Question about Whirlpool LER5636P Electric Dryer
Dryer not heating, Interimittent Problem -------------------------------------------------------------------------------- Having an intermittent problem. The dryer turns on, drum spins, but you have no heat, checked the following components: Heating Element (bad and replaced) Thermal Cut-Out Hi-Limit Thermostat Checked the bad blower fan assembly inside the dryer, everything fine. Checked dryer for proper air flow in order to dry properly. The ducting has been checked and is not clogged. Removed the dryer hose from the back of the dryer and inspected it thoroughly from where it leaves the dryer to where it exits home, clear with no kinks or clogs. If you take everything apart, check the ohms, reset the fuses, spin the timers/switches and put back together it works for a few cycles and then goes back to not heating again. Would appreciate any help or ideas.
  • 979 Answers
Have you tried to bypass the hi limit switch or the thermal switch. It will work. If it works for a few times, then you will know the switch is bad. I did this on a friend's one time and it solved it. Only cost about 15 bucks. Godd luck and let me know how it turns out.
Posted on Jan 17, 2009
Whirlpol dryer intermittently dryes clothes. dryer p/n LGR8620PWO I do see the glow plug glowing put no flame.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 17, 2011 | Whirlpool Dryers
Intermittent heat problem.
heatman101;'
Jul 14, 2011 | Dryers
The heat for my gas dryer 110.74652400 is coming on intermittently and will not stay on.
heatman101;
Jun 13, 2011 | Kenmore Dryers
Runs fine low heat
heatman101
May 25, 2011 | Maytag Neptune MDG9700A Gas Dryer
Intermittent no heat/extended dry time
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 20, 2011 | Maytag Dryers
Dryer heats intermittently sometimes doesn't heat at all, no pattern. Model # GLGQ332AS4
The ignitor is going bad...
heatman101
Dec 30, 2010 | Frigidaire Dryers
I have a gas dryer, modle number mdg9700aww.There is no heat. drum rotates and fan works. Checked the heat sensor and ignitor and both work. The dryer heats intermittantly when the back is opened up....
heatman101
Nov 05, 2010 | Maytag Neptune MDG9700A Gas Dryer
I have a Whirlpool Imperial Gas Dryer (Model:LGN2000.JQ0) where the heat will intermittantly go on or stay off. Can you let me know what would cause that?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Whirlpool GGQ8831L Gas Dryer
Dryer wont get warm... intermittently works... sometimes canhear the ignitor spark, sometimes not. Completely cleaned all of the lint in the machine, exhaust line, etc... and got alot of lint. Thought it...
heatman101
Aug 28, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Gas dryer burner intermittently lights. Foul gas
heatman101
Aug 17, 2010 | Estate TGDS680EQ Dryer
Whirlpool LER5636P Electric Dryer Logo
113 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
