Question about Sewing Machines
Where do i get needles to fit sewing machine e&r classic model NT22
  • Sewing Machines Master
  • 7,365 Answers
Go to the sites below and call or email them about the needles
or try ebay
sewvacdoctor.com
a1sewingmachines.com
Posted on Dec 11, 2012
  • 96 Answers
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Posted on Dec 13, 2009
Mongo32
  • 111 Answers
SOURCE: my machine is not stitching
needle in backwards?
Posted on Jun 13, 2009
  • 1116 Answers
SOURCE: can't find replacement needles for Elna 1500
Check with a local sewing machine store and ask if they carry needles for industrial sewing machines.
These have a round shaft and may be what is needed.
Posted on May 09, 2010
SOURCE: the needle jams when i start sewing
Could be threaded wrong - check manual for proper threading
Needle could be bent - check and replace if needed
Needle plate could be damaged - see if any burrs are on it if so take to service dealer and have removed
Bobbin could be wound wrong - check manual
Bobbin could be bent - if so replace.
Posted on Jul 29, 2010
  • 1788 Answers
SOURCE: twin needle treading for singer sewing machine 3116
Yes, put your second thread in a cup behind your machine and thread your machine like normal
Posted on Aug 15, 2010
Where can i find needles for a singer 306k machine ?
What type of material are you going to be sewing? Sew-Classic has 10 needle packages of the size 12 and size 14 needles for the Singer 306 for light (not fine) and medium weight material. (It's a 206x13 needle for the single needle. The twin needle is a 306x3.) See http://shop.sew-classic.com/206x13-Sewing-Machine-Needles_c46.htm .
http://www.allbrands.com/products/15221-schmetz-german-206x13-flat-shank-needles-100-size has some notes on alternative needles. The site has boxes of 100 size 14 and size 12 needles. (The size 14 needles are out of stock due to delays on the manufacturer's side.) https://www.college-sewing.co.uk/206X13-SIZE-90-PACK-OF-10-NEEDLES (size 14) needles in stock.
Unfortunately, I do not see any twin needles available for the 306K. I hope this helps.
Feb 20, 2015 | Singer Sewing Machines
Machine skips stitches on bulky items
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Aug 19, 2013 | Simplicity Quilter's Classic SW240...
Euro-Pro Shark Sewing machine needle off center, hits needle plate
it sounds like the machine has jumped time & needs to be retimed
at a sewing machine repair shop.
I also suggest you throw away that denim needle, it's very
lightly damaged.
Sep 12, 2012 | Euro-Pro Sewing Machines
I HAVE A EURO SEWING MACHINE MODEL 373 IT WILL NOT SEW A STITCH
try these suggestions
change the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
try rethreading the machine top & bobbin
make sure the bobbin is not warped
make sure the bobbin is wound correctly & inserted correctly
in the bobbin case
if none of these suggestions help,, then you might think about having
the machine checked to see if there is something wrong inside the
machine
Jun 08, 2012 | Euro-Pro 373 Mechanical Sewing Machine
My bottom thread is making large loops, is the tension to tight or slack
it's to slack, try a 3 or 4 setting on the tension
& if you use your machine alot,, clean under the needle plate & bobbin area for loose threads & lint
using a can of air is helpful
Aug 07, 2011 | Simplicity Quilter's Classic SW240...
Which way does the flat side of the needle go towards in a 215 model?
the flat side should face the back of the sewing machine
here's a tip I learned about needle & thread compatibility from a needle & thread expert
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
happy sewing
Oct 12, 2010 | Husqvarna Huskystar 215 Sewing Machine
I have a white sewing machine model 415 and cant find needles to fit the machine
Hi. Sewing machine needles are standard sizes, so you shouldn't have a problem finding needles to fit. You use different size needles depending on what weight and type of fabric you plan to sew (I posted a chart that explains what size needle to use with what fabric).
What do you want to sew?
Robbie
Feb 26, 2010 | White Sewing 1866 Mechanical Sewing...
Sewing Machines Logo
82 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
