU WILL NOT BE PROTECTING THIS ZONE AND SOMEONE CAN NOW BREAK IN )))))The next thing to try is to simply look on the panel door and read where it says which resistor it needs and where it goes on the panel in relationship to the correct zone buy the resistor and install it in the panel.
((((( I DO NOT RECOMEND THIS ONE. IF YOU TRY THIS ONE YOU WILL NOT BE PROTECTING THIS ZONE AND SOMEONE CAN NOW BREAK IN)))))The next thing to try is the zone bypass.The instructions on how to do this should be on the back of the key pad door.
The next thing to try is to look in the senser to see if it has a battery.Some sensers have a battery and they need to be replaced from time to time.Now I have been asuming that this is a senser on a door or a window but their are other sensors that are optional on this panel as well.Check all wires on these batterys and make sure all outer housings are securly on the sensors.
If none of this works then you probably either have something wrong with the wireing or the panel its self is faulty.If so contact a security technician.
Posted on Jul 30, 2009
How do you turn off an alarm for a 2005 Saturn Ion
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the CTD armed mode. Also, disconnecting the battery or pulling fuses does not disable the armed mode, since the BCM stores the CTD mode status in memory.
To disarm the CTD system in arm pending mode, SECURITY indicator flashing and doors open, perform 1 of the following:
Press the UNLOCK button on the keyless entry transmitter.
Insert a valid key into the ignition and start the vehicle.
To disarm the CTD system in the armed mode:
To disarm the CTD system when activated, alarming mode.
Jun 24, 2016 | 2005 Saturn ION
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
Aug 25, 2015 | Cars & Trucks
Slomins
I don'r see a problem
in your browser page search bar type in --Slomins-- and click on the item you have
I selected alarm and there is a pdf version user manual to download
you are entitled to the user manual when it was installed
Dec 13, 2017 | Home Security
Does the bcm control the alarm in a 2006 monte Carlo? I can't seem to get the alarm to go off. I've also noticed that I have no chime and turn signal sounds. I just recently purchased this car and...
The no chime and turn signal has nothing to do with the alarm. You have a issue with power supply to turn flasher and door chime. The alarm consist of The door ajar switch,body control module,front door lock switch,power door lock switch. You need to check your fuse for turn signal and the door chime
Feb 22, 2012 | 2006 Chevrolet Monte Carlo
Need the fuse panel layout for the panel by the passenger door [ just bought truck, panel cover missing. so we canttell which fuse runs what???
1994 Jeep Grand Cherokee Laredo
(Fuse Block - Passenger side of Dash)
1 5 9 13 17 21 25
20 A 15 A 20 A 20 A 7.5 A 15 A 30 A
2 6 10 14 18 22 26
15 A 15 A 10 A 20 A 15 A 15 A 30 A
3 7 11 15 19 23 27
20 A 15 A 15 A 3 A 15 A 15 A 10 A
4 8 12 16 20 24 28
15 A 15 A 15 A 20 A 10 A 7.5 A 30 A
1)Trailer Tow Relay 18)Airbag Module
2)Brake Lamps 19)Interior Mirror, Auto
3)Hazard Lamps Headlamps, Overhead
4)Security Lamp Console, VIC/GDM Module,
5)Interior Lighting Heated Rear Window Relay
6)Security Alarm Module Coil, Illuminated Entry Relay
7)Security Alarm Relay, and Chime Module
Security Alarm Module, 20)Heated Rear Window
Flash-to-Pass Switch, Overdrive Switch,
8)Overhead Console, Keyless Speed Control
Entry, Radio Memory/Clock 21)Security Alarm Module,
Memory/Chime Module, Lamp Outage Module
Power Locks, Power Mirrors, 22)Airbag Module,
HEVAC and VIC Speedometer, Tachometer,
9)Rear Wiper Telltales and Gauges
10)Radio 23)Heated Mirror Feed, Heated
11)Cigar Lighter Rear Window Switch
12)Parking Lamps, Automatic 24)Instrument Panel
Headlamps Illumination
13)Horn Relay 25)Power Seats
14)Power Lock Relays 26)Power Windows, Power
15)ABS Module and Relay Sunroof
16)Turn Signals 27)Security Alarm Module and
17)Heating and Air Front Wiper
Conditioning Module 28)Heated Rear Window Relay
Aug 20, 2010 | 1994 Jeep Grand Cherokee
94 grand cherokee fuse panel fuse id,,,need to know each fuse function, location in panel and amp
............1994 Jeep Grand Cherokee
......(Fuse Block - Passenger side of Dash)
.....1........5........9........13........17........21........25
..20 A...15 A...20 A....20 A....7.5 A.....15 A....30 A
.....2........6.......10.......14........18........22........26
..15 A...15 A...10 A....20 A.... 15 A.....15 A....30 A
.....3........7.......11.......15........19........23........27
..20 A...15 A...15 A.....3 A......15 A....15 A.....10 A
.....4........8.......12.......16........20........24........28
..15 A...15 A...15 A....20 A.....10 A....7.5 A....30 A
1)Trailer Tow Relay
2)Brake Lamps
3)Hazard Lamps
4)Security Lamp
5)Interior Lighting
7)Security Alarm Relay, Security Alarm Module, Flash-to-Pass
8)Overhead Console, Keyless Entry, Radio Memory/Clock
Memory/Chime Module, Power Locks, Power Mirrors,
HEVAC and VIC
9)Rear Wiper
10)Radio
11)Cigar Lighter
12)Parking Lamps, Automatic Headlamps
13)Horn Relay
16)Turn Signals
17)Heating and Air Conditioning Module
18)Airbag Module
19)Interior Mirror, Auto Headlamps, Overhead Console,
VIC/GDM Module, Heated Rear Window Relay Coil,
Illuminated Entry Relay and Chime Module
20)Heated Rear Window Switch, Overdrive Switch, Speed Control
21)Security Alarm Module, Lamp Outage Module
22)Airbag Module, Speedometer, Tachometer, Telltales and
Gauges
23)Heated Mirror Feed, Heated Rear Window Switch
24)Instrument Panel Illumination
25)Power Seats
26)Power Windows, Power Sunroof
27)Security Alarm Module and Front Wiper
Aug 19, 2010 | 1994 Jeep Grand Cherokee
Where do i find a fuse box diagram for a 1994 Grand Cherokee Laredo?
There are 2 fuse blocks. The Power Distribution Center is under the hood along the passenger side fender and has fuses and relays in it. The other is on the passenger side of the dash and has fuses and circuit breakers.
....1994 Jeep Grand Cherokee Laredo
.20 A...15 A...20 A...20 A....7.5 A....15 A....30 A
.15 A...15 A...10 A...20 A.... 15 A....15 A....30 A
.20 A...15 A...15 A....3 A......15 A....15 A....10 A
.15 A...15 A...15 A...20 A.....10 A...7.5 A....30 A
1)Trailer Tow Relay
2)Brake Lamps
3)Hazard Lamps
4)Security Lamp
5)Interior Lighting
HEVAC and VIC
9)Rear Wiper
10)Radio
11)Cigar Lighter
13)Horn Relay
16)Turn Signals
18)Airbag Module
Control
Gauges
25)Power Seats
Aug 01, 2010 | 1994 Jeep Grand Cherokee
Have ADT 3000 series alarm system - would like to set it to max
adt sw3000 panel does not support max button on key pad. best solution would be to have ADT tech reprogram Zones so windows are perimeter zones(instant when armed away or stay) and motions interior follower (instant when no perimeter zone was triggered first). doors stay exit/entry.
Feb 25, 2010 | GE Security Simon 3 Wireless Home Security...
Fusebox diagram
hi, this is courtesy of ask me help desk...
FUSE PANEL INTERIOR
1 - 20 Amp (Yellow)Power Antenna Relay, Trailer Tow Relay.
2 - 15 Amp (Blue) Brake Lamps.
3 - 20 Amp (Yellow) Hazard Lamps.
4 - 15 Amp (Blue) Security Lamp.
5 - 15 Amp (Blue) Interior Lighting.
6 - 15 Amp (Blue) Security Alarm Module.
7 - 15 Amp (Blue) Security Alarm Relay, Security Alarm Module, Flash-To-Pass.
8 - 15 Amp (Blue) Overhead Console, Keyless Entry, Radio Memory, Clock/Chime Module, Power Locks, Power Mirrors, HVAC & VIC.
9 - 20 Amp (Yellow) Rear Wiper.
10 - 15 Amp (Blue) Radio Accessory.
11 - 15 Amp (Blue) Cigar Lighter.
12 - 15 Amp (Blue) Parking Lamps, Automatic Headlamps.
13 - 20 Amp (Yellow) Horn Relay.
14 - 20 Amp (Yellow) Power Lock Relays.
15 - 3 Amp (Violet) ABS Module & Relay.
16 - 20 Amp (Yellow) Turn Signals.
17 - 7.5 Amp (Brown) Heater & Air Conditioning Module.
18 - 15 Amp (Blue) Air Bag Module.
19 - 15 Amp (Blue) Interior Mirror, Auto Headlamps, Overhead Console, VIC/GDM Module, Heated Rear Window Relay Coil, Illuminated Entry Relay & Chime Module.
20 - 10 Amp (Red) Heated Rear Window Switch, Overdrive Switch, Speed Control.
21 - 15 Amp (Blue) Cluster, Security Alarm Module, Lamp Outage Module.
22 - 15 Amp (Blue) Air Bag Module, Speedometer, Tachometer, Telltales, Gauges.
23 - 15 Amp (Blue) Heated Mirror Feed, Heated Rear Window Switch.
24 - 7.5 Amp (Brown) Instrument Panel Illumination.
25 - 30 Amp Circuit Breaker Power Seats.
26 - 30 Amp Circuit Breaker Power Windows.
27 - 10 Amp Circuit Breaker Security Alarm Module, Front Wiper.
28 - 30 Amp Circuit Breaker Heated Rear Window Relay
Nov 27, 2009 | 1993 Jeep Grand Cherokee
90 sec count down
You Can Turn off the panel beep under the cover that is what i did.
Apr 15, 2008 | GE Security Simon 3 Wireless Home Security...
Home Security Logo
102 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
