Question about Fisher and Paykel Dishwashers
Have a Fisher & Paykel two drawer built in, each drawer will start running, but stops many times thru the cycle and starts beeping.
If I press the start button it will proceed where it left off. It can stop sometimes up to 10 times, other times only a couple of times. It started with just the top drawer and now it is doing it on the bottom too. I used to be able to switch cycle runs and it would run better but now it doesn't seem to matter which one it's on, it stops and beeps.
  • Fisher and P... Master
  • 3,247 Answers
The dishdrawer is a very sophisticated dishwasher and is very sensitive to dirt collecting inside and in the drain hoses. My suggestion would be to first clean the drawers from inside with damp cloth, especially around the top panel. Buy Finish dishwasher cleaning kit (one for each drawer) from the supermarket. Select longest cycel on dishwasher and run each drawer with the cleaning kit inside as per instructions on the kit.
See if this makes any difference.
Posted on Jan 27, 2013
5 Suggested Answers
stephanos18
  • 144 Answers
SOURCE: Fisher paykel DD603 top drawer starts cycle then
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
Posted on Mar 26, 2009
  • 205 Answers
SOURCE: Fisher & Paykel DD601 top drawer won't start.
Most likely the micro-switch that tells the controller that the drawer is closed is broken. Its a tiny little black switch at the back of the left drawer slide, it had a metal actuator that is prone to breaking.
Posted on Jul 21, 2009
  • 7 Answers
SOURCE: Both drawers Fisher Paykel DD603i start Beeping/Draining
the unit as had a lieak your it thinks it as first un plug the unit then try taking out the bottom draw (pull it all the way out then at the bottom front on both sides there is to clips push both clips in and pull the draw it wiil leaft of it runners push the runs back in out of the way then the can see under the in the base of the unit if the can see water or damp dathch plz call an enginner as ther is 5 things it can be
if not water you will see a grey plactic cover in the bottom back right the main pcb is in there witch has a water sencer on it if you fell up to 4remover the pcb and wiep the two prongs that are on the end of it as wiep there it was siting then put back as it was ps the dont need to take any wires to repalces the draw pull the to runners back out sit the draw on them then clothes the draw but re open it and give the to cilps a lite pull to make sure they are locked back in to places pulg it back in and try it if this dont work plz call an enginner as there is 3 pcbs in this unti that will need cheking
Posted on Jul 23, 2009
  • 275 Answers
SOURCE: fisher & paykel double dish drawer top draw just beeps...
The controllers get very brittle & can break away from their housing, the reason it's rapidly beaping is because it thinks the door is open. PLEASE TURN IT OFF FIRST AT THE POWER POINT. Take the front draw panel off by pulling the plugs situated on the front behind the draws, the controller is at the top right hand side if it is loose then thats the problem, double sided tape will work but lots of it or try a wedge type arrangement. I know this is an old post but people refer to these for solutions much later.
Posted on Nov 30, 2011
Top half of my dish washer beeps when i push the power button
you will find this diagnostic service document useful.
http://applianceassistant.com/ServiceManuals/dishwasher-fisher-paykel-dish-drawer-dd603-ds603-service.pdf#zoom=100#scrollbar=1
The likely reason for top drawer not starting wash program when you press start button is the drawer home sensor is either faulty or the drawer is misaligned. This means controller thinks the drawer is open and does not start the cycle.
Apr 28, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer stops, will restart if I push start
Sounds like a micro switch problem to me, telling the dishwasher that the drawer is open when it is not actually open.
Dec 26, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Paykel dishwasher beeping with red light indicator. Won't stop unless unplugged. Doesn't work, (won't drain when it did work), can't change cycle. Have not used it in a long time due to...
try pulling out the bottom drawer and check to see if there is a puddle of water around the circuit board, if so it will make it do a lot of wierd things.
Jan 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi We have a problem with our Fisher &
First is to make sure there is no leak. Pull out the lower tube, access from the left side only this side you can put your hand in with a small tower to dry out the wetness if there is. If it is wet dry out really good then unplug the power cord for 24 hr. After that plug power cord back. Hold the lock button while press the Start button until you see a display appears. Press the Power button to see a clear display. Then hit Start button one by one until you see Ld ( it stands for Lid down) If you miss it, keep going until it comes back in a loop. When at Ld hit the lock button. Wait until the noise is stopping. Hit the lock button again. Wait until the noise is stopping. Now you can pull out the top drawer and press the power button to get out this manual mode. Good luck.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F 1 Error, blinking, beeping and will not stop even when turned off, so we had to turn the circuit breaker off to stop the noise.
You have a leak.
Either from the top lid seal or bottom lid seal. A s time goes by the water level activates the sensor causing the beep. It won't do anything until you fix the leak.
May 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel DD603 top drawer starts cycle then stops and beeps and doesn't go thru cycle
Mar 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel Dishdrawer beeping constantly
leave it unpluged to stop for now, the machine has detected a leak and is constantly running hte pumps within the drawers to try to remove any water.. problrm is the water detector is in bottom under the lower drawer and htere is no pump to remove that water ..canbge a fickle machine as far as leaks are concerned, but the easy reason is usually misloading of the drawer itself, was an item put in that was too tall , preventing the lid from coming down and sealing off drawer causing water to overflow down the side??? there should be(so logn as no previous repairmen have taken it) a tech/trubleshooing guide taped to teh back wall behind the lower drawer, which is easily removed by unlocking hte hinges on either side of the front of drawer, explained in your manual
Nov 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel double dishdrawer
pour some vinger in and run it thru a few cycle this will flujsh it out also if you have a hot tub supply store near you can buy a bottle of Foam Down and that will cut the bubbles down so you can wash again
May 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dd603 top drawer won't start
on the hinge slide there is a micro switch the draw needs to be removed to locate it.
Jan 26, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwashers Logo
154 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
