Would like to know if the rear panel fan of this cpu supposed to run all times
The fan of this unit noticed is not running,the cpu is shutting down after 10-15 minutes after beginnig to record an off screen program
  • 7,627 Answers
Yes, but the RPM's of the fan will change when the heat sensors reach a pre determined temp. You didn' mention your Make. Model of computer or your OS? Overheating will shut down the machine, this is done to prevent damage to components. You may have a bad fan or sensor, or worse. What is the age of the machine? Try to use SpeedFan: http://www.filehippo.com/download_speedfan/. Not knowing your machine, I'm not sure it will work with your hardware.
Posted on Dec 12, 2012
CLUEPATEL
  • 138 Answers
SOURCE: CPU fan not working
This problem is due to your Powersupply! Get your powersupply checked and if necessary get it replaced with new. Avoid repairing.
Posted on Jan 06, 2008
Poormanspc
  • 24 Answers
SOURCE: CPU shutting down.
Hi MonaMona,
Replacing a CPU fan is easy, but be carefull, the CPU will have old thermal grease on it, so unlatch the CPU at the same time you take the fan off. Because the CPU will come up with the fan, so unlatch the CPU pins, to release the CPU pins, when taking the fan off. And when putting the new fan on the CPU, & the fan nust be smaller then 80mm, the sell just CPU fans. Make sure you put on thermal grease on the CPU, so it won't over heat & will protect your CPU, also don't cake on the grease. Put on a small amout & spread it on the CPU thin. Let me know if that does it for you.
Good Luck with it.
Posted on Mar 09, 2008
SASSYBEAR
  • 148 Answers
SOURCE: my Emachine T5212 has a loud fan constantly running
sounds like a fan is going out .. with the case open can you identify which fan is making the noise?
Posted on Mar 10, 2008
var-pun
  • 331 Answers
SOURCE: emachine 5220 keeps tuning its self off
I think the problem  may be that your operating system  may have gone corrupt
try  to enter the Safe mode  (if you can )
and see if you can  revert back to old settings and whether it helps or not
else   you would have to
  reinstall the whole operating system
Posted on Nov 09, 2008
  • 38 Answers
SOURCE: Thinkcentre M55 8806 power on off problem
May be your computer motherboard wires connection get loose or getting moisture in wires. Or there may be some earthing problem in ur power switch. First, check the wires connection & tighten up properly. if problem persists, check the earthing by power tester. Check you RAM if it is properly tight in the jack.
Posted on Dec 26, 2008
Gateway gt4016 desktop, s/n gcm64 110 54982 unit will not boot up, pressing power button, fans starts, yellow light comes on, then shuts down. cleared cmos, pressed power button unit will boot up but...
the cpu could be over heating make sure its secure if you like get some thermal paste from your local pc world put a little on the top of the cpu under the cpu fan and replace fan securely might work be carefull....bonnell
Sep 17, 2011 | Gateway GT4016 Desktop PC
No video, hard not running, fan not spinning, but i try my memory to another laptop, its working. and power is stable. pls help me to fix my tg averatec 8200 series?
Had you notice that the laptop would start up, then a while-time later would shut down ? Were there times that you had to keep turning on the laptop because it would shot down?.Have you notice that the FAN was not spining?, did not hear it (noise) spin?
If that is so, you could have damaged the MOST important part of the laptop...the CPU (Central Processing Unit) It is the heart of the computer\laptop. Try one more thing. Place to the side of the laptop where the FAN output would be a FAN (could be small, but MUST be powerful) blowing at an angle INTO the laptop. Turn the laptop on (by the way REPLACE memory sticks and anything that you took out). If the cpu is damaged it may be have to be replaced.It can be done, but sometimes difficult!!
P.S. you must see if your original FAN is working, then that must be replaced also...
Sep 01, 2011 | Computers & Internet
I have a Scaleo 600 which has been difficult to switch on for some time. I have been getting it to switch on ok provided I had switched the unit off on the rear panel when I shut down in the normal way....
HELLO ,
IF YOU HAVE THIS PROBLEM THEN IT MUST BE BY CPU.
REATTACH LOOSE CABLES ,HARD DISK AND CMOS BATTERY
IF IT DOESNT SOLVE THE PROBLEM THEN REPLACE YOUR CMOS BATTERY WITH NEW ONE..............
Apr 05, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
When I turn on my computer it runs for a couple of seconds and then stops.
Unplug everything inside the computer, except the motherboard and the front panel power on switch. Power up the computer. If the PS fan continues to run, (power supply doesn't shut down)and the CPU fan runs, then power off the unit and reinstall each device, one at a time, turn the power supply on after each device is installed (and off, before installing the next device).
You can not easily start the power supply if it is not connected to the cpu motherboard.
If the power supply shuts down with only the motherboard attached, then you will need either another power supply, to test the MB, or another MB to test the power supply.
R
Feb 02, 2011 | Acer DPS-420GB (dps420gb) Power Supply
I have a kitchaide side by siide refrigerator 7 yrs old. i have been noticing burning smell coming from refrigerator (not inside) when i walk by refrigrerator it smells like burnt wires burning. i dont...
Just went through the same thing only with a water leak also. The root of the issue was a computer board which shut down a cooling fan which is supposed to cool the compressor. A repair technician stated the warning signs are a constantly running unit and the center divider between the freezer and refrigerator is hot to the touch. As far as the smell and water leak. The waterline was laying against the compressor which registered at 174 degrees which melted the line and caused the leak. I guess your compressor could just be very hot also.
This line was after the valve so the only time it leaked was when the ice maker refills or one dispenses water. Access is easy pull unit out and remove lower panel on rear of unit. fan , compressor and line all visible At first he thought it was just a cooling fan but after further testing found it was a control board. The big problem is this causes a small unnoticeable water leak which over time does a great job at damaging wood floors, etc. Short term fix while waiting for parts is to shut off water and place a small fan pointed at compressor, this did reduce temp of divider and now it doesn't run 24/7.
Good Luck
Nov 17, 2010 | KitchenAid Superba Architect KSCS25INSS...
If the weather outside is cold and you are running the heatpump/aircondition. Is the fan motor on the outside suppose to stop running. I notice the there is heat coming from the unit after it as been...
yes the fan will shut down during the defrost cycle. But the fan only shuts down during this cycle....other than defrost the outdoor fan motor should be running during a call for heat.
Jan 07, 2010 | Amana Heating & Cooling
Cpu fan is not plugged in, never has ?
The socket for fan power on the motherboard is usually white and has three metal pins. If your fan connector does not match this socket I would suggest buying a fan that does have the proper connector. A lot of fans are attached to the heat sink with four screws so it is not a difficult thing to replace. This should be done ASAP before the processor burns up.
Jan 18, 2009 | Dell OptiPlex GX1 PC Desktop
Lenovo laptop shutdown suddenly after working for a while
Hi James, replace the fan or If it's still under warranty have it serviced. Suggest you stop turning it on until the fan is replaced. It could be the fan cooling the CPU. You don't want it to fry.
The shut down process is normal when over heating is detected by the system.
lenovo link. http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-63446
Mike
Mar 24, 2008 | Computers & Internet
Cpu fan starts then stops
Replace it and let us know if it still happens with the new one.It shut down because of overheating, I hope it didnt mess up your CPU.
Jan 06, 2008 | Biostar GEFORCE 6100-M9 Motherboard
CPU fan not working
you need to check your power supply if this is okay you need to replace the cpu fan. the cause of shutting down is the overheating of your cpu
Jan 06, 2008 | Acer Veriton 5200D PC Desktop
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
